4 Replies Latest reply on Jan 4, 2017 11:32 AM by kiwisenior
    PE 15 crashes using Fades
      I have been adding transitions between clips using cross dissolve. My project is made up of MT2 and JPEG clips. Where the story changes I have replaced the transition with a Fade Out Audio and Video on the end of the clip and a Fade In Audio and Video on the beginning of the next clip. When I then run play, just after the middle of the fade PE15 closes down. I have tried deleting some frames from the end and beginning of each clip, but this doesn't solve the problem.
      Any ideas?
        • 1. Re: PE 15 crashes using Fades
          Have you ensured that your JPEGs are no larger than 2500 pixels wide by 1875 pixels high (as I explain in my books)?
          Do you render your timeline (press Enter) whenever you see a yellow-orange "render" line along the top of the timeline?
          What operating system do you have? Which processor is your computer using and how much free, clean, freshly defragmented space is on your hard drive?
          • 2. Re: PE 15 crashes using Fades
            kiwisenior Level 1
            Steve, my JPEGs are always original size and have never caused any problems in previous projects. In this case they are 2992 x 2000.
            Yes I always render after completing any changes or additions to the project.
            Running Win 10 64bit with an i7-3770K. I have 185 GB free of 500 GB and is continually being defragged by O&O Defrag.
            This is unusual as it is between 2 video clips with both the videos trimmed by 15 frames. A transition works fine but not the fade. In other places the fade works fine. Not sure what else I can try?
            • 3. Re: PE 15 crashes using Fades
              Based on what you're telling me, it seems to be related to those particular clips.
              Also, what graphics card do you have? Have you manually gone to the nVidia or AMD site to get the latest updates to your card's drivers?
              • 4. Re: PE 15 crashes using Fades
                kiwisenior Level 1
                I have an Nvidia GTX760 with the latest driver.
                Tried deleting one clip, then the other with no change to the issue. I then deleted both and replaced them from the Project Assets. This time the issue is resolved. They must have been corrupted somehow when I originally placed them on the timeline. Go figure???
                Thanks for your ideas.
