4 Replies Latest reply on Jan 6, 2017 12:57 PM by Silly-V
    resizing width of a selected object.
    Peacock Level 1
      Trying to get a very simple script to adjust for the slight distortion that happens when a printing plate is wrapped around the print cylinder. Basically I need to condense the image width wise only (not the height) so it will compress something like 95-98% of it's original width but the height will be the same.
      I tried to make a fairly basic script to do this, but it keeps telling me "selectedObject.resize is not a function". Ultimately my idea was to create a variable called condenseRatio that would be the percentage I would reduce the width by, because not every plate would reduce by the same percentage. The distortion changes based on which print cylinder is chosen, so wherever the left x value of the repeating image is determines what percentage the image will need to be condensed. Currently I've just got the resize set to 90% of width just to see if I can get it going, and worry about using a variable number there later. So far, no go.
      Here's what I've cobbled together:
      // required: an open document and a selected path item
      var myDocument = app.activeDocument;
      var selectedObject = myDocument.selection;
      //Identify left edge of repeat
      var repeatBounds = app.activeDocument.groupItems['repeat'].geometricBounds;
      var r1 = repeatBounds[0];
      // Get position of selection bounds and create condense ratio
      var myBounds = selectedObject[0].geometricBounds;
      var x1 = myBounds[0];
      var x2 = myBounds[2];
      var rawRepeat = (r1 - x1);
      var rawGap = (r1 - x2);
      var rawPrintWidth = myBounds[2] - myBounds[0];
      var condenseRatio = (rawPrintWidth / rawRepeat) * 100;
      selectedObject.resize(
          90.0, // x
          100.0, // y
          true, // changePositions
          true, // changeFillPatterns
          true, // changeFillGradients
          true, // changeStrokePattern
          true , // changeLineWidths
          undefined); // scaleAbout
      Any help on what I'm doing wrong would be greatly appreciated.
      Thanks in advance.
        • 1. Re: resizing width of a selected object.
          Silly-V Adobe Community Professional
          The selection object in Illustrator scripting in an array, of sorts, so you have to pick one element in it to resize.
          var selectedObject = myDocument.selection[0];
          • 2. Re: resizing width of a selected object.
            williamadowling Level 4
            Silly's answer is absolutely correct. 'resize' is not a method of the array object. so you have to iterate the items in the array, however you have to be careful about that as well because if you simply iterate each item and reduce it's width, you're going to change the relative position of everything on the page. in order to keep the proportions of everything, you're going to need to group everything together before you resize. See the two attached images. For the 'after' image, i scaled each item's width by 50% to make the change more pronounced.
            • 3. Re: resizing width of a selected object.
              Peacock Level 1
              Thanks Silly!
              Didn't get a chance to implement this yesterday, but that's exactly what it was (as you clearly knew)... here's the new and improved script:
              •   // required: an open document and a selected path item
              • var myDocument = app.activeDocument;
              • var selectedObject = myDocument.selection[0];
              • // Get position of selection bounds and create condense ratio
              • var myBounds = selectedObject.geometricBounds;
              • var x1 = myBounds[0];
              • var x2 = myBounds[2];
              • var rawRepeat = (r1 - x1);
              • var rawGap = (r1 - x2);
              • var rawPrintWidth = myBounds[2] - myBounds[0];
              • var condenseRatio = ((rawRepeat - 18) / rawRepeat) * 100;
              • //Identify left edge of repeat
              • var repeatBounds = app.activeDocument.groupItems['repeat'].geometricBounds;
              • var r1 = repeatBounds[0];
              • selectedObject.resize(
              •     condenseRatio, // x
              •     100.0, // y
              •     true, // changePositions
              •     true, // changeFillPatterns
              •     true, // changeFillGradients
              •     true, // changeStrokePattern
              •     true , // changeLineWidths
              •     Transformation.LEFT); // scaleAbout
              • copy();
              Turns out my napkin geometry was a bit off and so my condense ratio had to be adjusted, but now it works beautifully.
              Thanks.
              • 4. Re: resizing width of a selected object.
                Sweet! Wanna mark as solved then?
