21 Replies Latest reply on Mar 1, 2017 8:11 AM by stane6230630
    InDesign Cc 2017 crashes while packaging
    dianab64867717
      New Mac Pro laptops. Running Sierra. All software is update for both myself and the other designer. Crashes for both of us. Any idea why? Suggestions on how to fix?
      Thanks!
      D
        • 1. Re: InDesign Cc 2017 crashes while packaging
          sanyamt Adobe Employee
          Can you please send the document to santalwa@adobe.com
          Regards
          Sanyam Talwar
          • 2. Re: InDesign Cc 2017 crashes while packaging
            dianab64867717 Level 1
            Hi Sanyam!
            It doesn’t matter the file. It happens on all of them for both of us.
            Diana Lynn Boyle
            Senior Graphic Communication Specialist
            [personal information removed by moderator]
            • 3. Re: InDesign Cc 2017 crashes while packaging
              I am not able to reproduce the issue with any file. Please share few documents to investigate the issue.
              Regards
              Sanyam Talwar
              • 4. Re: InDesign Cc 2017 crashes while packaging
                HI Sanyam,
                Do you work for Adobe Tech Support?
                Diana Lynn Boyle
                • 5. Re: InDesign Cc 2017 crashes while packaging
                  BarbBinder Adobe Community Professional
                  Diana—you can see who works for Adobe by their badges. Sanyamt has a staff badge, so is a verified employee.
                  • 6. Re: InDesign Cc 2017 crashes while packaging
                    Jeff Witchel, ACI Adobe Community Professional
                    Do you have any images in the document that include symbols that can cause problems in Mac file names?
                    OS X: Cross-platform filename best practices and conventions - Apple Support
                    • 7. Re: InDesign Cc 2017 crashes while packaging
                      I am part of InDesign Engineering team
                      • 8. Re: InDesign Cc 2017 crashes while packaging
                        mattw60028661
                        Hi Sanyam,
                        Both myself and team are having the same issue where InDesign CC17 is crashing upon completing 'Packaging' a file/folder.
                        Please see image attached for the dialog box when this happens. I have a team all running Sierra 10.12.3, all INDD CC17 (latest). I also have the text error report if you'd like me to send to you. The crash occurs constantly and is not dependant on the type of file setup/open.
                        Look forward to your thoughts, suggestions on how best to resolve.
                        Cheers
                        Matt
                        • 9. Re: InDesign Cc 2017 crashes while packaging
                          Are you using an external plugin? Also can you share the options selected while packaging? Also, Try if you could export idml seperately.
                          Regards
                          Sanyam Talwar
                          • 10. Re: InDesign Cc 2017 crashes while packaging
                            mattw60028661 Level 1
                            Hi Sanyam,
                            No external plugins are running.
                            I can 'Export' or 'Save as' an IDML file without any issues.
                            Attached is the packaging options.
                            Cheers
                            Matt
                            • 11. Re: InDesign Cc 2017 crashes while packaging
                              Send me the text error report. Also, we are aware of a crash in 12.0.0.81. lease try the steps mentioned at this troubleshooting page https://helpx.adobe.com/indesign/kb/crash-hyperlinks-panel-quick-apply.html to resolve your issue, if still facing.
                              Regards
                              Sanyam Talwar
                              • 12. Re: InDesign Cc 2017 crashes while packaging
                                stane6230630
                                Paste in Pastebin.com - #1 paste tool since 2002!  Then post a link.
                                Don't paste here. It makes it impossible to read the thread. [ Report removed by moderator]
                                • 13. Re: InDesign Cc 2017 crashes while packaging
                                  Hi there,
                                  The issue still persists.
                                  See my pastern.com link (Process: Adobe InDesign CC 2017 [34555] Path: /A - Pastebin.com ) for the error log.
                                  Look forward to your thoughts.
                                  Cheers
                                  Matt
                                  • 14. Re: InDesign Cc 2017 crashes while packaging
                                    Can you please try to package after disabling extensis?
                                    Regards
                                    Sanyam Talwar
                                    • 15. Re: InDesign Cc 2017 crashes while packaging
                                      Macawesome3278829 Level 1
                                      Cause of Problems with InDesign because of Strange Filenames when Making a Package.
                                      Any Filename that uses ( ) / \ characters (and there maybe others) that will cause the Package to Fail.
                                      I used to have a screenshot utility that saved filenames with: “Screenshot (02-20-2017-1802) ” This will not work when making a Package!  Rename to: Screenshot_02-20-2017-1802
                                      Also avoid Spaces at the Beginning of FileNames... Slashes / are subdirectories or indicate pathnames on PC or Mac so don't use them either... Underscore _ Spaces or Periods . or Hyphens - are okay.
                                      • 16. Re: InDesign Cc 2017 crashes while packaging
                                        shawnb832067
                                        Hi.
                                        I was reading the responses to  the packaging issue with InDesign 2017 as we have been facing the same issue with our Graphic Design team. Has this issue been escalated to the Engineering team? We have three folks who are all experiencing the same issue. We are running InDesign 2017 on Windows 10 not that it seems to be a Windows issue as Mac users are experiencing the same problem. Looking for an answer to this issue as well. Shawn
                                        • 17. Re: InDesign Cc 2017 crashes while packaging
                                          Steve Werner Adobe Community Professional & MVP
                                          Sanyam Talwar is on the InDesign Engineering team. They are probably in the process of resolving the problem. If you're lucky it might be fixed with the next update.
                                          • 18. Re: InDesign Cc 2017 crashes while packaging
                                            stevet94638453
                                            I had the same issue, I found deleting the 'ExtensisFontManagementIDCC2017.InDesignPlugin' from the application plugin folder worked but you lose the auto activation of fonts through suitcase.
                                            • 19. Re: InDesign Cc 2017 crashes while packaging
                                              Hi Sanyam,
                                              No change when Extensis is disable.
                                              When i copy my art folder from network drive to local drive and then open my INDD doc and subsequently perform a 'Package' it completes without crashing. Thoughts?
                                              Matt
                                              • 20. Re: InDesign Cc 2017 crashes while packaging
                                                stane6230630 Level 1
                                                FYI, I packaged one file today over our local server network with Suitcase disabled and NO crash
                                                Following that I packaged a second very similar file from the same design series and I re-enabled Suitcase and a crash occurred.
                                                • 21. Re: InDesign Cc 2017 crashes while packaging
                                                  Hi Sanyam,
                                                  FYI we just attempted packaging two other files with Suitcases turned OFF.  Both of them crashed today. The files did packup up correctly, however, as usual InDesign crashed at the end. Both attempts were over a very simple, but robust local server.
                                                  Here’s the report:
                                                  Path:                  /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Adobe InDesign CC 2017
                                                  Identifier:            com.adobe.InDesign
                                                  Version:               12.0.0.81 (12000)
                                                  Code Type:             X86-64 (Native)
                                                  Parent Process:        ???
                                                  Responsible:           Adobe InDesign CC 2017
                                                  User ID:               503
                                                  Date/Time:             2017-03-01 11:04:22.116 -0500
                                                  OS Version:            Mac OS X 10.12.3 (16D32)
                                                  Report Version:        12
                                                  Anonymous UUID:        FF21D560-8EC0-2480-FFF5-04F5672A1142
                                                  Sleep/Wake UUID:       6FB58576-8112-4B9F-9A91-F894E31A3FF9
                                                  Time Awake Since Boot: 68000 seconds
                                                  Time Since Wake:       6700 seconds
                                                  System Integrity Protection: enabled
                                                  Crashed Thread:        0  Main Thread  Dispatch queue: com.apple.main-thread
                                                  Exception Type:        EXC_CRASH (SIGABRT)
                                                  Exception Codes:       0x0000000000000000, 0x0000000000000000
                                                  Exception Note:        EXC_CORPSE_NOTIFY
                                                  Application Specific Information:
                                                  terminating with uncaught exception of type XMP_Error
                                                  abort() called
                                                  Thread 0 Crashed:: Main Thread  Dispatch queue: com.apple.main-thread
                                                  0   libsystem_kernel.dylib             0x00007fffb2da7dd6 __pthread_kill + 10
                                                  1   libsystem_pthread.dylib            0x00007fffb2e93787 pthread_kill + 90
                                                  2   libsystem_c.dylib                  0x00007fffb2d0d420 abort + 129
                                                  3   libc++abi.dylib                    0x00007fffb186a85a abort_message + 266
                                                  4   libc++abi.dylib                    0x00007fffb188fc4f default_terminate_handler() + 267
                                                  5   libobjc.A.dylib                    0x00007fffb2399ba3 objcterminate() + 124
                                                  6   libc++abi.dylib                    0x00007fffb188cd69 std::__terminate(void (*)()) + 8
                                                  7   libc++abi.dylib                    0x00007fffb188c9f2 __cxa_rethrow + 99
                                                  8   libobjc.A.dylib                    0x00007fffb2397f07 objc_exception_rethrow + 40
                                                  9   com.apple.AppKit                   0x00007fff9b3fdba6 -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 166
                                                  10  libsystem_trace.dylib              0x00007fffb2eabc3d osactivity_initiate + 61
                                                  11  com.apple.AppKit                   0x00007fff9b4870f1 -[NSMenu performActionForItemAtIndex:] + 121
                                                  12  com.adobe.dvaui.framework          0x000000010e4891e4 dvaui::utility::OS_Menu_MAC::DoPopupMenu(dvaui::utility::OS_Menu_MAC&, dvaui::ui::UI_Node const*, dvacore::geom::RectT const&, bool, bool) + 1700
                                                  13  com.apple.AppKit                   0x00007fff9b487068 -[NSMenu _internalPerformActionForItemAtIndex:] + 94
                                                  14  com.apple.AppKit                   0x00007fff9b486e95 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 107
                                                  15  com.apple.AppKit                   0x00007fff9b33e100 NSSLMMenuEventHandler + 986
                                                  16  com.apple.HIToolbox                0x00007fff9cbdfb15 DispatchEventToHandlers(EventTargetRec, OpaqueEventRef, HandlerCallRec*) + 1708
                                                  17  com.apple.HIToolbox                0x00007fff9cbded86 SendEventToEventTargetInternal(OpaqueEventRef, OpaqueEventTargetRef, HandlerCallRec*) + 428
                                                  18  com.apple.HIToolbox                0x00007fff9cbf48b4 SendEventToEventTarget + 40
                                                  19  com.apple.HIToolbox                0x00007fff9cc40d36 SendHICommandEvent(unsigned int, HICommand const, unsigned int, unsigned int, unsigned char, void const, OpaqueEventTargetRef, OpaqueEventTargetRef, OpaqueEventRef**) + 411
                                                  20  com.apple.HIToolbox                0x00007fff9cc6c34b SendMenuCommandWithContextAndModifiers + 59
                                                  21  com.apple.HIToolbox                0x00007fff9cc6c2fa SendMenuItemSelectedEvent + 188
                                                  22  com.apple.HIToolbox                0x00007fff9cc6c1cd FinishMenuSelection(SelectionData, MenuResult, MenuResult*) + 96
                                                  23  com.apple.HIToolbox                0x00007fff9cc6cc07 MenuSelectCore(MenuData, Point, double, unsigned int, OpaqueMenuRef, unsigned short) + 702
                                                  24  com.apple.HIToolbox                0x00007fff9cc6c8b6 _HandleMenuSelection2 + 460
                                                  25  com.apple.AppKit                   0x00007fff9b32deca _NSHandleCarbonMenuEvent + 239
                                                  26  com.apple.AppKit                   0x00007fff9b5a7dbe _DPSEventHandledByCarbon + 54
                                                  27  com.apple.AppKit                   0x00007fff9b927642 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 956
                                                  28  com.apple.AppKit                   0x00007fff9b1a1f35 -[NSApplication run] + 926
                                                  29  com.adobe.exo.framework            0x00000001101fc738 exo::app::OS_AppBase::RunEventLoop() + 56
                                                  30  com.adobe.InDesign.AppFramework     0x00000001172a74b3 0x11714d000 + 1418419
                                                  31  com.adobe.InDesign.AppFramework     0x00000001172a610a 0x11714d000 + 1413386
                                                  32  com.adobe.InDesign                 0x000000010d5a0961 main + 513
                                                  33  libdyld.dylib                      0x00007fffb2c79255 start + 1
                                                  Thread 1:: com.apple.CFSocket.private
                                                  0   libsystem_kernel.dylib             0x00007fffb2da7f4a __select + 10
                                                  1   com.apple.CoreFoundation           0x00007fff9d6b9239 __CFSocketManager + 729
                                                  2   libsystem_pthread.dylib            0x00007fffb2e90aab pthreadbody + 180
                                                  3   libsystem_pthread.dylib            0x00007fffb2e909f7 pthreadstart + 286
                                                  4   libsystem_pthread.dylib            0x00007fffb2e901fd thread_start + 13
                                                  Thread 2:: IPCClient rcvr: FMClient.503.6751.140736342004672.1
                                                  1   com.extensis.FontManagement.plugin-interface     0x000000011d5fa195 GIPCReceiver::OSWaitForData() + 3929
                                                  2   com.extensis.FontManagement.plugin-interface     0x000000011d5e9e9d GIPCClient::ReceiverThreadProc(GThread*) + 1103
                                                  3   com.extensis.FontManagement.plugin-interface     0x000000011d612e88 GThread::PthreadInternal(void*) + 256
                                                  4   libsystem_pthread.dylib            0x00007fffb2e90aab pthreadbody + 180
                                                  5   libsystem_pthread.dylib            0x00007fffb2e909f7 pthreadstart + 286
                                                  6   libsystem_pthread.dylib            0x00007fffb2e901fd thread_start + 13
