5 Replies Latest reply on Jan 8, 2017 8:28 AM by karth80472045
    Recheck pathItems.length property in for loop
    karth80472045 Level 1
      hello everyone,
      i need your help , i am grouping pathitems and text frames in a layer , while looping through pathitems and text frames using for loop  , if required pathitem and text frames is found it will group move the group to beginning , but here is the problem so pathitem position is changed so i could miss many pathitems so how to resolve this problem.
      for eg
      here is my code
      function read_create()
        for(layer_iteration=0;layer_iteration<layer_file.length;layer_iteration++)
      if (layer_file[layer_iteration].locked){
             layer_file[layer_iteration].locked=false;
          if(layer_file[layer_iteration].name=="NUMBER")
              var theGrp =layer_file[layer_iteration].pathItems;
                for(var i=0,len1=theGrp.length; i<len1; i++) {
      if(theGrp[i].pathPoints.length == 8)
                    if(theGrp[i].stroked == true && theGrp[i].filled == true) {
                 var strkColor = new CMYKColor();
              strkColor.cyan = Math.round(theGrp[i].strokeColor.cyan);
              strkColor.magenta = Math.round(theGrp[i].strokeColor.magenta);
              strkColor.yellow = Math.round(theGrp[i].strokeColor.yellow);
              strkColor.black = Math.round(theGrp[i].strokeColor.black);
              if(Math.round(theGrp[i].strokeWidth*25.4/72*10)/10 == 0.3 && strkColor.cyan == magentaColor.cyan && strkColor.magenta == magentaColor.magenta && strkColor.yellow == magentaColor.yellow && strkColor.black == magentaColor.black) {
                       x=Math.round(theGrp[i].pathPoints[1].anchor[0]);
                       y=Math.round(theGrp[i].pathPoints[3].anchor[1]);
                       xx=Math.round(theGrp[i].pathPoints[5].anchor[0]);
                       xy=Math.round(theGrp[i].pathPoints[7].anchor[1]);
                       count=0;
                        for(text_iteration=0,len=layer_file[layer_iteration].textFrames.length;text_iteration<len ;text_iteration++)
                           if(text_frame[text_iteration].contents.match(/[A-Z]{1}[0-9]{1}$/) != null||text_frame[text_iteration].contents.match(/[A-Z]{1}[0-9]{2}$/) != null||text_frame[text_iteration].contents.match(/[A-Z]{1}[0-9]{3}$/) != null){
                         t=Math.round(text_frame[text_iteration].anchor[1]);
                         t1=(Math.round(text_frame[text_iteration].anchor[0]))
                         alert(text_frame[text_iteration].contents);
                       if(t1>xx&&t1<x){
                           if(t>y&&t<xy) {
                            var newGroup = layer_file[layer_iteration].groupItems.add();
                            newGroup.name = text_frame[text_iteration].contents+":";
                            theGrp[i].moveToBeginning(newGroup);
                            text_frame[text_iteration].moveToBeginning(newGroup);
        • 1. Re: Recheck pathItems.length property in for loop
          o-marat Level 3
          Try to use reverse loop sorting of items, like this:
          for (var i = collection.length - 1; i >= 0; i--) {
            var obj = collection[i];
            // some actions
          • 2. Re: Recheck pathItems.length property in for loop
            o-marat Level 3
            I'm few simplified the code:
            • without changing the logic I removed unnecessary levels of nesting
            • use the reverse iterators (for objects that moved)
            • simplify the regexp
            • declared variables and simplify some variable names
            Now it is better to read. Should work. Run it in ESTK and catch the errors:
            //@target illustrator
            read_create(activeDocument.layers);
            function read_create(lays) {
              var lay_i, txt_i, x, y, xx, xy, count, txtFramesLen, t, t1;
              for (lay_i = 0; lay_i < lays.length; lay_i++) {
                if (lays[lay_i].locked) lays[lay_i].locked = false;
                if (lays[lay_i].name != "NUMBER") continue;
                var theGrp = lays[lay_i].pathItems;
                for (var i = theGrp.length - 1; i >= 0 ; i--) {
                  if (theGrp[i].pathPoints.length != 8)  continue;
                  if (!theGrp[i].stroked || !theGrp[i].filled)  continue;
                  if (!(Math.round(theGrp[i].strokeWidth * 25.4 / 72 * 10) / 10 == 0.3 &&
                    strkColor.black == magentaColor.black)) {
                    continue;
                  x            = Math.round(theGrp[i].pathPoints[1].anchor[0]);
                  y            = Math.round(theGrp[i].pathPoints[3].anchor[1]);
                  xx           = Math.round(theGrp[i].pathPoints[5].anchor[0]);
                  xy           = Math.round(theGrp[i].pathPoints[7].anchor[1]);
                  count        = 0;
                  txtFramesLen = lays[lay_i].textFrames.length;
                  for (txt_i = txtFramesLen - 1; txt_i >= 0; txt_i--) {
                    var text_frame = lays[lay_i].textFrames;
                    if (!text_frame[txt_i].contents.match(/[A-Z][0-9]{1,3}$/)) continue;
                    t  = Math.round(text_frame[txt_i].anchor[1]);
                    t1 = (Math.round(text_frame[txt_i].anchor[0]));
                    alert(text_frame[txt_i].contents);
                    if (!(t1 > xx && t1 < x)) continue;
                    if (!(t > y && t < xy)) continue;
                    var newGroup  = lays[lay_i].groupItems.add();
                    newGroup.name = text_frame[txt_i].contents + ":";
                    text_frame[txt_i].moveToBeginning(newGroup);
            • 3. Re: Recheck pathItems.length property in for loop
              Thank you sir,  but pathitems is at beginning , i want text frame should be placed before the pathItem inside the group so textframe will be visible.
              • 4. Re: Recheck pathItems.length property in for loop
                o-marat Level 3
                maybe replace this line:
                to that:
                theGrp[i].move(newGroup, ElementPlacement.PLACEATEND);
