2 Replies Latest reply on Apr 19, 2017 10:00 AM by WolfShade
    Cold Fusion 9 Oracle Upgrade Problem
    chrisr82907079 Level 1
      Hello everyone! We have a few applications running on Cold Fusion 9 and running off of an Oracle 11g database. I'll be honest and say that I don't have much experience on the administration side of things as a database developer and don't use CF much, but the responsibility to support this has been thrown on my shoulders.
      Our DBA is upgrading our Oracle server to Oracle 12 C. She has already created the new Oracle 12c instance and has migrated our old database to the new database. I can telnet into the new 12c database from both my PC as well as the application server that has CF9 on it, so I know its up and running and there are no firewall issues. I can connect to the new server in SQL Developer just fine and have already tested read/write privileges.
      Everything on the database side has been mirrored from the old 11g server. When moving the CF applications to the new server, all I am doing is pointing the application to the new sever using CF administrator as the upgraded database server is mirroring the old server. I am using the SID and Server name provided to me from our DBA based on the new server's information, but when I submit this, I get an error message:
      Connection verification failed for data source: abc
      java.sql.SQLNonTransientConnectionException: [Macromedia][Oracle JDBC Driver][Oracle]ORA-12505 Connection refused, the specified SID (xxxxxxx) was not recognized by the Oracle server.
      The root cause was that: java.sql.SQLNonTransientConnectionException: [Macromedia][Oracle JDBC Driver][Oracle]ORA-12505 Connection refused, the specified SID (xxxxxxxx) was not recognized by the Oracle server
      If I change the SID to any other SID other than the one provided by our DBA, I get a completely different error:
      java.sql.SQLException: [Macromedia][Oracle JDBC Driver][Oracle]ORA-28040: No matching authentication protocol
      The root cause was that: java.sql.SQLException: [Macromedia][Oracle JDBC Driver][Oracle]ORA-28040: No matching authentication protocol
      Has anyone encountered this, and if so, any recommendations as to what I can do to fix this? I experience this issue for all CF9 data sources/applications on this server.