                                                  Thread 3:: Agent IF Message Handler
                                                  0   libsystem_kernel.dylib             0x00007fffb2da7c86 __psynch_cvwait + 10
                                                  1   libsystem_pthread.dylib            0x00007fffb2e9196a pthreadcond_wait + 712
                                                  2   com.extensis.FontManagement.plugin-interface     0x000000011d608d3a GSemaphore::TimedWait(unsigned int) + 90
                                                  3   com.extensis.FontManagement.plugin-interface     0x000000011d5eec98 GIPCClient::GIPCMTDataAccumulator::WaitForData(unsigned int, std::vector&, bool) + 38
                                                  4   com.extensis.FontManagement.plugin-interface     0x000000011d5806f6 GAgentIFMessageHandlerThread::RunMessageHandlerThread() + 112
                                                  5   com.extensis.FontManagement.plugin-interface     0x000000011d580678 GAgentIFMessageHandlerThread::AgentIFMessageHandlerThreadFunc(GThread*) + 40
                                                  6   com.extensis.FontManagement.plugin-interface     0x000000011d612e88 GThread::PthreadInternal(void*) + 256
                                                  7   libsystem_pthread.dylib            0x00007fffb2e90aab pthreadbody + 180
                                                  8   libsystem_pthread.dylib            0x00007fffb2e909f7 pthreadstart + 286
                                                  9   libsystem_pthread.dylib            0x00007fffb2e901fd thread_start + 13
                                                  Thread 4:: com.apple.NSURLConnectionLoader
                                                  0   libsystem_kernel.dylib             0x00007fffb2da038a mach_msg_trap + 10
                                                  1   libsystem_kernel.dylib             0x00007fffb2d9f7d7 mach_msg + 55
                                                  2   com.apple.CoreFoundation           0x00007fff9d67de84 __CFRunLoopServiceMachPort + 212
                                                  3   com.apple.CoreFoundation           0x00007fff9d67d301 __CFRunLoopRun + 1361
                                                  4   com.apple.CoreFoundation           0x00007fff9d67cb54 CFRunLoopRunSpecific + 420
                                                  5   com.apple.CFNetwork                0x00007fff9c7eb680 + + 313
                                                  6   com.apple.Foundation               0x00007fff9f0bfc6d __NSThread__start__ + 1243
                                                  Thread 5:: VulcanMsgRecv
                                                  0   libsystem_kernel.dylib             0x00007fffb2da7e8a __recvfrom + 10
                                                  1   VulcanMessage5.dylib               0x000000011237c308 0x11235e000 + 123656
                                                  2   VulcanMessage5.dylib               0x000000011237b6cc 0x11235e000 + 120524
                                                  3   VulcanMessage5.dylib               0x000000011237a9c4 0x11235e000 + 117188
                                                  4   VulcanMessage5.dylib               0x000000011237a888 0x11235e000 + 116872
                                                  5   VulcanMessage5.dylib               0x00000001123754c7 0x11235e000 + 95431
                                                  6   VulcanMessage5.dylib               0x0000000112375f56 0x11235e000 + 98134
                                                  7   VulcanMessage5.dylib               0x00000001123758ef 0x11235e000 + 96495
                                                  8   VulcanMessage5.dylib               0x0000000112379974 0x11235e000 + 113012
                                                  9   VulcanMessage5.dylib               0x00000001123793cd 0x11235e000 + 111565
                                                  10  VulcanMessage5.dylib               0x00000001123790ba 0x11235e000 + 110778
                                                  11  VulcanMessage5.dylib               0x000000011237900d 0x11235e000 + 110605
                                                  12  VulcanMessage5.dylib               0x000000011236c848 0x11235e000 + 59464
                                                  13  VulcanMessage5.dylib               0x000000011236ba86 0x11235e000 + 55942
                                                  14  VulcanMessage5.dylib               0x000000011237a20c 0x11235e000 + 115212
                                                  15  VulcanMessage5.dylib               0x000000011237c109 0x11235e000 + 123145
                                                  16  libsystem_pthread.dylib            0x00007fffb2e90aab pthreadbody + 180
                                                  17  libsystem_pthread.dylib            0x00007fffb2e909f7 pthreadstart + 286
                                                  18  libsystem_pthread.dylib            0x00007fffb2e901fd thread_start + 13
                                                  Thread 6:
                                                  2   com.adobe.InDesign.AppFramework     0x00000001172913c1 0x11714d000 + 1328065
                                                  3   com.adobe.InDesign.AppFramework     0x0000000117290928 0x11714d000 + 1325352
                                                  4   com.adobe.InDesign.AppFramework     0x000000011728dca5 0x11714d000 + 1313957
                                                  5   com.adobe.InDesign.AppFramework     0x00000001172936b9 0x11714d000 + 1337017
                                                  6   com.adobe.boost_threads.framework     0x000000010ea2a41a boost::thread::start_thread_noexcept() + 410
                                                  Thread 7:
                                                  Thread 8:
                                                  0   libsystem_kernel.dylib             0x00007fffb2da7fda __semwait_signal + 10
                                                  1   libsystem_c.dylib                  0x00007fffb2d2eb72 nanosleep + 199
                                                  2   com.adobe.InDesign.Support for JavaScript     0x000000012290a498 0x1228b2000 + 361624
                                                  3   com.adobe.InDesign.Support for JavaScript     0x00000001228f164c 0x1228b2000 + 259660
                                                  4   com.adobe.InDesign.Support for JavaScript     0x000000012290a0e1 0x1228b2000 + 360673
                                                  5   libsystem_pthread.dylib            0x00007fffb2e90aab pthreadbody + 180
                                                  6   libsystem_pthread.dylib            0x00007fffb2e909f7 pthreadstart + 286
                                                  7   libsystem_pthread.dylib            0x00007fffb2e901fd thread_start + 13
                                                  Thread 9:
                                                  5   com.apple.Foundation               0x00007fff9f1c32c1 -[NSConnection run] + 144
                                                  Thread 10:: CEPMonitorThread
                                                  5   com.apple.Foundation               0x00007fff9f1551be -[NSConcreteTask waitUntilExit] + 213
                                                  6   com.adobe.PlugPlugOwl              0x00000001105faa2b 0x110561000 + 629291
                                                  7   com.apple.Foundation               0x00007fff9f0bfc6d __NSThread__start__ + 1243
                                                  8   libsystem_pthread.dylib            0x00007fffb2e90aab pthreadbody + 180
                                                  9   libsystem_pthread.dylib            0x00007fffb2e909f7 pthreadstart + 286
                                                  10  libsystem_pthread.dylib            0x00007fffb2e901fd thread_start + 13
                                                  Thread 11:: MPSupport Worker
                                                  2   MultiProcessor Support             0x00000001334ff6fb 0x1334b8000 + 292603
                                                  3   MultiProcessor Support             0x00000001334ff61b 0x1334b8000 + 292379
                                                  4   MultiProcessor Support             0x0000000133521bed 0x1334b8000 + 433133
                                                  Thread 12:: MPSupport Worker
                                                  Thread 13:: MPSupport Worker
                                                  Thread 14:
                                                  0   libsystem_kernel.dylib             0x00007fffb2da03c6 semaphore_wait_trap + 10
                                                  1   libtbb.dylib                       0x0000000110835d99 tbb::internal::concurrent_queue_base_v3::internal_pop(void*) + 537
                                                  2   com.adobe.InDesign.Layout UI       0x000000011a3dfe49 0x11a2be000 + 1187401
                                                  3   com.adobe.boost_threads.framework     0x000000010ea2a41a boost::thread::start_thread_noexcept() + 410
                                                  Thread 15:
                                                  Thread 16:
                                                  Thread 17:
                                                  Thread 18:: CEPMonitorThread
                                                  Thread 19:
                                                  Thread 20:: CEPMonitorThread
                                                  Thread 21:
                                                  3   com.adobe.InDesign.AppFramework     0x00000001172909ef 0x11714d000 + 1325551
                                                  Thread 22:
                                                  Thread 23:
                                                  Thread 24:: com.apple.NSEventThread
                                                  5   com.apple.AppKit                   0x00007fff9b2faa62 _NSEventThread + 205
                                                  Thread 25:
                                                  2   com.adobe.headlights.LogSessionFramework     0x000000011b84cccc 0x11b6f4000 + 1412300
                                                  3   com.adobe.headlights.LogSessionFramework     0x000000011b84b5ef 0x11b6f4000 + 1406447
                                                  4   com.adobe.headlights.LogSessionFramework     0x000000011b7f9059 0x11b6f4000 + 1069145
                                                  5   com.adobe.headlights.LogSessionFramework     0x000000011b7c7cfb 0x11b6f4000 + 867579
                                                  6   com.adobe.headlights.LogSessionFramework     0x000000011b84a969 0x11b6f4000 + 1403241
                                                  Thread 26:
                                                  Thread 27:
                                                  2   DataBaseLib.dylib                  0x00000001123ecad3 0x1123b4000 + 232147
                                                  Thread 28:
                                                  Thread 29:
                                                  Thread 30:
                                                  Thread 31:
                                                  Thread 32:
                                                  Thread 33:
                                                  Thread 34:
                                                  0   libsystem_kernel.dylib             0x00007fffb2da84e2 __workq_kernreturn + 10
                                                  1   libsystem_pthread.dylib            0x00007fffb2e905fe pthreadwqthread + 1023
                                                  2   libsystem_pthread.dylib            0x00007fffb2e901ed start_wqthread + 13
                                                  Thread 35:
                                                  0   libsystem_pthread.dylib            0x00007fffb2e901e0 start_wqthread + 0
                                                  1   ???                                0x00007fffb851bd80 OBJC_METACLASS_$__NSChineseBigramKeySet_SKS + 40
                                                  Thread 36:: IPCDataHandler for rcvr: FMClient.503.6751.140736342004672.1
                                                  1   com.extensis.FontManagement.plugin-interface     0x000000011d5f54d7 -[IPCDataHandler handleDataFromSocket:] + 1610
                                                  2   com.apple.Foundation               0x00007fff9f0bfc6d __NSThread__start__ + 1243
                                                  3   libsystem_pthread.dylib            0x00007fffb2e90aab pthreadbody + 180
                                                  4   libsystem_pthread.dylib            0x00007fffb2e909f7 pthreadstart + 286
                                                  5   libsystem_pthread.dylib            0x00007fffb2e901fd thread_start + 13
                                                  Thread 37:
                                                  1   libsystem_pthread.dylib            0x00007fffb2e90791 pthreadwqthread + 1426
                                                  Thread 38:
                                                  Thread 39:
                                                  1   ???                                0x000000000000a513 0 + 42259
                                                  Thread 40:
                                                  Thread 41:
                                                  Thread 0 crashed with X86 Thread State (64-bit):
                                                    rax: 0x0000000000000000  rbx: 0x0000000000000006  rcx: 0x00007fff5265f418  rdx: 0x0000000000000000
                                                    rdi: 0x0000000000000307  rsi: 0x0000000000000006  rbp: 0x00007fff5265f440  rsp: 0x00007fff5265f418
                                                     r8: 0x00007fffb2d36650   r9: 0x00007fffb2cf8a50  r10: 0x0000000008000000  r11: 0x0000000000000206
                                                    r12: 0x00007fff5265f5a0  r13: 0x0000000000000030  r14: 0x00007fffbbac13c0  r15: 0x0000000000000008
                                                    rip: 0x00007fffb2da7dd6  rfl: 0x0000000000000206  cr2: 0x00007fffbbaa3128
                                                  Logical CPU:     0
                                                  Error Code:      0x02000148
                                                  Trap Number:     133
                                                  Binary Images:
                                                         0x10d59f000 -        0x10d5a8ff7 +com.adobe.InDesign (12.0.0.81 - 12000) <7D9D89A7-7C4A-32A9-B36E-626242C10277> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Adobe InDesign CC 2017
                                                         0x10d5b2000 -        0x10d5b5fff +com.adobe.InDesign.InDesignModelAndUI (9.0 - 0) <06FAAAD4-669A-34EF-9365-7FB3F8FC95DE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/InDesignModelAndUI.framework/Versions/A/InDesignModelAndUI
                                                         0x10d5c2000 -        0x10d5ccff7 +com.adobe.coretech.adobesplashkit (AdobeSplashKit Version 1.0 - 1.0) <B55F1CEC-518C-3999-A4A9-23C883871DAE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeSplashKit.framework/Versions/A/AdobeSplashKit
                                                         0x10d5d9000 -        0x10d5e7ffb +ASLSupportLib.dylib (0) <B1F022D3-52B3-33AA-BF3B-B7A294D7A97C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/ASLSupportLib.dylib
                                                         0x10d5f6000 -        0x10d6ebffb +DV_WidgetBinLib.dylib (0) <56298D44-D873-3EE8-ABCF-2B078EA2E642> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/DV_WidgetBinLib.dylib
                                                         0x10d827000 -        0x10d867ff3 +TextPanelLib.dylib (0) <EC73B739-F83F-3BEF-AFF6-D93AFFEB3904> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/TextPanelLib.dylib
                                                         0x10d889000 -        0x10d9ceff3 +WidgetBinLib.dylib (0) <1159F2F7-9435-3116-A107-CE1CECE255BC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/WidgetBinLib.dylib
                                                         0x10da90000 -        0x10dc18ff7 +com.adobe.owl (AdobeOwl version 5.2.9 - 5.2.9) <A08490CC-75C3-35F0-A207-AE39CF56C78F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
                                                         0x10dc69000 -        0x10df7effb +com.adobe.dvacore.framework (10.0.0 - 10.0.0.0) <8BE548C6-CE6A-374B-A071-BCFF4B9A7E5F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                                                         0x10e062000 -        0x10e5f2ff3 +com.adobe.dvaui.framework (10.0.0 - 10.0.0.0) <0E15B253-AC76-337D-867B-FBE77959B683> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
                                                         0x10ea1d000 -        0x10ea1dff7 +com.adobe.InDesign.InDesignModel (9.0 - 0) <3ABCBBC9-5789-363A-A6D5-BB29AFBBAA47> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/InDesignModel.framework/Versions/A/InDesignModel
