0 Replies Latest reply on Dec 17, 2008 4:43 AM by DongerNeedFood
    help with translating a .net webservice
      My config: CF 7, win 2003 server, IIS 6
      Not sure how to explain this and I'll probably use the wrong terms, but I need to get info from an ASP webservice, but I've only been given VB.net example code. Here's the example code:
      Dim WebClient As New System.Net.WebClient
      WebClient.Credentials = New System.Net.NetworkCredential(ChallengeUserName, ChallengePassword)
      Dim ReturnXml As String = WebClient.UploadString(" http://xxx.xxx.xxx.xxx:2235/Data.ASP", SendPacket.ToString)
      That's easy enough...I think. So, here's my cfhttp call:
      <cfhttp username="xx" password="xxx" url=" http://xxx.xxx.xxx.xxx:2235/data.asp" method="post" useragent="#cgi.HTTP_USER_AGENT#" result="xxx" redirect="Yes">
      <cfhttpparam type="Header" name="charset" value="utf-8" />
      <cfhttpparam type="file" mimetype="text/xml" file="#thefile#" name="SendPacket" encoded="no" />
      The response I get is: "Connection Failure". ErrorDetail is: "I/O Exception: Premature EOF encountered"
      Through some googling, I found someone who had problems with IIS compression and changed their cfhttpparam header for Accept-Encoding....but that didn't help or change the response.
      Is the error "Premature EOF encountered" saying there's a problem on my side or in the response I'm getting from the webservice?
      If I browse straight to the URL, I get NOTHING. It doesn't ask for a user/pass...just get a blank page (no html).
      Any help would be appreciated.
