5 Replies Latest reply on Jan 8, 2017 9:03 PM by JJMack
    How to Select CTRL + Click command
    Dariusz1989 Level 1
      Hey
      Frustrating but I cant find it...
      I know there is selection.selectAll but I want to select only pixels in channel so... :
      doc.ActiveChannel.select.select < ??
      or
      doc.channel[5].select.select ??
      basically select pixels and then fill layer using selection
      Regards
      Dariusz
        • 1. Re: How to Select CTRL + Click command
          You can load a channel as a selection usinak acyion manager code.  I would also think you coul also add to the selecton by adding accitional channels to the selection.  The Acyion managet load may look something like this:
          // ======Load Alpha Channel Selection===============================
          function loadAlpha(channel) {
            var idsetd = charIDToTypeID( "setd" );
               var desc2 = new ActionDescriptor();
               var idnull = charIDToTypeID( "null" );
                   var ref1 = new ActionReference();
                   var idChnl = charIDToTypeID( "Chnl" );
                   var idfsel = charIDToTypeID( "fsel" );
                   ref1.putProperty( idChnl, idfsel );
               desc2.putReference( idnull, ref1 );
               var idT = charIDToTypeID( "T   " );
                   var ref2 = new ActionReference();
                   ref2.putName( idChnl, channel );
               desc2.putReference( idT, ref2 );
            executeAction( idsetd, desc2, DialogModes.NO );
          • 2. Re: How to Select CTRL + Click command
            Dariusz1989 Level 1
            Hey
            Yeah I know, but I was hoping I could do something like
            selectionR = doc.channel[1].select.loadSelection()
            selectionG = doc.channel[2].select.loadSelection()
            selectionB = doc.channel[3].select.loadSelection()
            do stuff with selectionR etc etc. So I can go back to it at will...
            • 3. Re: How to Select CTRL + Click command
              Also DOM Selection method:
              load (from[, combination][, inverting]) Channel. SelectionType boolean
              Loads the selection from the specified channel.
              var channelRef = app.activeDocument.channels.getByName("my channel");
              SelectionType DIMINISH or EXTEND or INTERSECT or REPLACE
              The selection behavior when a selection already exists:
              DIMINISH: Remove the selection from the already selected area.
              EXTEND: Add the selection to an already selected area.
              INTERSECT: Make the selection only the area where the new selection intersects the already selected area.
              REPLACE: Replace the selected area.
              Used in PathItem.makeSelection(),
              Selection.load(), Selection.select(), and  Selection.store().
              • 4. Re: How to Select CTRL + Click command
                Dariusz1989 Level 1
                I have no idea how to use it o.o
                Can you throw an example maybe?
                Btw thanks for help, many of your posts that I read helped me a lot in past!
                • 5. Re: How to Select CTRL + Click command
                  I use the Action manager code I posted to load the Alpha channels I have in collage template PSD the Map the Shape Size and image location on image in collages.  The Alpha channels must have the required names.  :"mage 1",  "Image 2", ..., "Image N"
                  I use the function I posted above. To load the Alpha Channels so I can size position and mask image layers to shape.
                  loadAlpha("Image " + imageNumber);