                                                         0x10ea28000 -        0x10ea36ff7 +com.adobe.boost_threads.framework (10.0.0 - 10.0.0.0) <B73D6065-556B-3AD6-900A-803D7BF1BDDB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                                                         0x10ea4a000 -        0x10ea4bffb +com.adobe.boost_system.framework (10.0.0 - 10.0.0.0) <27097AC9-14AD-3510-8BD6-6B69494489CA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                                                         0x10ea55000 -        0x10ea59fff +com.adobe.boost_date_time.framework (10.0.0 - 10.0.0.0) <D0154E96-3135-3A27-AA36-FF8E600FE2C3> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                                                         0x10ea64000 -        0x10ee81ff3 +PublicLib.dylib (0) <1AA372E7-3936-3A10-BE2A-5A73A31AE8B2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/PublicLib.dylib
                                                         0x10efd5000 -        0x10efd6fff +com.adobe.InDesign.Metadata Database Filter (12.0.0.81 - 0) <129ADE28-84B3-355D-949D-5C58B89DFCA2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Metadata Database Filter.InDesignPlugin/Metadata Database Filter
                                                         0x10efdc000 -        0x10efe7ffb +PMRuntime.dylib (0) <F704ADAD-42F1-3680-9F4A-7C0578EC3608> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/PMRuntime.dylib
                                                         0x10eff5000 -        0x10f009fff +com.adobe.AFL (AdobeAFL 3.0.0 - 3.0) <63034C19-9D73-37B9-8D6C-230270E2F172> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeAFL.framework/Versions/A/AdobeAFL
                                                         0x10f01f000 -        0x10f313fff +com.adobe.CoolType (AdobeCoolType 5.15.00.37194 - 5.15.00.37194) <342B9526-C99A-3A1C-B3B3-9D50B8CF30F7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                                                         0x10f361000 -        0x10f37dfff +com.adobe.BIB (AdobeBIB 1.2.03.36974 - 1.2.03.36974) <5B62D9F4-7012-3C7E-B821-31B38A101F3F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                                                         0x10f386000 -        0x10f4d2ffb +com.adobe.ACE (AdobeACE 2.20.02.36974 - 2.20.02.36974) <EC655948-66DE-39ED-9A50-424511FC81DC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                                                         0x10f4ec000 -        0x10fc8eff3 +com.adobe.AGM (AdobeAGM 4.30.60.1 - 4.30.60.1) <35BDB273-0D57-38FA-987A-A7D1CEA006FB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                                                         0x10fd49000 -        0x10fd7bfff +com.adobe.ARE (AdobeARE 1.5.02.36974 - 1.5.02.36974) <0272D45A-FB5C-3A86-ABAD-D1236768D51E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
                                                         0x10fd88000 -        0x10fdabffb +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <6FDFDB79-CE33-30EE-8056-D76B4D52B6EF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                                                         0x10fdb8000 -        0x11011efff +com.adobe.MPS (AdobeMPS 5.8.1.36881 - 5.8.1.36881) <B9EFAA03-C560-3B5C-A92C-ED156F669D0B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                                                         0x110196000 -        0x1101c7ff3 +com.adobe.dvaflashview.framework (10.0.0 - 10.0.0.0) <6A4CE2DA-0DE8-3097-BFA6-EB79B73669DB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
                                                         0x1101e3000 -        0x1101e3fff  com.apple.applescript.component (2.5 - 381) <3C5459D8-D1B0-3D43-AD6C-DB98FA75E758> /System/Library/Components/AppleScript.component/Contents/MacOS/AppleScript
                                                         0x1101e8000 -        0x1101ecff7 +com.adobe.ape.shim (3.4.0.29366 - 3.4.0.29366) <B9447EE8-6F91-9E85-C163-96600BF70764> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                                                         0x1101f4000 -        0x1102a6fff +com.adobe.exo.framework (10.0.0 - 10.0.0.0) <A906B7BA-818F-3E27-9721-5907919F4034> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/exo.framework/Versions/A/exo
                                                         0x110369000 -        0x110474ff7 +com.adobe.dvaworkspace.framework (10.0.0 - 10.0.0.0) <678A5E16-2CDC-330B-86DB-BCDEF76103F3> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
                                                         0x110561000 -        0x1107d7ff7 +com.adobe.PlugPlugOwl (7.0.0.59 - 7.0.0.59) <1A71FB55-00B7-3332-A7DF-27FC2A8D895D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
                                                         0x110834000 -        0x11086bfe7 +libtbb.dylib (0) <57385823-CF98-3366-B55F-B454BCC39B7A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/libtbb.dylib
                                                         0x1108ac000 -        0x1108cfff7 +libtbbmalloc.dylib (0) <2D49758A-80A5-33B2-AF4F-315DD0761657> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/libtbbmalloc.dylib
                                                         0x11090a000 -        0x11164ffff +com.adobe.ICUData (4.0 - 3.61) <8726D6A3-3921-3AB2-94D5-062E9EA297DB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
                                                         0x111667000 -        0x111781ff7 +com.adobe.ICUInternationalization (4.0 - 3.61) <36984DC1-7D78-3AB5-9891-CA6ACD116AEE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/ICUInternationalization.framework/Versions/4.0/ICUInternatio nalization
                                                         0x1117d8000 -        0x1118c9ff7 +com.adobe.ICUUnicode (4.0 - 3.61) <431F0368-6F63-3B0D-A215-D6866EEACA9A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
                                                         0x111903000 -        0x111a2dff7 +com.winsoft.wrservices (WRServices 12.2.0 - 12.2.0) <02E9EA6A-5D56-3BF4-AFA3-3CB90539226D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                                                         0x111a79000 -        0x111b7cfff +com.adobe.amtlib (10.0.0.47 - 10.0.0.47) <AD7B1E56-04A5-355A-AD70-DA2464879FC3> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                                                         0x111b92000 -        0x111d2ffff +libtypekitC4Release.dylib (0) <7A1E8B5F-5505-3C2A-BB8E-37061B2FFED9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/libtypekitC4Release.dylib
                                                         0x111d56000 -        0x111d59fff +com.adobe.AdobeCrashReporter (7.3 - 7.3.2) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                                                         0x111d64000 -        0x111e17ff7 +com.adobe.boost_regex.framework (10.0.0 - 10.0.0.0) <CA797BE1-B534-338C-9977-64B210FE8705> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
                                                         0x111e6f000 -        0x111f69ff7 +com.adobe.adobe_caps (adobe_caps 10.0.0.6 - 10.0.0.6) <F42B5047-A935-3B78-9F9A-F4841C6DEE88> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                                                         0x111f7f000 -        0x111f99fff +com.adobe.dvaunittesting.framework (10.0.0 - 10.0.0.0) <257F4E67-D99C-378C-8C10-1FCC00AED05A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
                                                         0x111fb0000 -        0x111fbcff3 +com.adobe.boost_filesystem.framework (10.0.0 - 10.0.0.0) <59376A9F-17E9-3BC4-AEE2-8957460769B0> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
                                                         0x111fcb000 -        0x111fd6fff +com.adobe.boost_signals.framework (10.0.0 - 10.0.0.0) <5D646DA9-E532-320C-9593-EC7E18FA3258> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
                                                         0x111fe4000 -        0x111fe8ffb  com.apple.agl (3.3.1 - AGL-3.3.1) <4E968AA4-9FB1-3425-AC1D-4853BC1182E3> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                                                         0x111ff5000 -        0x112128fff +com.adobe.AIDE (1.5.0 - 1.5.0.36540) <D593F9F3-0032-338A-AE28-E6EF2CC91F70> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
                                                         0x11214a000 -        0x11214bffb  libCyrillicConverter.dylib (69) <658DA2C5-EDC0-3F0A-88FA-33AFC4E484B3> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
                                                         0x112150000 -        0x1121f2ff7 +com.adobe.ICUConverter (4.0 - 3.61) <4D6A813A-56D5-3CE1-8743-2BA65500FD20> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
                                                         0x112216000 -        0x1122d2fff +com.adobe.dvanet.framework (10.0.0 - 10.0.0.0) <CC77D8A2-18C5-3506-8D9E-691DE9C2209A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
                                                         0x11232b000 -        0x11234ffff +VulcanControl.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <32AA6861-E0A7-37F8-8CE9-FCE97E3BFD07> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/VulcanControl.dylib
                                                         0x11235e000 -        0x112399ff7 +VulcanMessage5.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <4B054DF8-614C-39A7-AC19-CBBA847B9014> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/VulcanMessage5.dylib
                                                         0x1123b4000 -        0x112420ffb +DataBaseLib.dylib (0) <A6E884B0-76B7-35F3-A606-0C7FCFA1D5C5> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/DataBaseLib.dylib
                                                         0x112438000 -        0x1124b3ff3 +ObjectModelLib.dylib (0) <0914C6C7-8E56-3C8F-8F70-FA6CC424F980> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/ObjectModelLib.dylib
                                                         0x1124d6000 -        0x1124f6ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.36783 - 3.8.0.36783) <3C3CE968-0069-3A67-AA90-EF82A1AC3745> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExp at
                                                         0x11616d000 -        0x1161b0ff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 10.0.0.1 - 10.0.0.1) <624E6E8F-ACC9-3802-83A3-51970E64F769> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotificatio ns
                                                         0x11714d000 -        0x117322ff7 +com.adobe.InDesign.AppFramework (12.0.0.81 - 0) <101F5C03-4DE2-3436-8256-4F6CFDB7BB40> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/AppFramework.InDesignPlugin/AppFramework
                                                         0x117b45000 -        0x117b5cff7 +com.adobe.InDesign.IME (12.0.0.81 - 0) <31F9511D-BFB0-3159-994A-B1EB694C7787> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/IME.InDesignPlugin/IME
                                                         0x117b6e000 -        0x117ceaff3 +com.adobe.InDesign.Text Walker (12.0.0.81 - 0) <28EC1749-88D4-34D6-824B-728D2DFA435F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text Walker.InDesignPlugin/Text Walker
                                                         0x117d3b000 -        0x117d3fff7 +com.adobe.InDesign.Global Preferences Panel (12.0.0.81 - 0) <9E8C6084-DA2F-3249-A420-EB2F6BD38B4C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Global Preferences Panel.InDesignPlugin/Global Preferences Panel
                                                         0x117d46000 -        0x117d8aff7 +com.adobe.InDesign.Linguistics (12.0.0.81 - 0) <294B8364-0C29-3D8C-B81F-C976E2BF596A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Linguistics.InDesignPlugin/Linguistics
                                                         0x117da3000 -        0x117e02ff3 +com.adobe.InDesign.Text Panel (12.0.0.81 - 0) <33781C75-540B-31D7-B229-93854799337B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Text Panel.InDesignPlugin/Text Panel
                                                         0x117e2a000 -        0x117e71fff +com.adobe.InDesign.Spelling Panel (12.0.0.81 - 0) <72AE4F6F-7D24-3878-8EB3-47A88358FE55> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Spelling Panel.InDesignPlugin/Spelling Panel
                                                         0x117e8a000 -        0x117f9dfff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 137 - 79.159768) <0BEB92DC-04FA-37AD-8EC2-F07208EF1CFB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                                                         0x118004000 -        0x118092ff7 +com.adobe.InDesign.Master Page (12.0.0.81 - 0) <31799670-C224-3E5A-9340-C9F050FA3C97> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Master Page.InDesignPlugin/Master Page
                                                         0x11a04d000 -        0x11a279ffb +com.adobe.InDesign.Package and Preflight (12.0.0.81 - 0) <19BF9EBB-242C-3FB4-BD0C-40DFCC3717EC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Prepress/Package and Preflight.InDesignPlugin/Package and Preflight
                                                         0x11a2be000 -        0x11a510ff7 +com.adobe.InDesign.Layout UI (12.0.0.81 - 0) <EA035A95-B098-3503-8438-2987602EB8D3> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Layout UI.InDesignPlugin/Layout UI
                                                         0x11a594000 -        0x11a652ff3 +com.adobe.InDesign.Import Export UI (12.0.0.81 - 0) <46836589-899F-31D1-9DA8-E858D0224540> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Import Export UI.InDesignPlugin/Import Export UI
                                                         0x11a687000 -        0x11a76bff3 +com.adobe.InDesign.Hyperlinks (12.0.0.81 - 0) <69B1A7B5-B5F9-3AFE-8E7E-31FDB0C7AE7E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Hyperlinks.InDesignPlugin/Hyperlinks
                                                         0x11a796000 -        0x11a87afff +com.adobe.InDesign.Text Editor (12.0.0.81 - 0) <8F0E0DB4-0701-3AEE-B5FD-529D652C335F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text Editor.InDesignPlugin/Text Editor
                                                         0x11a8b2000 -        0x11a8d2ffb +com.adobe.InDesign.Utilities (12.0.0.81 - 0) <95BBD18D-E95E-3413-8FDE-BDCB67D323B5> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Utilities.InDesignPlugin/Utilities
                                                         0x11a8ec000 -        0x11a9c6ff7 +com.adobe.InDesign.Color Management (12.0.0.81 - 0) <BF24BFC9-54D5-3324-A4A4-BE917A35703C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Color Management.InDesignPlugin/Color Management
                                                         0x11ad4f000 -        0x11afabff3 +com.adobe.InDesign.Application UI (12.0.0.81 - 0) <C2EEFEBA-B789-330F-98DC-165435DC9C9E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Application UI.InDesignPlugin/Application UI
                                                         0x11b079000 -        0x11b3b2ff7 +com.adobe.dvaadameve.framework (10.0.0 - 10.0.0.0) <69E932FE-4BBA-33BF-B556-7A5BD2F296BB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
                                                         0x11b6f4000 -        0x11b88efff +com.adobe.headlights.LogSessionFramework (7.4.1.60.45263) <2116CCCF-BA38-366C-8BCE-91827BA52E6D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                                                         0x11b8b3000 -        0x11b9aaffb +com.adobe.dvametadataUI.framework (10.0.0 - 10.0.0.0) <FDABABFC-15AE-301F-895B-0DEB60209DE8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
                                                         0x11ba3a000 -        0x11bad7fff +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.4) <8FF7B7E4-C344-3433-B9BB-93737EF4A825> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
                                                         0x11baff000 -        0x11bb94ff7 +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.4) <8200505F-05B7-34FF-A81C-4221C6177FAF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                                                         0x11bbbf000 -        0x11bbf4fff +AgoraLib.dylib (1.0.0.0) <73697218-E690-371D-9728-7883DA2051A7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AgoraLib.dylib
                                                         0x11bc27000 -        0x11bd34fff +com.adobe.dvascriptui.framework (7.0.6 - 7.0.6.0) <1877E9C7-F52D-3E1E-8B97-1CFB7AF55F17> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvascriptui.framework/Versions/A/dvascriptui
                                                         0x11be50000 -        0x11bfa1fff +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.7 -f 21 - 79.159768) <F3543365-4EDE-38D9-892F-BBE8EB88C26B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
                                                         0x11bff4000 -        0x11c0b3ffb +com.adobe.dvametadata.framework (10.0.0 - 10.0.0.0) <3860678C-074D-3979-9BF2-D245C34D0E9A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
                                                         0x11c10d000 -        0x11c1e0fff +com.adobe.dvaeve.framework (10.0.0 - 10.0.0.0) <4E2283DE-B142-3E16-A40B-8A1904BE8E40> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
                                                         0x11c27f000 -        0x11c2d0ffb +com.adobe.dvatemporalxmp.framework (10.0.0 - 10.0.0.0) <6E5C33AA-DD95-33DE-B9D3-141ABA537C63> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
                                                         0x11c2fa000 -        0x11c335ff3 +com.adobe.dvamediatypes.framework (10.0.0 - 10.0.0.0) <9DA2A835-9D31-338C-856F-953126DB9A65> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
                                                         0x11c352000 -        0x11c51bff3 +com.adobe.InDesign.Document Framework (12.0.0.81 - 0) <EC3C1587-4DA7-3686-9FC7-34E066EFA2C6> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Document Framework.InDesignPlugin/Document Framework
