• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
2
How do I make a selection in multiple layers and free transform it on all layers?
Community Beginner ,
Jan 08, 2017 Jan 08, 2017
In MangaStudio a similar software, I am able to make a selection and apply it to all layers.
For example if I have an image with an apple and a banana and my layers are like this:-
1)one layer for line art work,
2) another layer for color
3) and another layer for texture
What I want to acheive is select half the banana with the selection tool and scale that part of the image, but I want it to look right by applying the scaling to all my layers.
I hope my question is clear.
If this is not possible is there a workaround?
Views
11.7K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advocate , Jan 09, 2017 Jan 09, 2017
Maybe you can marge your layers as a Smart Object (Select three Layers and with wight mouse Button choose Convert To Smart Object Command) then you can easily select any part of your mage (all layers) and transform it.
Before you transform selected part of image you can move it to new separate layer. Just:
  1. Convert all important layers to smart object
  2. Select any area you want
  3. Move to new layer (CTRL+J)
  4. And finally transform your image
Pawel
Votes
Translate
Translate
Adobe
Community Expert ,
The Forum Lounge is not for technical help, please provide the name of the program you are using so your message may be moved to the correct program forum
Votes
Translate
Translate
Report
Report
Sorry Yes, photoshop, the forums here are confusing so I thought I posted in the correct forum.
Votes
Translate
Translate
Report
Report
LEGEND ,
I will assume you are in Photoshop?
1: Select your layers you want to control in the layers panel
2: Right click on any of the selected layers
3: Choose 'Link Layers' from the menu
In some cases depending on your setup you can simply group them as well and select the group and make any changes.
Hope that helps.
Votes
Translate
Translate
Report
Report
Thanks for the reply Brad, yes Photoshop.
I will try this when I get home but I think what you suggested only allows for changing the whole layers not a part of it.
So if I have an apple and banana sharing the same  (Iineart, Color, Texture) layers, Can I choose to scale up the apple alone by making a selection that is applied to all layers. Or is the only way to do this is to combine all layers (lineart, color, texture) into one layer then make a selection for  the apple and then scaling it up.
Votes
Translate
Translate
Report
Report
Advocate ,
Pawel
Votes
Translate
Translate
Report
Report
New Here ,
Feb 04, 2023 Feb 04, 2023
Hi, I see that this post is from a while ago but I still can't find a satisfactory answer to this. The problem with this is that the new selection has all of its layers merged, so (using the analogy above) wanted to adjust the texture of the apple after making it larger, I wouldn't be able to without affecting all of the other stuff on the image. Is there a way to do transform the selection while keeping the multiple layers intact?
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
Aug 16, 2023 Aug 16, 2023
LATEST
If anyones still having this problem. Theres a photoshop plugin for PS CC that lets you transform a selection of layers without baking them. https://kritskiy.gumroad.com/l/factory?layout=profile
Super helpful.
Votes
Translate
Translate
Report
Report
