6 Replies Latest reply on May 23, 2006 7:34 PM by Robere_144
    Robohelp decompile problem
    Robere_144
      Greetings:
      I haven't been on the forum for a while, but I have a real problem. I inadvertently deleted some components of my original Robohelp data directory, so I followed the (excellent) instructions posted here regarding the use of the Keytools.exe pgm to decompile the chm file. This has worked for me in the past.
      Today, however, I find that, although the decompile works fine, the next steps fail -
      Open Robohelp HTML from the selection of pgms within Robohelp X5.
      Select New Project
      Click the Import tab
      Select MS-HTML Help project; OK
      Select the HHP file that keytools created; Open it.
      when I attempt to open the Helpfile.hhp file, a msg appears -
      'unable to create database - check that the directory is not read-only'
      the file folder is indeed marked 'read-only', but every time I uncheck it, the change is 'ignored'.
      I have never seen an instance in Windows XP where this happened before.
      Needless to say, I can't successfully recreate my Robohelp data files, at this point.
      Has anyone else seen this?
      thanx for your help!
      Robert Gross
      Budgetext Inc.
      Technical Documentation and Training