                                                         0x11c5c5000 -        0x11c5e4ffb +com.adobe.InDesign.OnBoarding (12.0.0 - 0) <55A5963B-431F-3BBD-8C57-CE4454B3F22C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/OnBoarding/OnBoarding.InDesignPlugin/OnBoarding
                                                         0x11c63c000 -        0x11c692ff7 +com.adobe.InDesign.XMLParser (12.0.0.81 - 0) <7B8946CF-5EA5-3E99-95D9-1272B9B55E6E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/XMLParser.InDesignPlugin/XMLParser
                                                         0x11c6a7000 -        0x11c756ff7 +com.adobe.AXEXSLT (AdobeAXSLE 3.8.0.36783 - 3.8.0.36783) <96EEFBFD-FA69-3B1D-B74A-46F207AA1EFA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeAXSLE.framework/Versions/A/AdobeAXSLE
                                                         0x11c76a000 -        0x11c76cffb  com.apple.textencoding.unicode (3.0 - 3.0) <1ABD997B-AC91-3CB4-81E4-98E1863F9E3C> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                                                         0x11c776000 -        0x11c7b3267  dyld (421.2) <947FC440-80F9-32F7-A773-6FC418FE1AB7> /usr/lib/dyld
                                                         0x11ca01000 -        0x11cde7ff7 +com.extensis.AutoActivationPlugin.ID12 (18.2.1.1194 - 1194) <17F129B5-19BA-35C6-BC49-29B7343DD90C> /Applications/Adobe InDesign CC 2017/*/ExtensisFontManagementIDCC2017
                                                         0x11d0b4000 -        0x11d94ffff +com.extensis.FontManagement.plugin-interface (18.2.1.1311 - 1311) <C4421A6B-2C61-3BA3-ADB4-AAF289085440> /Applications/Suitcase Fusion.app/Contents/Resources/ExtensisPluginInterface.framework/ExtensisPluginInterface
                                                         0x11daf1000 -        0x11dbbcff7 +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.36783 - 3.8.0.36783) <EE56856F-5988-38F6-B748-F9E07288D7E9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                                                         0x11dbd0000 -        0x11ddc7fff +com.adobe.InDesign.XML (12.0.0.81 - 0) <062983B6-26DF-397F-9FF5-C57D2D5B2F83> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/XML.InDesignPlugin/XML
                                                         0x11de11000 -        0x11de35ff3 +com.adobe.InDesign.WorldReady (12.0.0.81 - 0) <20026D60-96B0-36FC-B459-3E4BF1C0A600> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/WorldReady.InDesignPlugin/WorldReady
                                                         0x11de45000 -        0x11de78fff +com.adobe.InDesign.Workgroup (12.0.0.81 - 0) <22C9733E-28D9-3C7B-A660-4D3D9ED4D3C1> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Workgroup.InDesignPlugin/Workgroup
                                                         0x11de87000 -        0x11dea3fff +com.adobe.InDesign.Workgroup Client (12.0.0.81 - 0) <08C19498-76C7-3CE6-AC0B-34DF38142967> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Workgroup Client.InDesignPlugin/Workgroup Client
                                                         0x11deb1000 -        0x11dfd5fff +com.adobe.InDesign.Transparency (12.0.0.81 - 0) <D8201F77-76DC-3830-BF6E-3107FF232C98> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Transparency.InDesignPlugin/Transparency
                                                         0x11dfff000 -        0x121675f8f +com.adobe.psl (AdobePSL 15.1.0.36906 - 15.1.0.36906) <104EE3CA-51E9-3F6B-A079-3E87BE36552D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
                                                         0x121b69000 -        0x121c29ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.36529) <759A9903-5910-3051-ABB6-CE6EBF18FF7E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                                                         0x121c4d000 -        0x121ca7fff +com.adobe.InDesign.TOC (12.0.0.81 - 0) <5943DCFC-3FDA-3D02-BFF2-57A6DEB14506> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/TOC.InDesignPlugin/TOC
                                                         0x121cba000 -        0x122270fff +com.adobe.InDesign.Text (12.0.0.81 - 0) <166E1D01-FB9D-331C-8A29-5D5FB37770EC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text.InDesignPlugin/Text
                                                         0x122313000 -        0x122377ff3 +com.adobe.InDesign.Text Wrap (12.0.0.81 - 0) <5BCB14B7-B4E5-313D-B287-747D89D84B29> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text Wrap.InDesignPlugin/Text Wrap
                                                         0x122390000 -        0x1223b0ff3 +com.adobe.InDesign.Text Wrap Path (12.0.0.81 - 0) <B36BAA42-AE34-3732-8502-22BEEB208F88> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text Wrap Path.InDesignPlugin/Text Wrap Path
                                                         0x1223b9000 -        0x1223ccfff +com.adobe.InDesign.Text Editor Model (12.0.0.81 - 0) <3BC234FF-11C5-39AB-AF73-8A76877E839F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text Editor Model.InDesignPlugin/Text Editor Model
                                                         0x1223d7000 -        0x12241affb +com.adobe.InDesign.Text Attributes (12.0.0.81 - 0) <CB83D8A8-3990-32F3-8978-97B1E7A43B4B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text Attributes.InDesignPlugin/Text Attributes
                                                         0x122434000 -        0x122484ff3 +com.adobe.InDesign.TableStyles (12.0.0.81 - 0) <977B6A65-0C07-307B-A20A-A0FFA2BC4F16> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/TableStyles.InDesignPlugin/TableStyles
                                                         0x122496000 -        0x1226a9fff +com.adobe.InDesign.Table Model (12.0.0.81 - 0) <E13EFBA3-5D81-3562-8C07-E9CE06BD5D72> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Table Model.InDesignPlugin/Table Model
                                                         0x1226ec000 -        0x12273bff3 +com.adobe.InDesign.Image Filters (12.0.0.81 - 0) <96B65FD6-2B2C-3FC9-AF45-FFFFDC3A24B0> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Image Filters.InDesignPlugin/Image Filters
                                                         0x122747000 -        0x1227b7ffb +com.adobe.InDesign.SVGExport (12.0.0.81 - 0) <F796556D-AB44-33AB-A48F-9E0DA49B7864> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/SVGExport.InDesignPlugin/SVGExport
                                                         0x1227d1000 -        0x12288ffff +com.adobe.SVGExport (AdobeSVGExport 6.0 - 6.0) <2FAB4B9A-EDB9-0FF9-55B2-52DEC380D2BF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeSVGExport.framework/Versions/A/AdobeSVGExport
                                                         0x1228b2000 -        0x12293fff3 +com.adobe.InDesign.Support for JavaScript (12.0.0.81 - 0) <BFD2572F-E62E-37F7-A559-36D88581BB4A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Support for JavaScript.InDesignPlugin/Support for JavaScript
                                                         0x12296b000 -        0x1229c2fff +com.adobe.InDesign.Support for AppleScript (12.0.0.81 - 0) <DA7AB65F-4203-30C6-9353-D34D522EA04E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Support for AppleScript.InDesignPlugin/Support for AppleScript
                                                         0x1229d9000 -        0x122ab2ff3 +com.adobe.InDesign.Graphics (12.0.0.81 - 0) <EDDEF96D-3BE6-3101-BD53-589192880A9B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Graphics.InDesignPlugin/Graphics
                                                         0x122ad6000 -        0x122b28ff7 +com.adobe.InDesign.Stroke and Fill (12.0.0.81 - 0) <ED6E5B60-FE5C-3B0B-8788-6A396D4DE3F8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Stroke and Fill.InDesignPlugin/Stroke and Fill
                                                         0x122b3f000 -        0x122c5aff7 +com.adobe.InDesign.Spread (12.0.0.81 - 0) <3A084E49-7BE9-32A8-8F13-746C4E96903B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Spread.InDesignPlugin/Spread
                                                         0x122c8b000 -        0x122cccfff +com.adobe.InDesign.Spline (12.0.0.81 - 0) <04630691-6029-32BA-B508-47ECE76BF2D1> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Spline.InDesignPlugin/Spline
                                                         0x122ce4000 -        0x122cf3ff3 +com.adobe.InDesign.Spelling Service (12.0.0.81 - 0) <126134BE-7999-381B-9D69-C3A61218F125> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Spelling Service.InDesignPlugin/Spelling Service
                                                         0x122d01000 -        0x122d0cffb +com.adobe.InDesign.Sound (12.0.0.81 - 0) <CE10C26A-F59F-312E-BEF3-05D0D9F40FA9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Sound.InDesignPlugin/Sound
                                                         0x122d18000 -        0x122d8cff7 +com.adobe.InDesign.SharedContent (12.0.0.81 - 0) <58ADA84E-7697-3958-924D-8DF7700612DF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/SharedContent.InDesignPlugin/SharedContent
                                                         0x122dad000 -        0x122dcdfff +com.adobe.InDesign.Sections (12.0.0.81 - 0) <58D9D77C-B150-343B-B3BB-31A99873A461> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Sections.InDesignPlugin/Sections
                                                         0x122ddd000 -        0x122e7cff7 +com.adobe.InDesign.Scripting (12.0.0.81 - 0) <DE3CC19F-B7C7-3EEE-B8CB-F1BBCAB3F298> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Scripting.InDesignPlugin/Scripting
                                                         0x122e9c000 -        0x123004ff3 +com.adobe.InDesign.Print (12.0.0.81 - 0) <9C4B95B0-87FA-39B7-89BE-7DB4101ADF7F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Print.InDesignPlugin/Print
                                                         0x123032000 -        0x12306cff3 +com.adobe.InDesign.PNG Import Filter (12.0.0.81 - 0) <42EBA308-5BC3-3E8A-ACAC-830496A5D0A9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/PNG Import Filter.InDesignPlugin/PNG Import Filter
                                                         0x12307c000 -        0x1230b7ff7 +com.adobe.InDesign.Photoshop Import Filter (12.0.0.81 - 0) <118529C5-FB6F-39F7-8123-07A352985D15> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Photoshop Import Filter.InDesignPlugin/Photoshop Import Filter
                                                         0x1230ca000 -        0x123124ff3 +com.adobe.InDesign.Book (12.0.0.81 - 0) <F3EB3E68-595C-353A-BD3D-FA3F28C749FE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Book.InDesignPlugin/Book
                                                         0x12313b000 -        0x123237fff +com.adobe.InDesign.Image (12.0.0.81 - 0) <B6BB788F-2326-3561-B4F5-D9B3E322225E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Image.InDesignPlugin/Image
                                                         0x123263000 -        0x12326dff3 +com.adobe.InDesign.Group (12.0.0.81 - 0) <0F029429-BF95-39A5-AA15-0091AF98C9E8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Group.InDesignPlugin/Group
                                                         0x123279000 -        0x123384ff7 +com.adobe.InDesign.EPS Page Item (12.0.0.81 - 0) <7CAB8473-B1E9-381D-A1B8-26F3AC4EE8D8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/EPS Page Item.InDesignPlugin/EPS Page Item
                                                         0x1233c3000 -        0x123603fff +com.adobe.InDesign.PDF (12.0.0.81 - 0) <30A6D0A1-D537-3B74-8170-67518615A972> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/PDF.InDesignPlugin/PDF
                                                         0x12364a000 -        0x12373cffb +com.adobe.PDFPort (AdobePDFPort 2.1.0.36974 - 2.1.0.36974) <EBC47077-B30C-3D9D-B624-73D1CDB07ED6> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
                                                         0x12374f000 -        0x123772ff3 +com.adobe.PDFSettings (AdobePDFSettings 1.07.0 - 1.7) <EE5AD335-1E84-381D-B433-32C95C5DEF4A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
                                                         0x12377d000 -        0x1239b3ff3 +com.adobe.InDesign.Generic Page Item (12.0.0.81 - 0) <F1D42D33-B76B-385E-A887-3B3A49D9C89B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Generic Page Item.InDesignPlugin/Generic Page Item
                                                         0x1239ff000 -        0x123a36fff +com.adobe.InDesign.Path Type (12.0.0.81 - 0) <5FF9C9DE-D9DB-3894-BF5A-8A4CB6850782> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Path Type.InDesignPlugin/Path Type
                                                         0x123a4f000 -        0x123a56ff3 +PathTypeLib.dylib (0) <BBCE3A07-2FCD-381B-A79F-32AE7887A256> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/PathTypeLib.dylib
                                                         0x123a5e000 -        0x123b0dff7 +com.adobe.InDesign.Paragraph Composer (12.0.0.81 - 0) <9B630291-ADF4-3A58-90F6-B0A1CBEFB3BA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Paragraph Composer.InDesignPlugin/Paragraph Composer
                                                         0x123b1d000 -        0x123b5bff3 +com.adobe.InDesign.Open Place (12.0.0.81 - 0) <8DFC5411-650B-30D3-9C82-0902C8460981> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Open Place.InDesignPlugin/Open Place
                                                         0x123b71000 -        0x123b85ffb +com.adobe.InDesign.Movie (12.0.0.81 - 0) <4F1B30F2-1358-3359-AEC3-DD6C94C0592C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Movie.InDesignPlugin/Movie
                                                         0x123b93000 -        0x123c04ffb +com.adobe.InDesign.Metadata (12.0.0.81 - 0) <76536F65-1692-3BB0-8009-A6AF6512A2A0> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Metadata.InDesignPlugin/Metadata
                                                         0x123c20000 -        0x123c6afff +com.adobe.InDesign.Media (12.0.0.81 - 0) <FB410EBE-BA9B-3C25-A2E9-30CDE0CADA29> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Media.InDesignPlugin/Media
                                                         0x123c7f000 -        0x123dd9ff3 +com.adobe.InDesign.Links (12.0.0.81 - 0) <0B8E6573-1959-307C-8B5E-E9CB3C79D9D3> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Links.InDesignPlugin/Links
                                                         0x123e1a000 -        0x123e40ff7 +com.adobe.InDesign.Layout (12.0.0.81 - 0) <A17B43CD-24E4-309B-B256-3659AE03C60E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Layout.InDesignPlugin/Layout
                                                         0x123e50000 -        0x123e76ffb +com.adobe.InDesign.Layer (12.0.0.81 - 0) <D42D9074-AFAA-386B-A126-E9498E36C864> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Layer.InDesignPlugin/Layer
                                                         0x123e89000 -        0x123f3fffb +com.adobe.InDesign.INXCore (12.0.0.81 - 0) <2E006BD3-2579-31A1-A19D-621E1C18464F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/INXCore.InDesignPlugin/INXCore
                                                         0x123f68000 -        0x12404dff3 +com.adobe.InDesign.Indexing (12.0.0.81 - 0) <6ABBFBEA-2284-319B-AB27-F9F7C63784A0> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Indexing.InDesignPlugin/Indexing
                                                         0x12406e000 -        0x1240f1ffb +com.adobe.InDesign.InCopyWorkflow (12.0.0.81 - 0) <4BB4B4C0-6C29-3246-9E5A-E5E97B94B7E2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/InCopyWorkflow.InDesignPlugin/InCopyWorkflow
                                                         0x124117000 -        0x1241ffff7 +com.adobe.InDesign.InCopyShared (12.0.0.81 - 0) <BA4F24E6-82D6-3A68-99BE-7101DFF10839> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/InCopyShared.InDesignPlugin/InCopyShared
                                                         0x12422b000 -        0x1242fcffb +com.adobe.InDesign.HTMLPGT (12.0.0.81 - 0) <95EC760C-8AB4-396C-B05D-42922C57C816> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/HTMLPGT.InDesignPlugin/HTMLPGT
                                                         0x124355000 -        0x124371ff3 +com.adobe.InDesign.Guides (12.0.0.81 - 0) <1D8B98E3-E0E4-3F48-A1BF-56D945BA4048> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Guides.InDesignPlugin/Guides
                                                         0x124382000 -        0x1243dffff +com.adobe.InDesign.Gradient Fill (12.0.0.81 - 0) <10CA39FE-BDB4-3A76-BFFB-FF61F0ADDDB2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Gradient Fill.InDesignPlugin/Gradient Fill
                                                         0x1243fa000 -        0x124404fff +com.adobe.InDesign.GenericSettings (12.0.0.81 - 0) <D498FC39-9151-3B81-873C-E98839ED6ECA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/GenericSettings.InDesignPlugin/GenericSettings
                                                         0x12440d000 -        0x124464ffb +com.adobe.InDesign.Galley (12.0.0.81 - 0) <88DD237D-8DA0-3E53-B7A3-DF7E1F89E1ED> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Galley.InDesignPlugin/Galley
                                                         0x12447a000 -        0x124539ff7 +com.adobe.InDesign.FormField (12.0.0.81 - 0) <0BC6CF28-3906-34FC-98BC-71880670D6CB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/FormField.InDesignPlugin/FormField
