0 Replies Latest reply on Dec 17, 2008 4:44 AM by bdaul
    advice on FLV and question about borders
    bdaul Level 1
      First...I created a FLV file from CS4 AfterEffects. It is an animated book cover. I don't want little control panel at the bottom of the animation...which I get if I make it a .MOV file...so I figured FLV. What is the best format for an animation from AE put on a webpage...to load quickest...play on MOST browsers?
      IF I use QT...how do I get rid of the control panel at the bottom?
      IF I use FLV...how do I control the color of the borders...the default seems to be black...AND/OR can I get rid of the control panel bar with the FLV file too...the HTML follows:
      <object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" width="426" height="614" id="FLVPlayer">
      <param name="movie" value="FLVPlayer_Progressive.swf" />
      <param name="quality" value="high" />
      <param name="wmode" value="opaque" />
      <param name="scale" value="noscale" />
      <param name="salign" value="lt" />
      <param name="FlashVars" value="&amp;MM_ComponentVersion=1&amp;skinName=Clear_Skin_2&amp;streamName=PLAYbook&amp;a utoPlay=true&amp;autoRewind=false" />
      <param name="swfversion" value="8,0,0,0" />
      <!-- This param tag prompts users with Flash Player 6.0 r65 and higher to download the latest version of Flash Player. Delete it if you don’t want users to see the prompt. -->
      <param name="expressinstall" value="Scripts/expressInstall.swf" />
      <!-- Next object tag is for non-IE browsers. So hide it from IE using IECC. -->
      <!--[if !IE]>-->
      <object type="application/x-shockwave-flash" data="FLVPlayer_Progressive.swf" width="426" height="614">
      <!--<![endif]-->
      <!-- The browser displays the following alternative content for users with Flash Player 6.0 and older. -->
      <div>
      <h4>Content on this page requires a newer version of Adobe Flash Player.</h4>
      <p><a href=" http://www.adobe.com/go/getflashplayer"><img src=" http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif" alt="Get Adobe Flash player" /></a></p>
      </div>
      <!--[if !IE]>-->
      </object>
      <!--<![endif]-->
      </object>
