I've re-install my Indesign CS4 ME and its writing me the messege "cannot load plug-in arabiclayout.IndesignPlugin." and some more plug ins.
what can i do to fix it?
The app doesn't open for me.
InDesign CS4 is not supported under El Capitan. Probably best to upgrade to CC2015/17.
What operating system? Have you tried re-installing?
OS X El capitan 10.11.
I've tried to re-installing, doesn't and it work.
Man, i need this version Plz.
could you give me the link ?
Appreciated in advance
There's no link. You must use your original disks, but first install a compatible operating system if you can. If you can't, then it's time to upgrade InDesign.
If you are lucky you can install and use ( two totally different things! ) InDesign CS4 on Mac OS X 10.11.
Nearly no chance for 10.12 or above, I think.
Regards,
Uwe
Thanks and I will use version higher