                                                         0x12455d000 -        0x124667fff +com.adobe.InDesign.Font Manager (12.0.0.81 - 0) <B7DE4EE6-06B2-3DD2-ABD3-B6A509B341E9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Font Manager.InDesignPlugin/Font Manager
                                                         0x12468d000 -        0x124987ff7 +com.adobe.InDesign.Dynamic Documents (12.0.0.81 - 0) <DC91CE45-51A5-34E7-B9DC-60F7398F76EC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Dynamic Documents.InDesignPlugin/Dynamic Documents
                                                         0x1249d4000 -        0x124acbfff +com.adobe.AGMFL (AdobeAGMFL 2.1.0.32362 - 2.1.0.32362) <C93FF155-AA80-34F1-A785-42BC0D8D3909> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/ADBE_AGMFL.framework/Versions/A/ADBE_AGMFL
                                                         0x124ae8000 -        0x124cc5ff7 +com.adobe.AFlamingo (AFlamingo 2.4.402.31977 - 2.4.402.31977) <B90D5CA4-DA52-39A1-95DD-8011764655A1> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflamingo
                                                         0x124ce9000 -        0x124d0cff3 +com.adobe.InDesign.Document Actions (12.0.0.81 - 0) <12C834A6-6B6E-304F-8C9F-0BD6416D07EB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Document Actions.InDesignPlugin/Document Actions
                                                         0x124d19000 -        0x124d47fff +com.adobe.InDesign.ContentDropper (12.0.0.81 - 0) <742AB3F1-9BB4-33EC-9203-616CBBE35A51> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/ContentDropper.InDesignPlugin/ContentDropper
                                                         0x124d5b000 -        0x124da7ff7 +com.adobe.InDesign.Conditional Text (12.0.0.81 - 0) <A1D66194-ADD5-3F82-8D1B-C2C247F1F1B2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Conditional Text.InDesignPlugin/Conditional Text
                                                         0x124dbf000 -        0x124e20ff3 +com.adobe.InDesign.CompFontMgr (12.0.0.81 - 0) <C27F5478-D4CB-3CEF-B5DF-5ED4C1344557> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/CompFontMgr.InDesignPlugin/CompFontMgr
                                                         0x124e3a000 -        0x124eb0ffb +com.adobe.InDesign.CJKGrid (12.0.0.81 - 0) <72CABFFE-B9D4-31E9-9865-35077526811D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/CJKGrid.InDesignPlugin/CJKGrid
                                                         0x124ecc000 -        0x124f3cff3 +com.adobe.InDesign.CJK Text Attributes (12.0.0.81 - 0) <6DD053CD-EBEB-347A-B424-D4251287B516> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/CJK Text Attributes.InDesignPlugin/CJK Text Attributes
                                                         0x124f5e000 -        0x124f91ffb +com.adobe.InDesign.CellStyles (12.0.0.81 - 0) <A0185B4A-B10E-3C7E-ABBD-D7C8F1888D99> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/CellStyles.InDesignPlugin/CellStyles
                                                         0x124fa3000 -        0x12502bfff +com.adobe.InDesign.BNCore (12.0.0.81 - 0) <6DDF3759-07FF-3AB3-93C7-3C1C59CF6371> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/BNCore.InDesignPlugin/BNCore
                                                         0x125047000 -        0x125092ff7 +com.adobe.InDesign.Behavior (12.0.0.81 - 0) <6DAF0693-413B-3904-A6F1-F61A53AB867E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Behavior.InDesignPlugin/Behavior
                                                         0x1250af000 -        0x1250eafff +com.adobe.InDesign.AWS (12.0.0.81 - 0) <666CF5CF-E6DA-31BF-B28B-789120E97467> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/AWS.InDesignPlugin/AWS
                                                         0x125105000 -        0x12518fffb +com.adobe.InDesign.Assignments (12.0.0.81 - 0) <10450C5F-6D02-35F2-A20F-6A73098ACAFC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Assignments.InDesignPlugin/Assignments
                                                         0x1251af000 -        0x1251d0ff3 +com.adobe.InDesign.Article (12.0.0.81 - 0) <FBBA34E6-32BD-34B2-B075-CEC2A715595D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Article.InDesignPlugin/Article
                                                         0x1251df000 -        0x125225ff3 +com.adobe.InDesign.Snippet (12.0.0.81 - 0) <9445570A-6658-3AA5-8DEB-2B4A1CABD71E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/XMedia/Snippet.InDesignPlugin/Snippet
                                                         0x12523d000 -        0x125246ff7 +com.adobe.InDesign.PerformanceMetrics (12.0.0.81 - 0) <1716F8A5-881E-3706-BE27-792A68197501> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Utility/PerformanceMetrics.InDesignPlugin/PerformanceMet rics
                                                         0x125250000 -        0x12525dff3 +com.adobe.InDesign.SING (12.0.0.81 - 0) <85BA6A3D-EA1A-3344-A014-3E27088F36D5> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/SING.InDesignPlugin/SING
                                                         0x125266000 -        0x125283fff +com.adobe.InDesign.Optical Kerning (12.0.0.81 - 0) <D39A4D55-B168-307F-B59E-2C2E33B22397> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Optical Kerning.InDesignPlugin/Optical Kerning
                                                         0x12528f000 -        0x1252a8ff7 +com.adobe.InDesign.Create Outlines (12.0.0.81 - 0) <1E6A5942-69FD-36B9-B4BC-00247AC6C287> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Create Outlines.InDesignPlugin/Create Outlines
                                                         0x1252b4000 -        0x12538aff3 +com.adobe.InDesign.JBX (12.0.0.81 - 0) <6900A400-3AEC-32B7-94BB-098E775A3240> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Sandbox/JBX.InDesignPlugin/JBX
                                                         0x1253b7000 -        0x125454fff +com.adobe.InDesign.DataMerge (12.0.0.81 - 0) <69C991B5-F8B8-33E0-BB41-5FDFE8F8B91F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/PMPack/DataMerge.InDesignPlugin/DataMerge
                                                         0x125473000 -        0x125484ff7 +com.adobe.InDesign.Scotch Rules (12.0.0.81 - 0) <1AAB5DAD-E78B-36D3-943A-1FD9A3B3F6D9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Page Item/Scotch Rules.InDesignPlugin/Scotch Rules
                                                         0x12548e000 -        0x12553fff7 +com.adobe.InDesign.Knowledge Base (12.0.0.81 - 0) <67013AB3-D322-3870-AC96-8DBFE1E6DFB4> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Knowledge Base.InDesignPlugin/Knowledge Base
                                                         0x125549000 -        0x125562ff3 +com.adobe.InDesign.Layout Adjustment (12.0.0.81 - 0) <8B07AB35-4130-3DEE-A69B-D23EC3B52EDA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Layout Adjustment.InDesignPlugin/Layout Adjustment
                                                         0x125570000 -        0x1255cdff7 +com.adobe.InDesign.Asset PubLibrary (12.0.0.81 - 0) <8B8FF99C-8373-30E2-85D8-C30E6DB63F8D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Asset PubLibrary.InDesignPlugin/Asset PubLibrary
                                                         0x1255ea000 -        0x1255efff3 +com.adobe.InDesign.InCopyImport (12.0.0.81 - 0) <240BABC7-70DC-3480-8C53-8A95E8A5AE72> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopyImport.InDesignPlugin/InCopyImport
                                                         0x1255f6000 -        0x1255fcff7 +com.adobe.InDesign.InCopyExport (12.0.0.81 - 0) <453DC2AF-B2EA-3FA6-B2F0-47478B7A9D7E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopyExport.InDesignPlugin/InCopyExport
                                                         0x125605000 -        0x125639ff3 +com.adobe.InDesign.InCopy Bridge (12.0.0.81 - 0) <28FB35C8-BE11-3FC1-919A-B5AC1E975FC6> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopy Bridge.InDesignPlugin/InCopy Bridge
                                                         0x125648000 -        0x12565afff +com.adobe.InDesign.Printer Styles (12.0.0.81 - 0) <3256EC82-58C3-3F81-918F-8F1724C66FFC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Printer Styles.InDesignPlugin/Printer Styles
                                                         0x125668000 -        0x12567dffb +com.adobe.InDesign.JPEG Export (12.0.0.81 - 0) <57D8CC84-4AF6-3B1B-ABC5-98FAF80DEB93> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/JPEG Export.InDesignPlugin/JPEG Export
                                                         0x12568e000 -        0x125711ff7 +com.adobe.InDesign.Tagged Text Attributes (12.0.0.81 - 0) <C1A0501D-4B40-3DF9-94C5-91BC2904515D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Tagged Text Attributes.InDesignPlugin/Tagged Text Attributes
                                                         0x125740000 -        0x1257cfffb +com.adobe.InDesign.Tagged Text Filters (12.0.0.81 - 0) <B50A1A3D-56B0-3316-BA20-D105C2E30381> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Tagged Text Filters.InDesignPlugin/Tagged Text Filters
                                                         0x1257e3000 -        0x1257e5ff7 +com.adobe.InDesign.SimpleTextImportFilter (12.0.0.81 - 0) <AE8F3E2E-3077-37A6-BF87-83B4A7D309ED> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/SimpleTextImportFilter.InDesignPlugin/SimpleText ImportFilter
                                                         0x1257eb000 -        0x1257fffff +com.adobe.InDesign.SaveBack (12.0.0.81 - 0) <7B66BEC5-7EB7-396A-A3B5-BE4F63CB0026> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/SaveBack.InDesignPlugin/SaveBack
                                                         0x12580d000 -        0x125957ffb +com.adobe.InDesign.SangamServicer-Mapper (12.0.0.81 - 0) <41174835-35B9-3ABF-B1B2-FBE1E949A743> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/SangamServicer-Mapper.InDesignPlugin/SangamServi cer-Mapper
                                                         0x125985000 -        0x1259e6fff +com.adobe.AdobeSangam (AdobeSangam 5.65.0.36985 - 5.65.0.36985) <F1E4000E-DAB0-313F-A6BB-9EC2028B4CB9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeSangam.framework/Versions/A/AdobeSangam
                                                         0x125a38000 -        0x125a7dff3 +com.adobe.InDesign.Media Import Filter (12.0.0.81 - 0) <C5679F28-01C8-3505-95F3-0DB2C800D223> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Media Import Filter.InDesignPlugin/Media Import Filter
                                                         0x125a8f000 -        0x125ceffff +com.adobe.InDesign.EBookExport (12.0.0.81 - 0) <CEAD0C3A-BECC-31CC-91E8-EAF9DD25AA7A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/EBookExport.InDesignPlugin/EBookExport
                                                         0x125d2b000 -        0x125f01ff3 +com.adobe.InDesign.Digital Publishing (12.0.0.81 - 0) <4927EB4B-7D73-3D1B-B527-23428E7DD014> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Digital Publishing.InDesignPlugin/Digital Publishing
                                                         0x125f47000 -        0x125f6cfff +com.adobe.InDesign.LILO (12.0.0.81 - 0) <8E0D9329-63F5-3746-B458-CA84C8BFB1DF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Dictionaries/LILO/LILO.InDesignPlugin/LILO
                                                         0x125f7b000 -        0x126045ff7 +com.adobe.linguistic.LinguisticManager (10.1.0 - 22175) <9A965912-1738-3875-B4E3-88FE4E19F2EA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
                                                         0x126062000 -        0x12606dfff +com.adobe.InDesign.DTTransform (12.0.0.81 - 0) <329DB794-D0CB-3D23-99D2-1E28F3F8FF37> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Data Services/DTTransform.InDesignPlugin/DTTransform
                                                         0x126076000 -        0x12607cff7 +com.adobe.InDesign.Data Services (12.0.0.81 - 0) <F3A64479-9CE4-3E55-9A95-6BAEE21C01D7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Data Services/Data Services.InDesignPlugin/Data Services
                                                         0x126082000 -        0x1260a8ff7 +com.adobe.ape (3.4.0.29366 - 3.4.0.29366) <40A59819-7A57-0E9F-658D-1803B2A461AE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/adbeapecore.framework/adbeapecore
                                                         0x1260bb000 -        0x1260c8fff +com.extensis.fontplugins (18.2.1.1194 - 1194) <C4AD8DE4-E2B6-3806-B2DF-2ED582DCA3D9> /Applications/Suitcase Fusion.app/Contents/Resources/PluginFiles/ExtensisPlugins.framework/ExtensisPlugins
                                                         0x126112000 -        0x126130fff +com.adobe.InDesign.SavebackService (12.0.0 - 0) <5FA1922F-43AA-31D6-B34F-D864E0006A48> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/SavebackService/SavebackService.InDesignPlugin/SavebackS ervice
                                                         0x126142000 -        0x12628dfff +IMSLib.dylib (10.0.0.11 - 10.0.0.11) <21D0C981-4447-364F-AAAA-F64A310F55B4> /Library/Application Support/Adobe/*/IMSLib.dylib
                                                         0x1262ae000 -        0x126306ffb +com.adobe.InDesign.Actions (12.0.0.81 - 0) <7685643D-9612-335C-B8F0-5C3067C28D1C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Actions.InDesignPlugin/Actions
                                                         0x126323000 -        0x12639cfff  com.apple.xquery (1.3.1 - 30) <9BBE7704-B310-31C7-85F6-BA033714B482> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
                                                         0x1263d9000 -        0x126457fff +com.adobe.InDesign.CSXS (12.0.0.81 - 0) <AAE722B1-9AA8-31CC-A325-2A68D0461514> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/CSXS.InDesignPlugin/CSXS
                                                         0x12647e000 -        0x1265a0ffb +libExperimentationSDKRelease.dylib (0) <23E0C445-66FC-35ED-A54B-5A40893AC048> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/libExperimentationSDKRelease.dylib
                                                         0x1265b7000 -        0x1265dffff +com.adobe.InDesign.AWSUI (12.0.0.81 - 0) <283221E2-2C53-344E-ACEE-BF1910ACBF8A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/AWSUI.InDesignPlugin/AWSUI
                                                         0x1265f5000 -        0x126656ff3 +com.adobe.InDesign.Spread UI (12.0.0.81 - 0) <9EE5CB84-2902-3FEA-8CEF-6097048EFF2F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Spread UI.InDesignPlugin/Spread UI
                                                         0x126678000 -        0x126769ffb +com.adobe.InDesign.Package and Preflight UI (12.0.0.81 - 0) <B48C25C0-2C79-3911-AE89-A83CC93CF709> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Prepress/Package and Preflight UI.InDesignPlugin/Package and Preflight UI
                                                         0x1267aa000 -        0x1267b7ff3 +com.adobe.InDesign.Scripts Panel (12.0.0.81 - 0) <646C073B-66C5-3AEB-8B32-B77226975B9C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Script/Scripts Panel.InDesignPlugin/Scripts Panel
                                                         0x1267c7000 -        0x126847ffb +com.adobe.InDesign.Eyedropper Tool (12.0.0.81 - 0) <A41370CA-6C66-36FD-BF95-D99F6D83E41F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Eyedropper Tool.InDesignPlugin/Eyedropper Tool
                                                         0x12686d000 -        0x1268b5ff3 +com.adobe.InDesign.Asset Library Panel (12.0.0.81 - 0) <E48DC50A-ABF0-30A9-B03B-D254B65483C4> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Asset Library Panel.InDesignPlugin/Asset Library Panel
                                                         0x1268db000 -        0x1269f0ff3 +com.adobe.InDesign.XMedia UI (12.0.0.81 - 0) <79820244-504C-3B67-A8FD-EB017E09BEB2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/XMedia/XMedia UI.InDesignPlugin/XMedia UI
                                                         0x126c4b000 -        0x126c4cfff  ATSHI.dylib (422.2) <AD4ADF66-9701-337E-8177-E0E13E82DC0B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
                                                         0x126c5c000 -        0x126c64ff7 +com.adobe.InDesign.Workgroup Client UI (12.0.0.81 - 0) <95C6F351-6EBA-3D48-8C1C-4B985ADA4D5B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Workgroup Client UI.InDesignPlugin/Workgroup Client UI
                                                         0x126c6a000 -        0x126c6fffb +com.adobe.InDesign.Help (12.0.0.81 - 0) <3AB11208-2055-38CC-AFB4-22A1688C856B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Help.InDesignPlugin/Help
                                                         0x126c76000 -        0x126c82ffb +com.adobe.InDesign.General Preferences Panel (12.0.0.81 - 0) <C152E38C-07C8-3E9E-8590-356092E94DA2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/General Preferences Panel.InDesignPlugin/General Preferences Panel
                                                         0x126cb6000 -        0x126cc2ff7 +com.adobe.InDesign.Document UI (12.0.0.81 - 0) <5EE88969-8105-3260-B009-28BAAAA42D9C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Document UI.InDesignPlugin/Document UI
                                                         0x126ccd000 -        0x126ccdfff +DTraceSupport.dylib (1) <E54DF20B-C169-68CF-A3F5-0470DEFF1C8A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/DTraceSupport.dylib
                                                         0x126cd1000 -        0x126cdafff +com.adobe.InDesign.Track Changes Preferences (12.0.0.81 - 0) <309BBAEB-1562-3AFD-A21F-3BE1922DBAB4> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Track Changes Preferences.InDesignPlugin/Track Changes Preferences
