Hello,
As you can see in the image that I'm posting, I'm creating a document with a specific values. The problem that I found is that when I work with de document I can't see the "Sangria", and I think maybe it doesn't appear in the image that I see, but after, when I use it for the purpose I'm doing it (It will be the image of a folder), the sangria will be incorporated. I need it, it won't work if not. So, that's my question. Have any of you know exactly how it works?
I've just solve my problem. The fact was that I was selecting the bleed in "Valores del documento" and I would have to doing it in this other option"Ajustar documento". Now is working! However thanks for everything.
The bleed lines (Sangrado) won't appear if your file is in Preview mode. After you click OK, change the screen mode to Normal.
On second glance, I can see that you are in Normal mode. Do they show when you click on OK?
Not. And I cannot understand why, what actually appears are pink lines forming a rectangle and they seem like a sang. But it cannot be, because that lines appear when I chose a sang of 0mm or 20m. So, I don't know. I've tried changing the screen mode to preview from normal, and turn again, but it keeps not working.
The pink lines represent the top and bottom margins. The bleed lines should be red. I
s this a new problem? Have you tried deleting preferences?
Troubleshooting 101: Replace, or "trash" your InDesign preferences
My Indesing is only a test, in a few days I will not be able to use it anymore. So, I don-t know if it will works for me too. However I-ll try it tomorrow. Thanks.
However I'll try it tomorrow. Thanks.
OK. I'll check back on you tomorrow.
In the meantime, I keystroked your values as shown below, and realized that you don't have a margin set. (My red bleed lines are showing in the image, but they are hard to see against the dark background.)
Normally, you will want margins when creating a new document:
In this final image, I went to View and unchecked Match Pasteboard to Theme Color and it is easier to see the red bleed lines against the white background.
Look, I'm doing this document because of a content I'm suscribe in. Then this the information about the document they mention:
The measure of the desing must be 54,1 x 34,7 cm, with a bleed of 2cm around.
As you can see they mention nothing about margins, then I prefer don't to use them. Here I add the image how it is now, and I keep not understanding how to see the bleed.
And this is the image with white background, and I keep been unable to see the bleed.
So glad you figured it out!
