10 Replies Latest reply on Jan 11, 2017 12:41 AM by jabulanim57049389
    Trusted function throwing exceptions when called initially but work afterwards
    jabulanim57049389 Level 1
      I have a working plugin that adds buttons to a toolbox, the issue I'm having is that when adding the buttons using the trusted functions e.g doc.addField, doc.addToolButton, it works but it keeps throwing exceptions and it looks as if it is affecting the application, the app crashes, the toolbox window is too small and I need to scroll instead of it fitting all the items. the error messages I get back are all from one call. The weird part that I am failing to understand is that these functions will work flawlessly on the second call but not on the first? instead I get the following exceptions being hit:
      InitializeFormsTrackerJS is not defined
      InitAnnot is not defined
      SetRSSMethods is not defined
      I am using Acrobat X Pro.
      Thank you.
        • 1. Re: Trusted function throwing exceptions when called initially but work afterwards
          Bernd Alheit Adobe Community Professional & MVP
          What can you see when you execute following in the console:
          for ( var i in this ) {
            console.println( i + " : " + ( typeof this[i]) );
          • 2. Re: Trusted function throwing exceptions when called initially but work afterwards
            This is the output I get from the print.
            app : object
            global : object
            console : object
            util : object
            search : object
            catalog : object
            identity : object
            shareIdentity : object
            SOAP : object
            Net : object
            RSS : object
            Collab : object
            AnnotsString : object
            EScriptString : object
            SOAPString : object
            Preflight : object
            PreflightResult : object
            PreflightProfile : object
            PreflightAuditTrail : object
            tts : object
            spell : object
            FormsString : object
            XMLData : object
            FormWorkflow : object
            security : object
            dbg : object
            event : object
            aActiveDocs : object
            aNewDoc : object
            numpages : number
            i : string
            inUMSSession : string
            edtFinish : object
            fileString : undefined
            appViewerType : undefined
            btnOpenRubric : undefined
            addCommentMarkIcon : undefined
            addMarkIcon : undefined
            addTickIcon : undefined
            addCrossIcon : undefined
            addCountIcon : undefined
            addStampIcon : undefined
            addDeselectIcon : undefined
            addHalfTick : undefined
            oo : undefined
            The above is before I call one of the trusted functions I mentioned, the following is what I got after the initial call:
            app : object
            global : object
            console : object
            util : object
            search : object
            catalog : object
            identity : object
            Preflight : object
            tts : object
            spell : object
            XMLData : object
            security : object
            dbg : object
            aNewDoc : object
            numpages : number
            i : string
            edtFinish : object
            fileString : string
            appViewerType : string
            btnOpenRubric : object
            addCommentMarkIcon : object
            addMarkIcon : object
            addTickIcon : object
            addCrossIcon : object
            addCountIcon : object
            addStampIcon : object
            addDeselectIcon : object
            addHalfTick : object
            oo : undefined
            • 3. Re: Trusted function throwing exceptions when called initially but work afterwards
              What can you see when you execute the code without the plugin?
              • 4. Re: Trusted function throwing exceptions when called initially but work afterwards
                There seems to be  a lot that is not being initialized because of the plugin...
