1 Reply Latest reply on Jan 4, 2017 12:33 AM by c.pfaffenbichler
    resizing using crop tool vs resampling
    owenpga2 Level 1
      is there a best way to resize and crop and image?
      i have a 30.5"x12.5" image at 300ppi and i want to resize to 48"x24" at 300ppi
      I compared setting the resolution and dimensions using the crop tool vs using the upsampling tool and i don't really see much difference.
      are they both doing the same thing?
      thanks
        • 1. Re: resizing using crop tool vs resampling
          c.pfaffenbichler Level 8
          Resampling with the Crop Tool uses the Interpolation Method specified under Preferences > General > Image Interpolation while Image > Image Size (which I suspect you might mean by »upsampling tool«) allows to set the method individually.
          If you should have meant Edit > Transform then you can also select the method individually (in the Options Bar) but »Preserve Details« is not available there.
