1 Reply Latest reply on May 17, 2006 11:26 AM by Newsgroup_User
    .swf reading XML file in .NET environment
    angelina28
      I have flash file that loads a XML file. The XML load works fine in a regular internet browser. I have a .Net environment (.aspx) that loads this flash file which is also reading the XML. This is where the XML data is not showing. What is it about .NET that prevents this data from loading?
        • 1. Re: .swf reading XML file in .NET environment
          Level 7
          It really depends on the XML document -- not the environment. For example,
          the built-in parser is somewhat limited and cannot handle processing
          instructions that do not begin with <?xml-
          Lookup XML.onData -- you can manipulate the raw string before it gets to the
          parser.
          -- or you could write your own parser
          "angelina28" <angiehust@yahoo.com> wrote in message
          news:e4fopk$p56$1@forums.macromedia.com...
          regular
          file