                                                         0x1271df000 -        0x1271e4ff3  libgermantok.dylib (17) <C35BED09-0631-31F8-91C4-EC5994CC4FAF> /usr/lib/libgermantok.dylib
                                                         0x127368000 -        0x127384ff3 +com.adobe.InDesign.InCopySharedUI (12.0.0.81 - 0) <5199569E-C5FE-3430-94D7-BFEC9B33032B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/InCopySharedUI.InDesignPlugin/InCopySharedUI
                                                         0x1275a0000 -        0x1275acfff +com.adobe.InDesign.Text Color Panel (12.0.0.81 - 0) <E0652271-7986-3672-87D1-6B880662EC20> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Text Color Panel.InDesignPlugin/Text Color Panel
                                                         0x1275bc000 -        0x1275e3ff7 +com.adobe.InDesign.Rulers (12.0.0.81 - 0) <D01BC512-274E-3FE1-8173-6065EAC0142E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Rulers.InDesignPlugin/Rulers
                                                         0x1275f8000 -        0x127601fff +FastCore (17.0.1 - 17.0.1) <E385B772-C887-3D72-B226-7E6BBB2DBC26> /Applications/Adobe InDesign CC 2017/*/FastCore.plugin/Contents/MacOS/FastCore
                                                         0x12760b000 -        0x127614fff +com.adobe.InDesign.Span Columns Panel (12.0.0.81 - 0) <5455B95B-C5F9-36C3-B16B-A499C7F942FF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Span Columns Panel.InDesignPlugin/Span Columns Panel
                                                         0x127622000 -        0x127629ff7 +com.adobe.InDesign.Keeps Panel (12.0.0.81 - 0) <E238E435-DDD8-3964-9CEC-2781D58DDB39> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Keeps Panel.InDesignPlugin/Keeps Panel
                                                         0x12763b000 -        0x12765cfff +com.adobe.InDesign.SharedContentUI (12.0.0.81 - 0) <42971359-C170-3200-A048-84CC3378FF63> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/SharedContentUI.InDesignPlugin/SharedContentUI
                                                         0x12766b000 -        0x127687ffb  libJapaneseConverter.dylib (69) <A7425FB1-38FF-3CEF-B9BB-B0120F681DB0> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                                                         0x12768d000 -        0x1276affff  libKoreanConverter.dylib (69) <56252FE2-8D5C-343D-B74B-47FA982AE7B6> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                                                         0x12771b000 -        0x127720ffb +com.adobe.InDesign.Layout Adjustment Panel (12.0.0.81 - 0) <81B4ADAE-08A0-3110-A059-E5FE44AA7260> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Layout Adjustment Panel.InDesignPlugin/Layout Adjustment Panel
                                                         0x12883e000 -        0x128866fff +com.adobe.InDesign.Article Panel (12.0.0.81 - 0) <4CE15E7F-D2F5-3B16-925E-4E6297444B24> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Article Panel.InDesignPlugin/Article Panel
                                                         0x12887f000 -        0x1288b6ffb +com.adobe.InDesign.Transform Panel (12.0.0.81 - 0) <9F57DB5E-7682-35CF-B8AD-9FD68FDB42F7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Transform Panel.InDesignPlugin/Transform Panel
                                                         0x1288cd000 -        0x128943ff7 +com.adobe.InDesign.DynamicDocumentsUI (12.0.0.81 - 0) <7EC20AB4-52AB-315A-8AE6-7A9B6DB8ABC0> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/DynamicDocumentsUI.InDesignPlugin/DynamicDocume ntsUI
                                                         0x12896a000 -        0x128997fff +com.adobe.InDesign.Conditional Text UI (12.0.0.81 - 0) <B232A286-B18E-3AF8-B23E-1A49C4F710DC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Conditional Text UI.InDesignPlugin/Conditional Text UI
                                                         0x1289b2000 -        0x128a46ff3 +com.adobe.InDesign.TableStylesUI (12.0.0.81 - 0) <64AC052A-6A6A-3B01-B1A0-54434A080E08> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Tables/TableStylesUI.InDesignPlugin/TableStylesUI
                                                         0x128a72000 -        0x128a7dfff +com.adobe.InDesign.Generic Style Editor (12.0.0.81 - 0) <90D366EB-CB1C-3A4F-94C6-44596B423A1B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Generic Style Editor.InDesignPlugin/Generic Style Editor
                                                         0x128a8b000 -        0x128b58ffb +com.adobe.InDesign.PrintUI (12.0.0.81 - 0) <61E78318-0765-388B-9778-42AE572EC987> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/PrintUI.InDesignPlugin/PrintUI
                                                         0x128b83000 -        0x128c04ff3 +com.adobe.InDesign.Color Picker Panel (12.0.0.81 - 0) <088716BC-AFF1-3663-843C-E0B902E8496E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Color Picker Panel.InDesignPlugin/Color Picker Panel
                                                         0x128c31000 -        0x128d16ff7 +com.adobe.InDesign.Swatches Panel (12.0.0.81 - 0) <EB891CAC-F4CE-3D42-B1E1-5F233BB5BB34> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Swatches Panel.InDesignPlugin/Swatches Panel
                                                         0x128d51000 -        0x128de5ff3 +com.adobe.InDesign.Transparency UI (12.0.0.81 - 0) <05AA3716-8CD9-3EC3-B116-B2251722BA45> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Transparency UI.InDesignPlugin/Transparency UI
                                                         0x128e18000 -        0x128e3eff3 +com.adobe.InDesign.Text Style Panel (12.0.0.81 - 0) <E255B71E-1A83-30C6-9DF4-0A98A7D73233> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Text Style Panel.InDesignPlugin/Text Style Panel
                                                         0x128e4f000 -        0x128ebffff +com.adobe.InDesign.Style Panel (12.0.0.81 - 0) <1898A9F7-3D12-365E-828A-E4A11D525B5B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Style Panel.InDesignPlugin/Style Panel
                                                         0x128ee9000 -        0x128f92ffb +com.adobe.InDesign.Graphic Panels (12.0.0.81 - 0) <4BE79D70-76EF-357F-9453-CA26128E372D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Graphic Panels.InDesignPlugin/Graphic Panels
                                                         0x128fbe000 -        0x129055ffb +com.adobe.InDesign.ObjectStylesUI (12.0.0.81 - 0) <7882A96F-EC25-38F5-A2AA-7EDC55047276> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/ObjectStylesUI.InDesignPlugin/ObjectStylesUI
                                                         0x129085000 -        0x129096ff3 +com.adobe.InDesign.PS Import UI (12.0.0.81 - 0) <1AE97B4A-229C-3F77-9941-28CCB82421AF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/PS Import UI.InDesignPlugin/PS Import UI
                                                         0x1290a5000 -        0x1290abffb +com.adobe.InDesign.Username UI (12.0.0.81 - 0) <91CB1D7D-032D-3CCE-96D0-7B6787A8ABBA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/Username UI.InDesignPlugin/Username UI
                                                         0x1290b4000 -        0x12910fffb +com.adobe.InDesign.Assignment UI (12.0.0.81 - 0) <D9030AA9-16EC-3446-967F-994DDFB62A32> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/Assignment UI.InDesignPlugin/Assignment UI
                                                         0x129132000 -        0x12914bffb +com.adobe.InDesign.Bookmark Panel (12.0.0.81 - 0) <260AF045-9FA7-3917-BA02-5C83393D0BBC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Bookmark Panel.InDesignPlugin/Bookmark Panel
                                                         0x129161000 -        0x1291f3fff +com.adobe.InDesign.ButtonUI (12.0.0.81 - 0) <CA784015-7264-3E0E-B562-00F7FFA2D1D1> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Interactive/ButtonUI.InDesignPlugin/ButtonUI
                                                         0x129222000 -        0x1292befff +com.adobe.InDesign.Hyperlinks Panel (12.0.0.81 - 0) <835AC38D-25A4-3E13-A33E-96D168AFA68B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Hyperlinks Panel.InDesignPlugin/Hyperlinks Panel
                                                         0x1292ea000 -        0x12936dfff +com.adobe.InDesign.Index Panel (12.0.0.81 - 0) <8850A0E9-B000-32E3-9F1C-7E66244BD3D5> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Index Panel.InDesignPlugin/Index Panel
                                                         0x12938e000 -        0x129398fff +unihan (0) <54E13787-663F-3550-94EF-6CD94F63C375> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/unihan.framework/Versions/A/unihan
                                                         0x1293a5000 -        0x1293f1ffb +com.adobe.InDesign.Output Preview (12.0.0.81 - 0) <665012E5-914E-3A45-9350-8891C2B6974E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Output Preview.InDesignPlugin/Output Preview
                                                         0x12940d000 -        0x12944aff3 +com.adobe.InDesign.TOC UI Dialog (12.0.0.81 - 0) <96D0A57E-52B0-3E18-AABC-88846EFBC450> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/TOC UI Dialog.InDesignPlugin/TOC UI Dialog
                                                         0x129463000 -        0x12947aff7 +com.adobe.InDesign.OutputMiscUI (12.0.0.81 - 0) <A9208127-2E79-36B4-B5A4-2820E79EDD34> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/OutputMiscUI.InDesignPlugin/OutputMiscUI
                                                         0x12948d000 -        0x12949fff7 +com.adobe.InDesign.Sections UI (12.0.0.81 - 0) <0ACFD577-F66C-3FE6-945A-7A8D8A0A8B1E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Sections UI.InDesignPlugin/Sections UI
                                                         0x1294aa000 -        0x1294f1ff7 +com.adobe.InDesign.Book Panel (12.0.0.81 - 0) <D454BD4B-7CA6-3F50-865F-CF9882E431CC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Book Panel.InDesignPlugin/Book Panel
                                                         0x129516000 -        0x129566ff3 +com.adobe.InDesign.Note (12.0.0.81 - 0) <0CD90339-CCBA-3FBD-B7E5-9057598C8B50> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/Note.InDesignPlugin/Note
                                                         0x129586000 -        0x1295cefff +com.adobe.InDesign.Layers Panel (12.0.0.81 - 0) <5CD50EE0-12F9-3A3B-AFBC-E72B15E4B4A3> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Layers Panel.InDesignPlugin/Layers Panel
                                                         0x1295f0000 -        0x129627fff +com.adobe.InDesign.Dictionary Editor Dialog (12.0.0.81 - 0) <F3DBAA28-14D2-3DC3-B6E0-9FC2112845AC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Dictionaries/Dictionary Editor Dialog.InDesignPlugin/Dictionary Editor Dialog
                                                         0x129647000 -        0x1296ffff3 +com.adobe.InDesign.Pages Panel (12.0.0.81 - 0) <CD4DB179-57B4-3AFB-9721-A766467FA2B4> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Pages Panel.InDesignPlugin/Pages Panel
                                                         0x129730000 -        0x1297d3ff7  ColorSyncDeprecated.dylib (502.1) <CE18BCA4-27E3-3188-AA5B-EF68F2AA6328> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/Resources/ColorSyncDeprecated.dylib
                                                         0x12981b000 -        0x12985aff3 +com.adobe.InDesign.Color Management UI (12.0.0.81 - 0) <78DDC256-9135-389C-9B47-C537CE177339> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Color Management UI.InDesignPlugin/Color Management UI
                                                         0x12986a000 -        0x12988bfff +com.adobe.InDesign.Swatch Library Panel (12.0.0.81 - 0) <52B76571-5586-3E52-ABA7-E5BF67FC087A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Swatch Library Panel.InDesignPlugin/Swatch Library Panel
                                                         0x12989a000 -        0x1298cdfff +com.adobe.InDesign.Basic Tools (12.0.0.81 - 0) <026E1461-C93A-3DF2-B0B7-6A8D464209F3> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Basic Tools.InDesignPlugin/Basic Tools
                                                         0x129bfb000 -        0x129c07ff7 +com.adobe.InDesign.Metadata UI (12.0.0.81 - 0) <1EC05707-738C-3F89-A2DF-72135961933C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Workflow/Metadata UI.InDesignPlugin/Metadata UI
                                                         0x129c12000 -        0x129c1bfff +com.adobe.InDesign.Justification Panel (12.0.0.81 - 0) <E25008E3-70F3-313D-9046-C286C3376747> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Justification Panel.InDesignPlugin/Justification Panel
                                                         0x129c27000 -        0x129c5cff3 +com.adobe.InDesign.Paragraph Panel (12.0.0.81 - 0) <BF29973E-2A3B-39FE-B9C2-A619FA922175> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Paragraph Panel.InDesignPlugin/Paragraph Panel
                                                         0x129c73000 -        0x129c90fff +com.adobe.InDesign.Performance UI (12.0.0.81 - 0) <30609330-89AD-36EA-9626-21AF508EF2B8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Performance UI.InDesignPlugin/Performance UI
                                                         0x12a380000 -        0x12a4bafff +com.adobe.InDesign.GalleyUI (12.0.0.81 - 0) <3B67EE29-961F-3116-97C7-CB8E2BA9BCBC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/GalleyUI.InDesignPlugin/GalleyUI
                                                         0x12a4eb000 -        0x12a5c7ff7 +com.adobe.InDesign.Tables UI (12.0.0.81 - 0) <916251FE-B080-30BD-9CF8-7DC76F9E866A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Tables/Tables UI.InDesignPlugin/Tables UI
                                                         0x12a5f9000 -        0x12a61eff3 +com.adobe.InDesign.Find Change Format Panel (12.0.0.81 - 0) <43A02721-7790-3837-B57D-8823C7FB6FD9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Find Change Format Panel.InDesignPlugin/Find Change Format Panel
                                                         0x12a632000 -        0x12a741ff3 +com.adobe.InDesign.Find and Change Panel (12.0.0.81 - 0) <E4749361-65CD-36AC-AB63-57506BADFE38> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Find and Change Panel.InDesignPlugin/Find and Change Panel
                                                         0x12a77e000 -        0x12a7acff7 +com.adobe.Reader for DOCX (Reader for DOCX 5.65.0.36985 - 5.65.0.36985) <7222A7BA-EF2C-348B-8C1E-B7C65A08D959> /Applications/Adobe InDesign CC 2017/*/Reader for DOCX
                                                         0x12a7b8000 -        0x12a83dff3 +com.adobe.AdobeSangamML (AdobeSangamML 5.65.0.36985 - 5.65.0.36985) <4E9C7BF3-881D-31C4-A7CB-7BE464760BEB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeSangamML.framework/Versions/A/AdobeSangamML
                                                         0x12a861000 -        0x12a8b4fff +com.adobe.Reader for Excel (Reader for Excel 5.65.0.36985 - 5.65.0.36985) <3657EB98-55BA-3964-8207-29C46CD5A386> /Applications/Adobe InDesign CC 2017/*/Reader for Excel
                                                         0x12a8c6000 -        0x12a8dcff7 +com.adobe.AdobeSFL (AdobeSFL 1.1.0.36043 - 1.1.0.36043) <049C1233-3D7E-38C6-9A14-4DF92626AB51> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
                                                         0x12a8e7000 -        0x12a9c2ffb +com.adobe.Reader for Quark (Reader for Quark 5.65.0.36985 - 5.65.0.36985) <ED28641A-34D9-3301-904A-40B6CEA2A453> /Applications/Adobe InDesign CC 2017/*/Reader for Quark
                                                         0x12a9db000 -        0x12aa2aff3 +com.adobe.Reader for RTF (Reader for RTF 5.65.0.36985 - 5.65.0.36985) <1D11FE22-46FB-3E86-821E-B0046F99CCF8> /Applications/Adobe InDesign CC 2017/*/Reader for RTF
                                                         0x12aa43000 -        0x12aaa4ff7 +com.adobe.Reader for Word (Reader for Word 5.65.0.36985 - 5.65.0.36985) <EBA8224F-4909-3F12-8C6D-C894507D0861> /Applications/Adobe InDesign CC 2017/*/Reader for Word
                                                         0x12aab9000 -        0x12ab27fff +com.adobe.Reader for XLSX (Reader for XLSX 5.65.0.36985 - 5.65.0.36985) <059C92E5-6884-3E6E-833A-816136E79B81> /Applications/Adobe InDesign CC 2017/*/Reader for XLSX
                                                         0x12ab41000 -        0x12ab47ff7 +com.adobe.ZTextReader (ZTextReader 5.65.0.36985 - 5.65.0.36985) <ED055B47-0C1B-3FCB-B834-1AE7FA1E8C32> /Applications/Adobe InDesign CC 2017/*/ZTextReader
                                                         0x12ac5e000 -        0x12ad18ff7  com.apple.AMDRadeonX3000GLDriver (1.48.21 - 1.4.8) <112B133E-9EF2-3B96-886E-DA033D17DDB9> /System/Library/Extensions/AMDRadeonX3000GLDriver.bundle/Contents/MacOS/AMDRadeonX3000GLD river
                                                         0x12b037000 -        0x12b08cff7 +com.adobe.InDesign.DV_Widgets (12.0.0.81 - 0) <F72BF8EF-9F38-31FD-B303-FD0BD1D36D17> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/DV_Widgets.InDesignPlugin/DV_Widgets
                                                         0x12b0fc000 -        0x12b1e8ff7 +com.adobe.InDesign.Widgets (12.0.0.81 - 0) <7D6492A1-D0D8-3835-A213-C4722EB72969> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Widgets.InDesignPlugin/Widgets
