5 Replies Latest reply on Jan 9, 2017 12:44 PM by John Mensinger
    automatic layout updating
    up in lites
      not sure if this is a feature in indesign cc2017 or not??
      I am updating our catalog from a few years ago.. my boss said that I should be able to delete the discontinued products and the page layout should
      automatically update to move all items together and compress
        • 1. Re: automatic layout updating
          John Mensinger Adobe Community Professional & MVP
          It depends entirely upon the original setup of the layout. There are indeed ways to produce an everything-flow, like your boss seems to be describing, but it has to be done purposefully from the beginning. There are just as many ways (more, actually), to produce a layout that doesn't flow in that way.
          The fact that you're asking seems to indicate the original layout isn't yours, so to confirm either way, you'll have to do some exploring. open the file, save a copy under a different name, select/delete some content, and see what happens.
          • 2. Re: automatic layout updating
            up in lites Level 1
            we have all the original files because they are owned by our company, however the employee before me is gone..  I did open the orig file and save under new name an deleted content.. nothing moves
            • 3. Re: automatic layout updating
              up in lites Level 1
              is there a way I can now change my new file to have this everything-flow layout? im not even sure where to find that.
              • 4. Re: automatic layout updating
                BarbBinder Adobe Community Professional
                Are you brand new to InDesign?
                It's a function of working with threaded frames and anchored objects—which may or may not make sense immediately—depending on your existing knowledge of InDesign.
                • 5. Re: automatic layout updating
                  You won't find it. As I mentioned (and Barb reinforced), it's more of a method than a feature; a method that requires purposeful planning and procedure...from the beginning stages of layout. In other words, you'd essentially be starting from scratch, using several features in combination to anchor all your elements in threaded frames. There is no Easy Button.
                  So, seeing as you haven't given us a sense of your deadline, and not knowing the condition of the existing materials in terms of asset management, etc., redoing the layout with everything anchored in threaded frames for this go-'round may not be feasible, if you don't already know how to do it. On the other hand, if it's, say, less than 20 pages, and you have a month or more to get it done, come back and tell us so, and we'll show you how it works.
