• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Printing photo with filename.
Guest
Jan 06, 2017 Jan 06, 2017
I'm new to Photoshop. I am trying to print pictures with the filename as a header for work. I have managed to do so, but the header prints out (filename.jpg) @ 16.7% (RGB/8) *. How can I print with just the filename?
Views
11.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Enthusiast , Jan 06, 2017 Jan 06, 2017
Generally for this operation I use the Photoshop feature "contact sheet", so I can print an entire folder of images on a sheet by using the file name as caption. Choose: FILE > AUTOMATE > CONTACT SHEET.
Votes
Translate
Translate
Adobe
Community Expert ,
That sounds more like a screen capture of your Photoshop Image window is being printed.  If you want to add the file name to your image.  You need a Photoshop Script.  To add a text layer containing the Documents File name. on top of the  image or over to a boarer you make by adding canvas..
JJMack
Votes
Translate
Translate
Report
Report
Guest
Thanks for the input. I am still new to this, so not sure how to do that.
Votes
Translate
Translate
Report
Report
Enthusiast ,
Votes
Translate
Translate
Report
Report
Guest
That partially worked, but I would prefer to print one picture per page and not all together like that.
Votes
Translate
Translate
Report
Report
Enthusiast ,
Set columns: 1 and rows: 1. So you will have a photo per page
Votes
Translate
Translate
Report
Report
Community Expert ,
In the Print dialog box, try turning on the Labels option. As the tool tip says, it will print the filename alongside the image.
Votes
Translate
Translate
Report
Report
Guest
That is how I got the original file name. It shows the file name, but also the other stuff I mentioned and I can't get just the file name.
Votes
Translate
Translate
Report
Report
Community Expert ,
Oh, OK. Unfortunately I don't think that label can be customized.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
What you want to do is easily done with a Photoshop Script.  If you search the web for Photoshop script that Frame mats and label images or Puts File name,  date, exit ext. on image.  I'm sure you will find  some Photoshop user have made available. Search the Photoshop Scripting forum here too.  I have seen some that you can download.
If you can hack a JavaScript any script you download you cam have one it to customize how it works for you.
for example Add File Name as Text Layer « Julieanne Kost's Blog
FrameShop Script v0.9.5 for Photoshop CS5 & CS6
JJMack
Votes
Translate
Translate
Report
Report