                                                         0x12b262000 -        0x12b282fff +com.adobe.InDesign.GapTool (12.0.0.81 - 0) <1771139D-0661-364D-A607-3D69AE28C250> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/GapTool.InDesignPlugin/GapTool
                                                         0x12b292000 -        0x12b2c2ffb +com.adobe.InDesign.ContentDropper Tool (12.0.0.81 - 0) <523536D6-2FF3-338C-B75E-8B8146F1FBCF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/ContentDropper Tool.InDesignPlugin/ContentDropper Tool
                                                         0x12b2e1000 -        0x12b2f6ff7 +com.adobe.InDesign.Path Type UI (12.0.0.81 - 0) <51B47F10-C617-3B31-A967-F7EC0579D1BD> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Path Type UI.InDesignPlugin/Path Type UI
                                                         0x12b306000 -        0x12b34affb +com.adobe.InDesign.Spline UI (12.0.0.81 - 0) <550C322B-B264-3596-BCCA-1993EFBB0076> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Spline UI.InDesignPlugin/Spline UI
                                                         0x12b367000 -        0x12b385ffb +com.adobe.InDesign.Tool Box (12.0.0.81 - 0) <05C6D703-B4C2-34CF-9BE9-0576966A1824> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Tool Box.InDesignPlugin/Tool Box
                                                         0x12b3b1000 -        0x12b3b9ff3 +com.adobe.InDesign.Tool Tips (12.0.0.81 - 0) <5F96D857-BC0A-3353-BD29-C37A2BBD0E09> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Tool Tips.InDesignPlugin/Tool Tips
                                                         0x12b6cb000 -        0x12b6ddff3 +com.adobe.InDesign.Story Panel (12.0.0.81 - 0) <6050F3FF-50B4-357E-97BA-89EACFC83576> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Story Panel.InDesignPlugin/Story Panel
                                                         0x12b6ec000 -        0x12b720ff3 +com.adobe.InDesign.Gradient Panel (12.0.0.81 - 0) <FCC84854-FCDE-33AE-A4D3-17940C12D706> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Gradient Panel.InDesignPlugin/Gradient Panel
                                                         0x12b739000 -        0x12b748ff7 +com.adobe.InDesign.Alignment Panel (12.0.0.81 - 0) <AFF308EF-3A59-391B-9FA3-74CCCFF41421> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Alignment Panel.InDesignPlugin/Alignment Panel
                                                         0x12b751000 -        0x12b7f4ff3 +com.adobe.InDesign.Character Panel (12.0.0.81 - 0) <52B86336-E63C-3C8B-8C02-DD788A6B49D8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Character Panel.InDesignPlugin/Character Panel
                                                         0x12b841000 -        0x12b864ff3 +com.adobe.InDesign.Dialog Layout (12.0.0.81 - 0) <082B6C3B-5D00-3D81-A6C0-C22BE105BB4C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Dialog Layout.InDesignPlugin/Dialog Layout
                                                         0x12b879000 -        0x12b88efff +com.adobe.InDesign.Track Changes UI (12.0.0.81 - 0) <32F6CC77-6AD6-33DC-A2D3-3A6AAB9C3FF7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Track Changes UI.InDesignPlugin/Track Changes UI
                                                         0x12b8a2000 -        0x12b96bff3 +com.adobe.InDesign.Glyphs Panel (12.0.0.81 - 0) <6A589C08-D75D-3BAF-B8A2-85F1678B99BA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Glyphs Panel.InDesignPlugin/Glyphs Panel
                                                         0x12b992000 -        0x12b9ceff7 +com.adobe.InDesign.Control Panel (12.0.0.81 - 0) <3A295F76-6448-3152-ADC5-AAAA2C820A50> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Control Panel.InDesignPlugin/Control Panel
                                                         0x12b9eb000 -        0x12b9f2fff +com.adobe.InDesign.Script Label Panel (12.0.0.81 - 0) <5441E77C-2925-30E6-B9EE-26D122C99863> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Script/Script Label Panel.InDesignPlugin/Script Label Panel
                                                         0x12b9fe000 -        0x12ba25ffb +com.adobe.InDesign.MediaUI (12.0.0.81 - 0) <97BACAB1-F482-32FC-9291-4B6129186D02> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Interactive/MediaUI.InDesignPlugin/MediaUI
                                                         0x12ba3e000 -        0x12ba98fff +com.adobe.InDesign.Info Panel (12.0.0.81 - 0) <C654E51A-C1BB-3B91-B080-1C13F5769C32> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Info Panel.InDesignPlugin/Info Panel
                                                         0x12bab0000 -        0x12bae1ff3 +com.adobe.InDesign.DataMergeUI (12.0.0.81 - 0) <A0E00A91-1F26-348E-8B56-8F4E06DA9DC7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/PMPack/DataMergeUI.InDesignPlugin/DataMergeUI
                                                         0x12bafb000 -        0x12bb42ff7 +com.adobe.InDesign.Links UI (12.0.0.81 - 0) <8E3849B6-A879-34F1-9C70-61E4DF95E5CC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Links UI.InDesignPlugin/Links UI
                                                         0x12bb63000 -        0x12bba2ffb +com.adobe.InDesign.Digital Publishing UI (12.0.0.81 - 0) <40041318-3260-368D-B664-1763CCC19FC8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Digital Publishing UI.InDesignPlugin/Digital Publishing UI
                                                         0x12bbf9000 -        0x12bdffffb  ATIRadeonX3000SCLib.dylib (1.48.21) <E9BFF311-10D0-3BA2-AD3E-E4EA5FEB1FA0> /System/Library/Extensions/AMDRadeonX3000GLDriver.bundle/Contents/MacOS/ATIRadeonX3000SCL ib.dylib
                                                         0x12be5b000 -        0x12beb3ff3 +com.adobe.InDesign.BNUI (12.0.0.81 - 0) <482826D0-9C7E-33ED-A2A7-20B36B797C79> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/PMPack/BNUI.InDesignPlugin/BNUI
                                                         0x12bed3000 -        0x12bf0cff3 +com.adobe.InDesign.Text Wrap Panel (12.0.0.81 - 0) <B98A0063-961E-3B3D-AC08-4CAEFE03F971> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Text Wrap Panel.InDesignPlugin/Text Wrap Panel
                                                         0x12c1a9000 -        0x12c1b3ff3 +com.adobe.InDesign.StepRepeat (12.0.0.81 - 0) <0D53DD3B-9AE3-3A2C-BF1E-85C1439F6F9F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/StepRepeat.InDesignPlugin/StepRepeat
                                                         0x12c2c5000 -        0x12c2e5ff3 +com.adobe.InDesign.InCopy Bridge UI (12.0.0.81 - 0) <985CB572-CFAB-37D1-91F4-83E0AE2186EC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopy Bridge UI.InDesignPlugin/InCopy Bridge UI
                                                         0x12c3f9000 -        0x12c482fff  com.apple.applescript (2.5 - 381) <E2F23F67-7046-3829-81A6-B7B008D3BC4F> /System/Library/PrivateFrameworks/AppleScript.framework/Versions/A/AppleScript
                                                         0x12c4c0000 -        0x12c4caffb +com.adobe.InDesign.Workgroup UI (12.0.0.81 - 0) <1E81D947-5401-3ABB-99B1-DC1F3F894A25> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Workgroup/Workgroup UI.InDesignPlugin/Workgroup UI
                                                         0x12c8b0000 -        0x12c8b5ffb  com.apple.URLMount.CIFSPlugin (7.1 - 7.1) <1B1E588C-5D00-31AC-8496-EEE6FAF70335> /System/Library/Filesystems/NetFSPlugins/smb.bundle/Contents/MacOS/smb
                                                         0x12ca2f000 -        0x12ca4ffff  com.apple.CoreNLP (1.0 - 78.2) <D7A0704A-C4EB-3225-9F23-A06EC3318238> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
                                                         0x12cab8000 -        0x12cac2fff +com.adobe.InDesign.NotePref (12.0.0.81 - 0) <25CC3ADF-9929-3B3E-8CAD-2633D6C483F5> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/NotePref.InDesignPlugin/NotePref
                                                         0x12cad0000 -        0x12cadfffb  libSimplifiedChineseConverter.dylib (69) <4A6C9911-5DE8-3CAE-A10C-AACE29D03FFE> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                                                         0x12cd5d000 -        0x12cd6fff3  libTraditionalChineseConverter.dylib (69) <40223B74-10DB-3FCB-9C7D-A387F6D87BD2> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                                                         0x12e3e1000 -        0x12e404fff +com.adobe.InDesign.Shortcut Editor Dialog (12.0.0.81 - 0) <C063BD03-83D2-375D-BAF1-0C90D77BAE43> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Shortcut Editor Dialog.InDesignPlugin/Shortcut Editor Dialog
                                                         0x12e418000 -        0x12e436fff +com.adobe.ahclientframework (2.2.0.1 - 2.2.0.1) <78C9396E-DBAE-3C68-9B67-95B28F2BEC76> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                                                         0x12e440000 -        0x12e473ff7 +com.adobe.InDesign.Galley Preferences (12.0.0.81 - 0) <1FF9DB14-4D4C-3BE1-BD0E-C0AF7E7DC278> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Galley Preferences.InDesignPlugin/Galley Preferences
                                                         0x12e4f2000 -        0x12e524ff7 +com.adobe.pip (7.4.1.60.45263) <B0E15E67-5403-3159-8A4F-6D3BDB11D77C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
                                                         0x12e5a2000 -        0x12e5c3ff3 +com.adobe.InDesign.Text Ruler (12.0.0.81 - 0) <AD2F6F0D-0DE1-35DE-8AF6-4A7A93BAA691> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Text Ruler.InDesignPlugin/Text Ruler
                                                         0x12e5fb000 -        0x12e61aff7 +com.adobe.InDesign.Text Preferences (12.0.0.81 - 0) <1775600D-8234-375B-AAD5-B45751A0A99D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Text Preferences.InDesignPlugin/Text Preferences
                                                         0x12e62a000 -        0x12e658ff3 +com.adobe.InDesign.Text Frame Options (12.0.0.81 - 0) <9F92829C-FC99-3822-835D-F246D6B36ED9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Text Frame Options.InDesignPlugin/Text Frame Options
                                                         0x12e66b000 -        0x12e67cffb +com.adobe.InDesign.Paragraph Rules Panel (12.0.0.81 - 0) <747B51F0-ED0B-3C52-AF34-9A030DED0500> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Paragraph Rules Panel.InDesignPlugin/Paragraph Rules Panel
                                                         0x12ef59000 -        0x12ef82ff3 +com.adobe.InDesign.RunIn Styles Panel (12.0.0.81 - 0) <B1C78260-AFD4-3927-969C-84E33F929B8D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/RunIn Styles Panel.InDesignPlugin/RunIn Styles Panel
                                                         0x12ef95000 -        0x12efa7ffb +com.adobe.InDesign.Indents and Tabs (12.0.0.81 - 0) <AB0F86BB-3395-334B-8C15-FCD049DAE36F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Indents and Tabs.InDesignPlugin/Indents and Tabs
                                                         0x12efb7000 -        0x12efc0ff3 +com.adobe.InDesign.Hyphenation Panel (12.0.0.81 - 0) <78BC5601-B711-3629-8E7D-47F543E9DE8F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Hyphenation Panel.InDesignPlugin/Hyphenation Panel
                                                         0x12f08d000 -        0x12f0a6ffb +com.adobe.InDesign.Image Import UI (12.0.0.81 - 0) <A75498F0-246C-370B-B9BC-09E464E5A268> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Page Item/Image Import UI.InDesignPlugin/Image Import UI
                                                         0x12f0ba000 -        0x12f0e8ff7 +com.adobe.InDesign.Page Setup Dialog (12.0.0.81 - 0) <ABA18DA1-6FAF-35CD-85A2-40EE9F588AEE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Page Setup Dialog.InDesignPlugin/Page Setup Dialog
                                                         0x12f0ff000 -        0x12f109fff +com.adobe.InDesign.Create Guides Dialog (12.0.0.81 - 0) <2F8F9DCC-6A19-3815-BDB8-48E829932D20> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Create Guides Dialog.InDesignPlugin/Create Guides Dialog
                                                         0x12f114000 -        0x12f11bff7 +com.adobe.InDesign.InCopyWorkflow UI (12.0.0.81 - 0) <69B522C8-D610-30BD-832F-58865C378E66> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopyWorkflow UI.InDesignPlugin/InCopyWorkflow UI
                                                         0x12f126000 -        0x12f12dffb +com.adobe.InDesign.InCopyExportUI (12.0.0.81 - 0) <8A5A058D-F444-358C-AF99-1B990EBB93AD> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopyExportUI.InDesignPlugin/InCopyExpor tUI
                                                         0x12f136000 -        0x12f1c1fff +com.adobe.InDesign.PDF UI (12.0.0.81 - 0) <E06DDBA1-D488-31FD-91B6-99BC6F6ECDFC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/PDF UI.InDesignPlugin/PDF UI
                                                         0x12f1e7000 -        0x12f1f0ff7 +com.adobe.InDesign.JPEG Export UI (12.0.0.81 - 0) <B77D3E9B-C264-3DD0-BD0B-9CD856392D9E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/JPEG Export UI.InDesignPlugin/JPEG Export UI
                                                         0x12f1f9000 -        0x12f212ffb +com.adobe.InDesign.EPS UI (12.0.0.81 - 0) <5FDB513E-635A-3749-B62D-7CFC8654BE95> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/EPS UI.InDesignPlugin/EPS UI
                                                         0x12f223000 -        0x12f22fff3 +com.adobe.InDesign.Clipping Path Dialog (12.0.0.81 - 0) <031FE8FC-DB59-3CFF-AC8D-66C188FC6537> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Clipping Path Dialog.InDesignPlugin/Clipping Path Dialog
                                                         0x12f241000 -        0x12f24cffb +com.adobe.InDesign.Tagged Text Filters UI (12.0.0.81 - 0) <F8A328D0-3CB9-3461-886E-3DC4AE4F4CA5> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Tagged Text Filters UI.InDesignPlugin/Tagged Text Filters UI
                                                         0x12f258000 -        0x12f27dff3 +com.adobe.InDesign.Sangam Preferences UI (12.0.0.81 - 0) <A682D260-3623-3D3B-B261-7A477118A2AE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Sangam Preferences UI.InDesignPlugin/Sangam Preferences UI
                                                         0x12f290000 -        0x12f29affb +com.adobe.InDesign.PNG Import Filter UI (12.0.0.81 - 0) <F1F9D2EC-9223-385E-BF09-4A62EC42A0A2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/PNG Import Filter UI.InDesignPlugin/PNG Import Filter UI
                                                         0x12f2a4000 -        0x12f2adffb +com.adobe.InDesign.Data Services UI (12.0.0.81 - 0) <AAAB33BC-2F83-332F-9788-667A3A1A5166> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Data Services/Data Services UI.InDesignPlugin/Data Services UI
                                                         0x12fbfb000 -        0x12fc24fff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
                                                         0x12fc6c000 -        0x12fc6dff3 +cl_kernels (???) <5455FD47-433A-48AE-8311-425AB5EF828E> cl_kernels
                                                         0x130869000 -        0x13086afe1 +cl_kernels (???) <F7CFFC4B-571D-489B-92E9-34D710C0BA7E> cl_kernels
                                                         0x1333b5000 -        0x133430fcf +MMXCore (17.0.1 - 17.0.1) <A30CB664-C3B8-3FE5-AC64-DFDCBFABA67F> /Applications/Adobe InDesign CC 2017/*/MMXCore.plugin/Contents/MacOS/MMXCore
                                                         0x1334b8000 -        0x13352fffb +MultiProcessor Support (17.0.1 - 17.0.1) <6B9B588B-80C7-3B82-AD28-A3B7D49CF0B0> /Applications/Adobe InDesign CC 2017/*/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
                                                         0x140658000 -        0x140da7ff7 +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 15.0.0.36975) <DE5F440D-4F9E-3D2A-A36D-9DF3B250C5D2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobePDFL.framework/AdobePDFL
                                                         0x140e63000 -        0x140ea9ff3 +com.adobe.InDesign.Font Usage Dialog (12.0.0.81 - 0) <67DFFFFA-AC70-388F-9C7D-34EEEBFD22CD> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Font Usage Dialog.InDesignPlugin/Font Usage Dialog
                                                         0x1458c8000 -        0x145af6ff7 +com.adobe.adobehunspellplugin2 (1.0) <9756F41D-1627-341A-909F-BF697D4C4E7E> /Applications/Adobe InDesign CC 2017/*/AdobeHunspellPlugin.bundle/Contents/MacOS/AdobeHunspellPlugin
                                                         0x14d073000 -        0x14d159fe3  unorm8_rgx.dylib (2.8.5) <DF42F31A-B801-31C1-8133-3F9BEC7529B7> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgx. dylib
                                                      0x7fff98192000 -     0x7fff984cbfff  com.apple.RawCamera.bundle (7.01 - 889) <155ED09B-673E-3726-8302-E54AADAC5B63> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                                                      0x7fff99cfc000 -     0x7fff99ebbffb  com.apple.avfoundation (2.0 - 1187.11.13) <0D0BB4A4-F987-381B-885E-88A81F50FD50> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                                                      0x7fff99ebc000 -     0x7fff99f5ffff  com.apple.audio.AVFAudio (1.0 - ???) <E3CDC215-9272-3F94-8093-865CA181F728> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framewor k/Versions/A/AVFAudio