                app : object
                global : object
                console : object
                util : object
                search : object
                catalog : object
                identity : object
                Preflight : object
                tts : object
                spell : object
                XMLData : object
                security : object
                dbg : object
                cTableOddRowColor : string
                cTableEvenRowColor : string
                cTableHeaderColor : string
                myReviewTrackerDebugAlert : function
                getFormsString : function
                CBAutoConfigCommentRepository : function
                IWEmailSteps : object
                IWEmailFormSteps : object
                IWSteps : object
                IWFDSteps : object
                ShareFileSteps : object
                UploadFileSteps : object
                DocCenterLoginSteps : object
                DocCenterSignupSteps : object
                ERTCSteps : object
                OldSRIWsteps : object
                filesAtDocCenter : object
                deadlineDate : string
                internalDeadlineDate : string
                objectDeadlineDate : object
                RT : undefined
                SharedReviewDocCenterInitiator : object
                SharedReviewWebDAVInitiator : object
                SharedReviewAppleiDiskInitiator : object
                SharedReviewSMBInitiator : object
                SharedReviewSharepointInitiator : object
                InitializeFormsTrackerJS : function
                InitializeMultimediaJS : function
                IDS_GREATER_THAN : string
                IDS_GT_AND_LT : string
                IDS_LESS_THAN : string
                IDS_INVALID_MONTH : string
                IDS_INVALID_DATE : string
                IDS_INVALID_DATE2 : string
                IDS_INVALID_VALUE : string
                IDS_AM : string
                IDS_PM : string
                IDS_MONTH_INFO : string
                IDS_STARTUP_CONSOLE_MSG : string
                RE_NUMBER_ENTRY_DOT_SEP : object
                RE_NUMBER_COMMIT_DOT_SEP : object
                RE_NUMBER_ENTRY_COMMA_SEP : object
                RE_NUMBER_COMMIT_COMMA_SEP : object
                RE_ZIP_ENTRY : object
                RE_ZIP_COMMIT : object
                RE_ZIP4_ENTRY : object
                RE_ZIP4_COMMIT : object
                RE_PHONE_ENTRY : object
                RE_PHONE_COMMIT : object
                RE_SSN_ENTRY : object
                RE_SSN_COMMIT : object
                ColorConvert : function
                ColorEqual : function
                color : object
                font : object
                border : object
                style : object
                highlight : object
                zoomtype : object
                cursor : object
                trans : object
                position : object
                scaleWhen : object
                scaleHow : object
                display : object
                permission : object
                submitFormUsageRights : object
                fileSystem : object
                encoding : object
                requirements : object
                HostContainerDisclosurePolicy : object
                AFDigitsRegExp : object
                AFPMRegExp : object
                AFAMRegExp : object
                AFTimeLongRegExp : object
                AFTimeShortRegExp : object
                AFTimeGarbageRegExp : object
                AFBuildRegExps : function
                AFNumberDotSepEntryRegExp : object
                AFNumberDotSepCommitRegExp : object
                AFNumberCommaSepEntryRegExp : object
                AFNumberCommaSepCommitRegExp : object
                AFZipEntryRegExp : object
                AFZipCommitRegExp : object
                AFZip4EntryRegExp : object
                AFZip4CommitRegExp : object
                AFPhoneEntryRegExp : object
                AFPhoneCommitRegExp : object
                AFSSNEntryRegExp : object
                AFSSNCommitRegExp : object
                AFMonthsRegExp : object
                AFExactMatch : function
                AFExtractNums : function
                AFMakeNumber : function
                AFExtractRegExp : function
                AFMakeArrayFromList : function
                AFExtractTime : function
                AFGetMonthIndex : function
                AFMatchMonth : function
                AFGetMonthString : function
                AFParseTime : function
                AFDateFromYMD : function
                AFParseDateEx : function
                AFDateHorizon : function
                AFParseDate : function
                AFParseDateWithPDF : function
                AFMergeChange : function
                AFRange_Validate : function
                AFSimpleInit : function
                AFSimple : function
                AFSimple_Calculate : function
                AFNumber_Keystroke : function
                AFPercent_Keystroke : function
                isNumber : function
                isAlphabetic : function
                isAlphaNumeric : function
                isReservedMaskChar : function
                maskSatisfied : function
                indexOfNextEssential : function
                AFSpecial_KeystrokeEx : function
                AFSpecial_Keystroke : function
                AFDate_KeystrokeEx : function
                AFDate_Keystroke : function
                AFTime_Keystroke : function
                AFNumber_Format : function
                AFPercent_Format : function
                AFSpecial_Format : function
                AFParseDateYCount : function
                AFParseDateOrder : function
                AFParseGMTDateString : function
