• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
HLS vectorscope
New Here ,
Jan 04, 2017 Jan 04, 2017
I have an older version of SG that only has the HLS vectorscope. I know on the YUV scope you can check the graticule and see if you are going over the legal limit. How can I check this on an HLS scope ? I watched every video on the subject with no avail.
Leon
Views
1.9K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Jan 04, 2017 Jan 04, 2017
Been a while since I've used the CS6 version. So I downloaded and ran it ... um, yea, that HLS Vectorscope without graticules was a MAJOR complaint I had about the CS6 version ... you can see where your signal is sorta mostly, but ... without graticules, there's no use for this for much of what we need a Vectorscope for!
At the time Iridas was created, they mostly assumed if you really needed good scopes, you'd have a Tektronix setup via external boxes. So this scope was just designed more or les
Votes
Translate
Translate
LEGEND ,
Which version of SpeedGrade do you have?
Neil
Votes
Translate
Translate
Report
Report
New Here ,
CS6
Votes
Translate
Translate
Report
Report
LEGEND ,
At the time Iridas was created, they mostly assumed if you really needed good scopes, you'd have a Tektronix setup via external boxes. So this scope was just designed more or less to show the placement of your signal around the scope.
So ... in CS6 ... there isn't an option to figure out what the out-lying data points are really doing. Sadly. So I'd guess about the best you can do is plop on a " + " layer, and select the appropriate "Legalize" LUT, either NTSC or PAL depending on your location.
Neil
Votes
Translate
Translate
Report
Report
New Here ,
Right + a legalize PAL/NTSC layer will clamp down the waveform ( brightness)visibly. Will it also legalize saturation? If so I don't see the clamping like on the waveform.
Votes
Translate
Translate
Report
Report
LEGEND ,
My understanding is that it does ... but I cannot guarantee that! You'd need to test this before committing serious output to it.
Neil
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Thanks.
Votes
Translate
Translate
Report
Report
