4 Replies Latest reply on Jan 12, 2017 2:00 PM by kevinq19750741
    cordova-plugin-geofence error on ios
    stefanot77493002
      I've added this plugin but I receive error after build.
      In my config.xml
      <plugin name="cordova-plugin-geofence" spec="https://github.com/cowbell/cordova-plugin-geofence.git" />
      Anyone knows how can I fix it?
        • 1. Re: cordova-plugin-geofence error on ios
          VectorP Level 4
          Well, have a look at the docs here:
          GitHub - cowbell/cordova-plugin-geofence: Geofencing plugin for cordova
          At the top, it contains an icon, saying that Android Builds are failing.
          In the docs text, it says that the only OS it should fully support is....Android.
          So, if everything is true what is being written there, I wouldn't expect much, anyway.
          Having said that, what is the error, per
          • 2. Re: cordova-plugin-geofence error on ios
            stefanot77493002 Level 1
            This is the log where there are errors:
            CompileSwift normal arm64 /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/GeofencePlugin.swi ft
              cd /tmp/gimlet/2065222/project
              /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/sw ift -frontend -c -primary-file /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/GeofencePlugin.swi ft /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/SwiftData.swift /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/SwiftyJson.swift -target arm64-apple-ios7.0 -Xllvm -aarch64-use-tbi -enable-objc-interop -sdk /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS10.1.sdk -I /tmp/gimlet/2065222/project/build -F /tmp/gimlet/2065222/project/build -g -import-objc-header /tmp/gimlet/2065222/project/Ethiconomy/Bridging-Header.h -serialize-debugging-options -Xcc -I/tmp/gimlet/2065222/project/build/Ethiconomy.build/Release-iphoneos/Ethiconomy.build/sw ift-overrides.hmap -Xcc -iquote -Xcc /tmp/gimlet/2065222/project/build/Ethiconomy.build/Release-iphoneos/Ethiconomy.build/Ethi conomy-generated-files.hmap -Xcc -I/tmp/gimlet/2065222/project/build/Ethiconomy.build/Release-iphoneos/Ethiconomy.build/Et hiconomy-own-target-headers.hmap -Xcc -I/tmp/gimlet/2065222/project/build/Ethiconomy.build/Release-iphoneos/Ethiconomy.build/Et hiconomy-all-target-headers.hmap -Xcc -iquote -Xcc /tmp/gimlet/2065222/project/build/Ethiconomy.build/Release-iphoneos/Ethiconomy.build/Ethi conomy-project-headers.hmap -Xcc -I/tmp/gimlet/2065222/project/build/include -Xcc -I/tmp/gimlet/2065222/project/build/usr/local/lib/include -Xcc -I/tmp/gimlet/2065222/project/build/UninstalledProducts/include -Xcc -I/tmp/gimlet/2065222/project/build/UninstalledProducts/iphoneos/include -Xcc -I/tmp/gimlet/2065222/project/build -Xcc -I/tmp/gimlet/2065222/project/build/Ethiconomy.build/Release-iphoneos/Ethiconomy.build/De rivedSources/arm64 -Xcc -I/tmp/gimlet/2065222/project/build/Ethiconomy.build/Release-iphoneos/Ethiconomy.build/De rivedSources -Xcc -working-directory/tmp/gimlet/2065222/project -emit-module-doc-path /tmp/gimlet/2065222/project/build/Ethiconomy.build/Release-iphoneos/Ethiconomy.build/Obje cts-normal/arm64/GeofencePlugin~partial.swiftdoc -O -module-name Ethiconomy -emit-module-path /tmp/gimlet/2065222/project/build/Ethiconomy.build/Release-iphoneos/Ethiconomy.build/Obje cts-normal/arm64/GeofencePlugin~partial.swiftmodule -serialize-diagnostics-path /tmp/gimlet/2065222/project/build/Ethiconomy.build/Release-iphoneos/Ethiconomy.build/Obje cts-normal/arm64/GeofencePlugin.dia -emit-dependencies-path /tmp/gimlet/2065222/project/build/Ethiconomy.build/Release-iphoneos/Ethiconomy.build/Obje cts-normal/arm64/GeofencePlugin.d -emit-reference-dependencies-path /tmp/gimlet/2065222/project/build/Ethiconomy.build/Release-iphoneos/Ethiconomy.build/Obje cts-normal/arm64/GeofencePlugin.swiftdeps -o /tmp/gimlet/2065222/project/build/Ethiconomy.build/Release-iphoneos/Ethiconomy.build/Obje cts-normal/arm64/GeofencePlugin.o
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/SwiftyJson.swift:18 1:39: error: '=' has been replaced with ':' in attribute arguments
              @available(*, unavailable, renamed="null")
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/SwiftyJson.swift:89 7:35: error: expected ',' joining parts of a multi-clause condition
              if let errorValue = error where errorValue.code == ErrorNotExist{
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/SwiftData.swift:161 2:21: error: 'SQLiteDB' is inaccessible due to 'private' protection level
            extension SwiftData.SQLiteDB {
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/SwiftData.swift:103 6:19: note: type declared here
              private class SQLiteDB {
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/SwiftData.swift:183 1:21: error: 'SQLiteDB' is inaccessible due to 'private' protection level
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/SwiftData.swift:197 1:21: error: 'SDError' is inaccessible due to 'private' protection level
            extension SwiftData.SDError {
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/SwiftData.swift:160 3:20: note: type declared here
              private struct SDError {
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/SwiftyJson.swift:27 4:26: error: 'ForwardIndexType' has been renamed to 'Comparable'
            public struct JSONIndex: ForwardIndexType, _Incrementable, Equatable, Comparable {
              Comparable
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/SwiftyJson.swift:65 9:23: error: no type named 'Printable' in module 'Swift'
            extension JSON: Swift.Printable, Swift.DebugPrintable {
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/SwiftyJson.swift:65 9:40: error: no type named 'DebugPrintable' in module 'Swift'