                AFDate_FormatEx : function
                AFDate_Format : function
                AFTime_Format : function
                AFTime_FormatEx : function
                AFSignatureLock : function
                AFSignature_Format : function
                AFStringReplace : function
                LookUpWordEnable : function
                LookUpWordDefinitionURL : function
                encryptUsingPolicyForJSObject : function
                LoginForGuardian : function
                RefreshPoliciesForGuardian : function
                ANSB_None : number
                ANSB_Page : number
                ANSB_Seq : number
                ANSB_Author : number
                ANSB_ModDate : number
                ANSB_Type : number
                ANSB_Subject : number
                ANFB_ShouldPrint : number
                ANFB_ShouldView : number
                ANFB_ShouldEdit : number
                ANFB_ShouldAppearInPanel : number
                ANFB_ShouldSummarize : number
                ANFB_ShouldExport : number
                ANFB_ShouldCollaborate : number
                ANFB_ShouldNone : number
                IPV6Type : number
                IPV4Type : number
                debugExcept : function
                ANTrustPropagateAll : function
                ANClipPrec3 : function
                CBEncodeMaybeInternalStrings : function
                CBCanDoReviewWorkflowCheckExpr : string
                CBCanDoWorkflowCheckExprAPR : string
                ANsums : object
                ANsumorder : object
                binsert : function
                isort : function
                ANstateful : function
                ANsumFlatten : function
                ANsummAnnot : function
                ANsummarize : function
                CBFNiceTableName : number
                CBFNiceDBName : number
                CBFDBPerDoc : number
                CBgetTableDesc : function
                CBgetTableConnect : function
                CBgetInfo : function
                CBsetInfo : function
                CBcreateTable : function
                CBconnect : function
                CBannotdata : object
                CBannotData : function
                CBannotSetData : function
                CBDeleteReplyChain : function
                CBGetReplyChain : function
                CBPutReplyChain : function
                ADBCAnnotEnumerator : function
                CBStrToLongColumnThing : function
                ADBCAnnotStore : function
                WDmungeURL : function
                WDAnnotEnumerator : function
                ANSendForReviewEnabled : function
                ANSendForSharedReviewEnabled : function
                ANSendForFormDistributionEnabled : function
                ANSendCommentsToAuthorEnabled : function
                ANVerifyComments : function
                ANDoSend : function
                CreateViewerVersionCheck70 : function
                CreateViewerVersionCheckCase : function
                CreateViewerVersionCheckString : function
                CreateViewerVersionCheckStringsCluster : function
                ANContinueApproval : function
                ANEndApproval : function
                ANRejectApproval : function
                ANApprovalGetStrings : function
                eMailValidate : function
                DoIdentityDialog : function
                ANStartApproval : function
                ANSendForApproval : function
                ANSendForBrowserReview : function
                ANSendForReview : function
                ANSendCommentsToAuthor : function
                ANSendApprovalToAuthorEnabled : function
                ANAuthenticateResource : function
                TestHSShare : function
                ANMatchString : function
                ANMatchStringCaseInsensitive : function
                ANShareFile2 : function
                ANDefaultInvite : function
                CBdef : function
                Matrix2D : function
                hasHanko : function
                SetHTTPMethods : function
                SetRSSMethods : function
                InitAnnot : function
                DebugThrow : function
                SharedString : function
                getDriver : function
                SOAPString : object
                Collab : object
                RSS : object
                Net : object
                SOAP : object
                GetStepNum : function
                ANDumpObj : function
                DebugPrintln : function
                TestReview : function
                ANCreateMLSElement : function
                ANCreateMLSEElementsFromArray : function
                ANCreateTipElements : function
                ANCreateSkipElements : function
                CBSetProductVariant : function
                CBIsValidEmail : function
                ANFancyAlertImpl : function
                ANPlatformPathToURL : function
                ANSMBURLToPlatformPath : function
                SplitAddrs : function
                CBTrustPropagateWiz : function
                CBCreateStepNavElements : function
                CBStartWizStep : function
                CBRunSimpleWiz : function
                CBStartWizStepNew : function
                CBRunSimpleWizNew : function
                CBCreateInviteStepDescription : function
                CBCreateInviteStepDescriptionApproval : function
                CBCreateSendInvitationStepDescription : function
                IWBrowseDocStepCommitWork : function
                IWBrowseDoc : function
                IWBrowseAnyDoc : function
                IWUploadFileError_UniqueFilenameDialog : function
                getFS : function
                IWShowFileError : function
                IWShowLocalFolderError : function
                IWShowFolderError : function
