4 Replies Latest reply on May 20, 2006 9:39 AM by Tiller
    Fitting a picture to fill a box
      I have a layout that I've created in Flash that involves bringing a picture in dynamically into a box. I can get it to come in at the top left without a problem, but ideally I need it to fill the height of the box (if it's a portrait picture) or the width (if it's landscape).
      The box's dimensions are 555px wide x 420px height
      If it is a portrait picture, then it needs to be centred horizontally.
      I'm so used to pressing a couple of buttons in InDesign (fit content proportionally and then centre in box) that I forget everything technical in Flash requires so much thought!
      Any help would be most appreciated.
        • 1. Re: Fitting a picture to fill a box
          blemmo Level 1
          To scale the picture and center it when it's loaded, you can use simple percent calculation:
          box.pic._yscale = box._height * 100 / box.pic._height;
          box.pic._x = box._width / 2 - box.pic._width / 2;
          This assumes the picture is loaded in an MC 'pic' inside the 'box' MC, and it scales just one dimension, which could lead to distortion. To keep the original ratio, just scale the y dimension with the same factor.
          This would be the portrait scaling, landscape would be similar, just with the _width properties. You would have to know which type of picture was loaded before.
          • 2. Re: Fitting a picture to fill a box
            Tiller Level 1
            Hi Blemmo,
            Thanks very much for your reply - is there any way Flash can sense what kind of picture it is when it's loaded?
            • 3. Re: Fitting a picture to fill a box
              blemmo Level 1
              It can't 'sense' it, you would have to indicate it somehow. Maybe through special names of the files, e.g. "pic1_P.jpg" vs. "pic2_L.jpg" (P for portrait, L for landscape), so Flash could check what's between _ and . and react accordingly. Maybe it would also be possible to know it from the image dimensions, if there are big differences between portrait and landscape pictures.
              How do you load these pictures? If you have an external file (xml) with the filenames, you could store this info along the names, that should be the simplest way.
              • 4. Re: Fitting a picture to fill a box
                Tiller Level 1
                Many thanks for that... we'll probably be using a combination of PHP and XML so between those I'm sure we'll find a solution.