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/SwiftyJson.swift:76 0:1: error: inheritance from non-protocol type 'BooleanType' (aka 'Bool')
            extension JSON: Swift.BooleanType {
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/GeofencePlugin.swif t:30:20: error: 'DISPATCH_QUEUE_PRIORITY_DEFAULT' has been renamed to 'DispatchQueue.GlobalQueuePriority.default'
              let priority = DISPATCH_QUEUE_PRIORITY_DEFAULT
            Dispatch.DISPATCH_QUEUE_PRIORITY_DEFAULT:2:12: note: 'DISPATCH_QUEUE_PRIORITY_DEFAULT' has been explicitly marked unavailable here
            public var DISPATCH_QUEUE_PRIORITY_DEFAULT: Int { get }
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/GeofencePlugin.swif t:185:20: error: 'DISPATCH_QUEUE_PRIORITY_DEFAULT' has been renamed to 'DispatchQueue.GlobalQueuePriority.default'
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/GeofencePlugin.swif t:352:10: warning: instance method 'locationManager(manager:didUpdateLocations:)' nearly matches optional requirement 'locationManager(_:didUpdateLocations:)' of protocol 'CLLocationManagerDelegate'
              func locationManager(manager: CLLocationManager, didUpdateLocations locations: [CLLocation]) {
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/GeofencePlugin.swif t:352:10: note: rename to 'locationManager(_:didUpdateLocations:)' to satisfy this requirement
              _
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/GeofencePlugin.swif t:352:10: note: move 'locationManager(manager:didUpdateLocations:)' to an extension to silence this warning
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/GeofencePlugin.swif t:352:10: note: make 'locationManager(manager:didUpdateLocations:)' private to silence this warning
              private
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/GeofencePlugin.swif t:352:10: note: add '@nonobjc' to silence this warning
              @nonobjc
            CoreLocation.CLLocationManagerDelegate:5:26: note: requirement 'locationManager(_:didUpdateLocations:)' declared here
              optional public func locationManager(_ manager: CLLocationManager, didUpdateLocations locations: [CLLocation])
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/GeofencePlugin.swif t:356:10: warning: instance method 'locationManager(manager:didFailWithError:)' nearly matches optional requirement 'locationManager(_:didFailWithError:)' of protocol 'CLLocationManagerDelegate'
              func locationManager(manager: CLLocationManager, didFailWithError error: NSError) {
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/GeofencePlugin.swif t:356:10: note: candidate has non-matching type '(CLLocationManager, NSError) -> ()'
              Error
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/GeofencePlugin.swif t:356:10: note: move 'locationManager(manager:didFailWithError:)' to an extension to silence this warning
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/GeofencePlugin.swif t:356:10: note: make 'locationManager(manager:didFailWithError:)' private to silence this warning
              private
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/GeofencePlugin.swif t:356:10: note: add '@nonobjc' to silence this warning
              @nonobjc
            CoreLocation.CLLocationManagerDelegate:21:26: note: requirement 'locationManager(_:didFailWithError:)' declared here
              optional public func locationManager(_ manager: CLLocationManager, didFailWithError error: Error)
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/GeofencePlugin.swif t:360:10: warning: instance method 'locationManager(manager:didFinishDeferredUpdatesWithError:)' nearly matches optional requirement 'locationManager(_:didFinishDeferredUpdatesWithError:)' of protocol 'CLLocationManagerDelegate'
              func locationManager(manager: CLLocationManager, didFinishDeferredUpdatesWithError error: NSError?) {
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/GeofencePlugin.swif t:360:10: note: candidate has non-matching type '(CLLocationManager, NSError?) -> ()'
              Error?
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/GeofencePlugin.swif t:360:10: note: move 'locationManager(manager:didFinishDeferredUpdatesWithError:)' to an extension to silence this warning
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/GeofencePlugin.swif t:360:10: note: make 'locationManager(manager:didFinishDeferredUpdatesWithError:)' private to silence this warning
              private
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/GeofencePlugin.swif t:360:10: note: add '@nonobjc' to silence this warning
              @nonobjc
            CoreLocation.CLLocationManagerDelegate:33:26: note: requirement 'locationManager(_:didFinishDeferredUpdatesWithError:)' declared here
              optional public func locationManager(_ manager: CLLocationManager, didFinishDeferredUpdatesWithError error: Error?)
            /tmp/gimlet/2065222/project/Ethiconomy/Plugins/cordova-plugin-geofence/GeofencePlugin.swif t:364:10: warning: instance method 'locationManager(manager:didEnterRegion:)' nearly matches optional requirement 'locationManager(_:didEnterRegion:)' of protocol 'CLLocationManagerDelegate'
            • 3. Re: cordova-plugin-geofence error on ios
              VectorP Level 4
              These appear to be syntax error messages from within the plugin.
              I would recommend posting an issue at the plugin's Github page, or contacting the plugin author directly.
              • 4. Re: cordova-plugin-geofence error on ios
                kevinq19750741
                the docs reference the UseLegacySwift pref, but it does nothing for me.
                the swift-version pref got it going though...
                <preference name="swift-version" value="2.3" />
                <preference name="UseLegacySwiftLanguageVersion" value="true" />