                getnextnumber : function
                populateFilesAtDocCenter : function
                isValidSaveLocationAtDocCtr : function
                SilentDocCenterLogin : function
                longFileName : function
                getAsciiSafeDocName : function
                DistributionServerStepCommitWork : function
                RemoveWebdav : function
                IWDistributionServer : function
                IWERTCWelcome : function
                IWShowSharepointWorkspace : function
                IWNewInternalServer : function
                IWSubmitButton : function
                IWDistributeStepDescription : function
                IWSaveProfileStepDescription : function
                filterAddrs : function
                setDateAndTime : function
                IWEmailStepDescription : function
                CBCreateGettingStartedStepDescription : function
                CBSharedReviewInviteReviewers : function
                IWSharedReviewDocCenterServicesDialog : function
                IWSharedReviewDocCenterLogin : function
                IWSharedReviewDocCenterEligibilityErrorDialog : function
                IWSharedReviewDocCenterCreateID : function
                IWSharedReviewDocCenterCreateConfirm : function
                CBSharedReviewDistributeStepDescription : function
                CBSharedReviewComplete : function
                CBFormDistributionEmailComplete : function
                CBFormDistributionComplete : function
                CBSharedReviewSelectServerTypeDescription : function
                CBSharedReviewConfigureServerStepDescription : function
                getFolderNameRemovedPath : function
                CBSharedReviewStatusDialog : function
                ANIdentityDialog : function
                ANValidateIdentity : function
                IWIdentityDialog : function
                CBSharedReviewSecurityDialog : function
                CBSharedReviewIfOfflineDialog : function
                CBSharedReviewCloseDialog : function
                CBCreateUploadStepDescription : function
                CBRunEmailReviewWizard : function
                CBRunEmailApprovalWizard : function
                CBRunBBRReviewWizard : function
                CBRunSharedReviewWizard : function
                CBRunFormDistributionWizard : function
                CBRunShareFileWizard : function
                CBRunERTCWizard : function
                CBEncodeURL : function
                CBFreezeFunc : function
                ANSendForSharedReview : function
                ANRunSharedReviewEmailStep : function
                ANSendForFormDistribution : function
                CBRunFormDistributionWizardEmail : function
                IWUploadFileFailedDialog : function
                IWShareFileConfirmDialog : function
                ANShareFile : function
                CBShareFileComplete : function
                ANDocCenterLogin : function
                ANDocCenterLoginForAddReviewers : function
                ANDocCenterSignup : function
                ANERTC : function
                CBBBRInit : function
                CBBBRInvite : function
                CBRunReturnResponseDialog : function
                CBRunReviewOptionsDialog : function
                CBRunApproveDialog : function
                InitAnWizard : function
                ScriptBridgeUtils : object
                DynamicAnnotStore : function
                SOAPMessageStyle : object
                SOAPVersion : object
                StreamDigest : object
                ServiceDiscovery : object
                SOAPRequestStyle : object
                event : object
                i : string
                • 5. Re: Trusted function throwing exceptions when called initially but work afterwards
                  This output is correct. You should contact the provider of the plugin.
                  • 6. Re: Trusted function throwing exceptions when called initially but work afterwards
                    I am attempting to fix some bugs on the existing plugin, the author cannot be reached anymore.
                    The issue I'm having is that a trusted function that is seemingly being called in a correct manner throws an exception initially but the very same call a second time round throws no exceptions at all...
                    Here is a sample of the code that throws the exception:
                    var btnOpenRubric = aNewDoc.addField("btnOpenRubric", "button", 0, [5, 5, 70, 30]);
                    btnOpenRubric.buttonSetCaption("Open Rubric");
                    btnOpenRubric.setAction("MouseUp", "openRubricForMarking(aNewDoc)");
                    btnOpenRubric.borderStyle = "beveled";
                    btnOpenRubric.highlight = "push";
                    btnOpenRubric.lineWidth = 2;
                    • 7. Re: Trusted function throwing exceptions when called initially but work afterwards
                      For the borderStyle you must use the keyword border.b. For highlight you must use highlight.p.
                      All is documented in the Acrobat JavaScript Reference.
                      • 8. Re: Trusted function throwing exceptions when called initially but work afterwards
                        I've looked in the reference docs and I couldn't find anything that would explain why the first call breaks(still creates the button) and the second doesn't. I'll just have to go over them again and continue to debug. Thanks for your help.
                        • 10. Re: Trusted function throwing exceptions when called initially but work afterwards
                          Thanks for putting me on the right track, I was able to determine that the plugins config file (config.js) needed to be renamed and now all the objects are being initialized without any exceptions. Thanks.
