• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Canon MXF Transcode for Speedgrade
New Here ,
Jan 05, 2017 Jan 05, 2017
Hi, I have footage shot on a Canon XC10 in 4K 29FPS. I'd like to color correct the raw video BEFORE I begin editing and render out new working raw files for use in premiere pro.
I'm using ME CC and am having a hard time finding an appropriate file format. I tried AVI and the file ends up being a massive 1GB per second of footage. For now I converted to a PNG sequence and am correct that way but there has to be a different way.
I'm on Windows 10 with AME CC 2017.
Views
932
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Jan 05, 2017 Jan 05, 2017
Problem you'll run into there is I don't think SpeedGrade 2015.1 (last version) has a 4k output available, in "Native" mode.
To use SpeedGrade with that, and end up with 4k, the only two ways I know are use PrPro CC2015.2 and simply load clips on a sequence, then do a direct "Send to SpeedGrade" process, grade the clips, then you can work or export them, or use CC2017, load the clips on a sequence, and use fellow user Patrick's little app/process to mod the project file for use in SpeedGrade 2015
Votes
Translate
Translate
LEGEND ,
To use SpeedGrade with that, and end up with 4k, the only two ways I know are use PrPro CC2015.2 and simply load clips on a sequence, then do a direct "Send to SpeedGrade" process, grade the clips, then you can work or export them, or use CC2017, load the clips on a sequence, and use fellow user Patrick's little app/process to mod the project file for use in SpeedGrade 2015.1 out & back again in a Direct Link process.
I've tested that with some 4k, and it works fine. Not an "officially approved" process by Adobe, but it works ... for a small fee. Here's a thread on that ... on the SpeedGrade forum:
Update: My little Speedgrade/Premiere Project Converter still works with 2017
Other than that, maybe Kevin-Monahan​ might know of a codec that Sg-2015.1 can render in a 4k size ...
Neil
Votes
Translate
Translate
Report
Report
Community Expert ,
Jan 06, 2017 Jan 06, 2017
SpeedGrade will be happy in 4K if you deliver it the right codec. Cineform (in QuickTime) is a good cross platform one that Adobe Media Encoder has build in. The 10-bit one will be fine. But as you discovered, the file size explodes. So you will need a big and FAST raid setup to actually work with it.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Hey ... hi there!
I tried a couple clips of 4k in SpeedGrade yesterday, and did test render-out of a couple of different codecs including Cineform ... but got 1920-1080 results, except for once, where I got a 1280-720.
Ideas for getting 4k ​out​ of SpeedGrade native?
I tried the converter app listed on this forum using a 4k PrPro project and that did work well. And fast.
Neil
Votes
Translate
Translate
Report
Report
