2 Replies Latest reply on Jan 10, 2017 3:55 AM by arenol
    Reciving signal: "EXC_BAD_ACCESS" when attempting to transform TextFrameArt objects.
    arenol Level 1
      GDB is reciving signal: "EXC_BAD_ACESS" when I try to transform a TextFrameArt using the TransformArtSuite. Here is an exampke code.
      (Note I'still with CS5 SDK.)
      AIErr
      SetPointTextMatrix( AIArtHandle textArt, AIRealMatrix *matrix)
          AIErr error = kNoErr;
          int textType;
          VMGetTextType( textArt, &textType);
          if (textType == kPointTextType)
              /* since we cannot set the matrix directly, we need to calculate a
               tranformation and transform the object:
               Let C be the <currentMatrix>
               Let R be the final <matrix>
               Let T be the <transformation> matrix
               Since,
                  R = C * T
               then we can calulate
                  T = inv(C) * R
              AIRealMatrix currentMatrix, transformation;
              GetPointTextMatrix( textArt, &currentMatrix);
              sMath->AIRealMatrixInvert( &currentMatrix);
              sMath->AIRealMatrixConcat( &currentMatrix, matrix, &transformation);
              /* THIS IS WHERE IT ALL GOES WRONG: - the content of the <transformation> matrix is OK */
              error = sTransformArt->TransformArt( textArt, &transformation, 1.0, kTransformObjects));
          return error;
      Anyone know why?
