There are no items highlighted in red.
What am I doing wrong?
You need to complete the keyword section for both files and add at least one more keyword for each image.
Make sure to sort your keywords by relevancy. Take a look at this blog post to get some tips for adding keywords.
No idea. What are your trying to do and what program are you using? Please provide more information so we can provide more assistance.
Hi Brad
Thanks for responding.
I am new to Adobe stock. I downloaded my first two pics. When I click "Save Work" that is when I get the error message "
However there are no areas highlighted in red to correct.
I am using an iMac.
Thank you
Can you take some screenshots of what you see? There is no 'Save Work' button/link in Adobe Stock.
Now I am totally confused? You said you were downloading images. Your screenshot is in the Contributor portal too 'upload' your own photos to Stock to have for sale. That is two completely different things.
Are you trying to add photos that you took with your own Camera to be available for sale on Adobe Stock? If so, then you will get a better answer asking in the contributor forum. If not, then you are totally in the wrong place in Adobe Stock Website.
Hi Brad. Yes, I am trying to upload my own photos to sell. I will try the contributor forum.
Thanks for your reply's
Have a great day
No problem, good luck! 🙂
Hi I am having the same problem. (There is no items highlighted red to correct.) Please assist.
I suppose you need to delete some keywords as you probably have more than 50 keywords.
(BTW: looking at your follow up posts, you shoul ask questions that can be answered. It's not clear what you intend with those remarks here.)
Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied.
Don't copy & paste replies from language translators.
Post in your native language. If needed, we can use this forum's language translator.
Some of your changes could not be saved. Please correct the items highlighted in red below and try again.
hi I am facing this problem do you have any solution
Greetings!
Just to clarify, you are having trouble submitting Stock photos as a Contributor? Tell us more about the trouble you are having. A screen shot would be helpful as well.
Cheers!
