• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Problem exporting from DIN A4 PDF to EPUB
Contributor ,
Jan 04, 2017 Jan 04, 2017
Hello, I really would need a bit of advice about how may I export a DIN A4 PDF document (a magazine) to EPUB. When I export it, I only get the cover perfectly exported. However, the text and the next pictures are floating everywhere without control. I would like all the pages maintain the original format of the PDF, and the original size of the PDF (Din A4).
Any recommendations about this?
Cheers
Views
903
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jan 05, 2017 Jan 05, 2017
No you don't want to rasterise everything. As mentioned, have a look at the course and it will explain the strengths and weaknesses of FXLePub.
Votes
Translate
Translate
Community Expert ,
It is only possible to export as EPUB with fixed layout.
Votes
Translate
Translate
Report
Report
Contributor ,
Yes, but don't work. Even if I export it as fixed layout, I get the text floating everywhere and without control. Specially the pages that do not work well are those in which a picture is outside of the physical dimensions of the page, specially spreads. The only page working fine is the cover, because it is rasterized... however I only see well the pictures... the text fly away to the next pages...
Votes
Translate
Translate
Report
Report
Community Expert ,
Do you have access to the original InDesign document?
Votes
Translate
Translate
Report
Report
Contributor ,
Hi Derek, yes I have access I can open it. Why?
Votes
Translate
Translate
Report
Report
Community Expert ,
Which version of InDesign do you have?
Do you want to produce a FXL ePub or Reflowable Text ePub?
Is it a simply designed book (one column) or complex?
Votes
Translate
Translate
Report
Report
Contributor ,
Hi, I have the latest one, Indesign CC 2017.
I want to produce a FXL ePub (Fixed Layout EPUB).
It is a very complex Indesign document. Exactly it is a magazine. To understand the complexity think in Newsweek, VOGUE or Time.
I want the exported EPUB show the page perfectly, maintaining the vertical DIN A4
I think I am having problems also in the spreads, because the pages have pictures which go beyond of the physical dimensions of the DIN A4, and that is creating a strange EPUB file, when you open it you see very weird things, text out of control, going to next pages and pictures floating everywhere.
Votes
Translate
Translate
Report
Report
Community Expert ,
I suggest you take a Lynda.com online video course and come back here with specific questions:
Creating Fixed-Layout EPUBs with InDesign CC
You can get a 10-day feee trial.
Votes
Translate
Translate
Report
Report
Contributor ,
There is no way to maintain the same look in the EPUB as in the PDF without having to re-make all the design?
Perhaps rasterizing everything?
Thinking about having to remake everything gives me goosebumps!
Votes
Translate
Translate
Report
Report
Guru ,
Can you post a sample of a few pages in .indd so we can test it? You can use Dropbox or similar and post the link here.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Votes
Translate
Translate
Report
Report