                                                      0x7fff9a028000 -     0x7fff9a028fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <BDDB2053-BB24-34E4-A452-50D1260BF672> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                                                      0x7fff9a029000 -     0x7fff9a040ff3  libCGInterfaces.dylib (331.5) <4E2DCEFA-F243-3FAE-8BFC-0B349973DD14> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/Libraries/libCGInterfaces.dylib
                                                      0x7fff9a041000 -     0x7fff9a681fe3  com.apple.vImage (8.1 - ???) <77F96C96-725E-31E5-8072-D09C6BD988A2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                                                      0x7fff9a682000 -     0x7fff9a849fef  libBLAS.dylib (1185) <0D55CF73-6DBD-3D15-B500-189479638551> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                                                      0x7fff9a84a000 -     0x7fff9a861fff  libBNNS.dylib (14) <43A9B06E-3C21-3CE6-B0C1-99DA172DEEB0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBNNS.dylib
                                                      0x7fff9a862000 -     0x7fff9ac6dfff  libLAPACK.dylib (1185) <E7AE9C48-6E42-3EB7-A257-D48E0CB48D00> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                                                      0x7fff9ac6e000 -     0x7fff9ac84fff  libLinearAlgebra.dylib (1185) <08F00EFB-B477-3421-906E-3D364E607E6A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
                                                      0x7fff9ac85000 -     0x7fff9ac8bfff  libQuadrature.dylib (3) <120F6228-A3D4-3184-89D7-785ADC2AC715> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libQuadrature.dylib
                                                      0x7fff9ac8c000 -     0x7fff9ac9fff7  libSparseBLAS.dylib (1185) <912E3D25-27C0-3245-B64C-3CAD43A5D633> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
                                                      0x7fff9aca0000 -     0x7fff9adedff7  libvDSP.dylib (600) <87EF1D0A-1F85-31DD-AD8F-AB31E7D8E73B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                                                      0x7fff9adee000 -     0x7fff9aea5fff  libvMisc.dylib (600) <F6EA539E-0A90-3F8A-9ECA-001E46394E29> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                                                      0x7fff9aea6000 -     0x7fff9aea6fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <B4B785D8-CB43-3E5D-AE81-1F27885AA112> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                                                      0x7fff9aea7000 -     0x7fff9aee5ff3  com.apple.Accounts (113 - 113) <E9D296BC-6DAC-3AB2-81A0-8DD6D1F8673B> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
                                                      0x7fff9aee6000 -     0x7fff9b165ff3  com.apple.AddressBook.framework (10.0 - 1756.14.6) <256ECB79-9F16-3565-AADB-D8A7AA83BC2F> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
                                                      0x7fff9b166000 -     0x7fff9bf38ff3  com.apple.AppKit (6.9 - 1504.81.100) <0CCB2E18-076E-3D8A-A777-A6E57EF2570A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                                                      0x7fff9bf39000 -     0x7fff9bf49fff  com.apple.AppleScriptObjC (1.4 - 32) <D697A702-E764-39D3-B5A7-F22E28C268D1> /System/Library/Frameworks/AppleScriptObjC.framework/Versions/A/AppleScriptObjC
                                                      0x7fff9bf4a000 -     0x7fff9bf4afff  com.apple.ApplicationServices (48 - 48) <237200C2-28A6-3C19-B34B-53C953F8AE42> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                                                      0x7fff9bf4b000 -     0x7fff9bfb9ff7  com.apple.ApplicationServices.ATS (377 - 422.2) <3680281F-DB99-3CA2-9C76-CABFC8DBC980> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                                                      0x7fff9c053000 -     0x7fff9c182fff  libFontParser.dylib (194.6) <F3DF2CF7-B25D-30BB-9EE6-1EA9F3B8A066> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                                                      0x7fff9c183000 -     0x7fff9c1cdfff  libFontRegistry.dylib (196.3) <855AF921-EAE0-3D07-B161-5EF09806B643> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                                                      0x7fff9c22a000 -     0x7fff9c25dff7  libTrueTypeScaler.dylib (194.6) <D0D7DA50-DF52-3D24-AFD2-03B336AA1929> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
                                                      0x7fff9c2c9000 -     0x7fff9c373ff7  com.apple.ColorSync (4.12.0 - 502.1) <5F244DE3-A6E8-335F-AE3B-25F0E407DD62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                                                      0x7fff9c374000 -     0x7fff9c3c4ff7  com.apple.HIServices (1.22 - 591) <34C950CC-1084-354A-BCE6-9396EDB29DF8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                                                      0x7fff9c3c5000 -     0x7fff9c3d4ff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <47D1A017-91A4-37F3-93E0-3923CD6ED2DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                                                      0x7fff9c3d5000 -     0x7fff9c422fff  com.apple.print.framework.PrintCore (12 - 491) <B7CC15C1-AF50-37F3-8AF6-65F8CDC323F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                                                      0x7fff9c423000 -     0x7fff9c45efff  com.apple.QD (3.12 - 310) <8F718290-DD82-36CE-9AF0-EFB6D31A49F4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                                                      0x7fff9c45f000 -     0x7fff9c46aff7  com.apple.speech.synthesis.framework (6.3.3 - 6.3.3) <629831B1-B13C-30F5-AE16-6BB9037E3753> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                                                      0x7fff9c46b000 -     0x7fff9c67bfff  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <A1B98513-C19E-376F-8DAF-71BB2F263C5F> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                                                      0x7fff9c67c000 -     0x7fff9c67cfff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <55C6A958-D52B-3D81-B230-EB949212B5D9> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                                                      0x7fff9c7e5000 -     0x7fff9cbb8ff7  com.apple.CFNetwork (807.2.14 - 807.2.14) <9702C8B9-2984-3DD9-9C59-A83499C2DBC4> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                                                      0x7fff9cbd2000 -     0x7fff9cbd2fff  com.apple.Carbon (154 - 157) <1BF9C0EB-45A0-3584-85DC-F64A9914F40D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                                                      0x7fff9cbd3000 -     0x7fff9cbd6fff  com.apple.CommonPanels (1.2.6 - 98) <6A71E8CB-3BF7-3A49-A5F7-0579BAE1219D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                                                      0x7fff9cbd7000 -     0x7fff9cedfff7  com.apple.HIToolbox (2.1.1 - 856.13) <98D5D2A7-55A6-31A7-9056-CC48EBB16654> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                                                      0x7fff9cee0000 -     0x7fff9cee3ff7  com.apple.help (1.3.5 - 49) <27C5F9FE-838F-3807-A4AC-D99470185B10> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                                                      0x7fff9cee4000 -     0x7fff9cee9fff  com.apple.ImageCapture (9.0 - 9.0) <E3E757FD-4060-33A4-A2AC-85EFBD987FCE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                                                      0x7fff9ceea000 -     0x7fff9cf81ff3  com.apple.ink.framework (10.9 - 219) <B44BA36D-7549-3EB2-8CF6-E171885194FB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                                                      0x7fff9cf82000 -     0x7fff9cf9cfff  com.apple.openscripting (1.7 - 172) <B204BF70-C4AA-3699-8493-66E6645A92A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                                                      0x7fff9cf9d000 -     0x7fff9cf9eff3  com.apple.print.framework.Print (12 - 267) <CA7E9448-0903-34C8-AAF6-9070B52BF70E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                                                      0x7fff9cf9f000 -     0x7fff9cfa1ff7  com.apple.securityhi (9.0 - 55006) <ACD20DC1-FBDE-3E1B-91BF-867FE7849CBC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                                                      0x7fff9cfa2000 -     0x7fff9cfa8ff7  com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <A20B0F7B-C32A-3FF1-BB75-BAC0EE4EF889> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                                                      0x7fff9cfa9000 -     0x7fff9d086ff7  com.apple.cloudkit.CloudKit (643.5 - 643.5) <2AB1D950-7EA5-359C-B17C-42AEFE99D360> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
                                                      0x7fff9d087000 -     0x7fff9d087fff  com.apple.Cocoa (6.11 - 22) <CF1AD0E9-2257-35FE-B719-760B58E405C9> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                                                      0x7fff9d1c7000 -     0x7fff9d257ff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <A38A11A5-130B-39CE-BEBA-F5427F6801DC> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                                                      0x7fff9d258000 -     0x7fff9d26bfff  com.apple.CoreBluetooth (1.0 - 1) <76AFC4B4-A9FD-3434-B168-90087E71F5C4> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
                                                      0x7fff9d26c000 -     0x7fff9d56afff  com.apple.CoreData (120 - 752.8) <694F9EA9-A785-3F84-8EB1-DAF76E3BDF9B> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                                                      0x7fff9d56b000 -     0x7fff9d5f7fff  com.apple.CoreDisplay (1.0 - 1) <48B568C0-1E12-34F4-943D-EAB447FBA1BE> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
                                                      0x7fff9d5f8000 -     0x7fff9da8cff7  com.apple.CoreFoundation (6.9 - 1348.28) <0F1FAA52-1C06-327E-A170-382B48B1846D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                                      0x7fff9da8d000 -     0x7fff9e130ff7  com.apple.CoreGraphics (2.0 - 1070.13.2) <ACB5545C-FE91-36C9-8F02-87DF6904A911> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                                                      0x7fff9e131000 -     0x7fff9e373fff  com.apple.CoreImage (12.2.0 - 451.3.1) <CDAD60F3-74F6-3EA5-A8B5-B42476E350FD> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
                                                      0x7fff9e374000 -     0x7fff9e3daff7  com.apple.corelocation (2100.5.34) <64E3F80C-E0FC-309D-B70D-0D0EC002CA70> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
                                                      0x7fff9e3db000 -     0x7fff9e48bfff  com.apple.CoreMedia (1.0 - 1907.15.15) <B5B8C128-C1C2-3585-9B43-41141B2C6332> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                                                      0x7fff9e48c000 -     0x7fff9e4d7ff7  com.apple.CoreMediaIO (804.0 - 4929) <54CF2AD2-4928-3A41-9F7D-F135A8A616D1> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                                                      0x7fff9e4d8000 -     0x7fff9e4d8fff  com.apple.CoreServices (775.9.7 - 775.9.7) <A5C444F3-408B-3062-AF4B-BF8CD919F221> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                                                      0x7fff9e4d9000 -     0x7fff9e52afff  com.apple.AE (712.2 - 712.2) <342A13C0-4A6A-3947-B66B-0F624A4A7B52> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                                                      0x7fff9e52b000 -     0x7fff9e806ff7  com.apple.CoreServices.CarbonCore (1159.5 - 1159.5) <11CC2194-0C9C-397A-B7F9-CDAB9B68D87D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                                                      0x7fff9e807000 -     0x7fff9e83afff  com.apple.DictionaryServices (1.2 - 274) <864F3808-FFDD-3C4B-A5B7-F1A6C4668A86> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                                                      0x7fff9e83b000 -     0x7fff9e843ffb  com.apple.CoreServices.FSEvents (1230 - 1230) <13A2FC17-8F8C-35BF-9584-59FDFB738E2B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
                                                      0x7fff9e844000 -     0x7fff9e9b0ff7  com.apple.LaunchServices (775.9.7 - 775.9.7) <E350E4F6-822A-3F04-B59B-468A39AF5C64> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                                                      0x7fff9e9b1000 -     0x7fff9ea61fff  com.apple.Metadata (10.7.0 - 1075.28) <DBB524CD-6938-3623-99C2-4B1EC1E1BE58> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                                                      0x7fff9ea62000 -     0x7fff9eac1fff  com.apple.CoreServices.OSServices (775.9.7 - 775.9.7) <E9625B0B-9AE7-3024-9FEF-FEE0A1876D9D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                                                      0x7fff9eac2000 -     0x7fff9eb32fff  com.apple.SearchKit (1.4.0 - 1.4.0) <F1B3EF8D-E820-317C-AC7F-8F056C246874> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                                                      0x7fff9eb33000 -     0x7fff9eb79ff7  com.apple.coreservices.SharedFileList (38 - 38) <E1400999-1F08-35A1-9D07-27D80A2AF89A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
                                                      0x7fff9ec06000 -     0x7fff9ed52ff7  com.apple.CoreText (352.0 - 544.5) <E90EA1D8-3491-3014-9043-9928C4E4349C> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                                                      0x7fff9ed53000 -     0x7fff9ed88fff  com.apple.CoreVideo (1.8 - 234.0) <48C31E93-87C2-31F4-97E7-9E54C1EA8E7D> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                                                      0x7fff9ed89000 -     0x7fff9edfaffb  com.apple.framework.CoreWLAN (11.0 - 1200.25.1) <BEBE9C03-3B9A-3948-99E3-CC8148FA2AB5> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                                                      0x7fff9ee2e000 -     0x7fff9ee39ff3  com.apple.DirectoryService.Framework (10.12 - 194) <0FCEF02A-EA92-358C-9877-414E75E0AA32> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
                                                      0x7fff9ee3a000 -     0x7fff9eef8ff7  com.apple.DiscRecording (9.0.3 - 9030.4.5) <4A3165EA-9CC2-3B06-84FF-953C3FE9D812> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
                                                      0x7fff9eef9000 -     0x7fff9eefefff  com.apple.DiskArbitration (2.7 - 2.7) <16EA6D93-A2EC-31DB-BF52-C4764E7B1630> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                                                      0x7fff9f08d000 -     0x7fff9f434ff3  com.apple.Foundation (6.9 - 1349.25) <D820A498-2E62-367D-BC72-5845B14C06E3> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                                                      0x7fff9f460000 -     0x7fff9f491fff  com.apple.GSS (4.0 - 2.0) <95FAD1F9-1610-3428-B9B4-D32F67C26574> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                                                      0x7fff9f551000 -     0x7fff9f5f4ffb  com.apple.Bluetooth (5.0.3 - 5.0.3f1) <CCB4E097-1ED0-3439-8450-2B6EFFBC4608> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
                                                      0x7fff9f5f5000 -     0x7fff9f68aff7  com.apple.framework.IOKit (2.0.2 - 1324.30.13) <163BE7FA-B29A-348F-8B5F-E301F2E8C964> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                                                      0x7fff9f68b000 -     0x7fff9f691ffb  com.apple.IOSurface (153.3 - 153.3) <3DD3BF22-0800-31F2-B179-87F87D6F0548> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                                                      0x7fff9f692000 -     0x7fff9f6e2ff3  com.apple.ImageCaptureCore (7.0 - 7.0) <0F899C07-AA23-350E-8670-9090924D670D> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                                                      0x7fff9f6e3000 -     0x7fff9f83fff7  com.apple.ImageIO.framework (3.3.0 - 1582) <A9A63D25-DA38-33C0-98C6-F015952568B2> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                                                      0x7fff9f840000 -     0x7fff9f844fff  libGIF.dylib (1582) <B0435621-A64F-3E0E-AC03-35ED505A61B1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                                                      0x7fff9f845000 -     0x7fff9f936fff  libJP2.dylib (1582) <396280DF-6E69-38A5-883D-1EEBAC80771B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                                                      0x7fff9f937000 -     0x7fff9f95afff  libJPEG.dylib (1582) <E2A44AAD-F6E0-3D74-80AE-BF2542AA6954> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                                                      0x7fff9f95b000 -     0x7fff9f981fff  libPng.dylib (1582) <FB81BC9C-5BB7-373F-8464-C41A780F762A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                                                      0x7fff9f982000 -     0x7fff9f984ff3  libRadiance.dylib (1582) <825BE3AF-BB9D-3B84-8EFF-8F5FE4C837B8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                                                      0x7fff9f985000 -     0x7fff9f9defff  libTIFF.dylib (1582) <8C24B061-762D-3EC8-AC64-4961C030D575> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                                                      0x7fff9fb0a000 -     0x7fffa05adff7  com.apple.JavaScriptCore (12602 - 12602.4.8) <4FF12BFD-CD3B-33D7-B844-85234A13BD42> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                                                      0x7fffa05ae000 -     0x7fffa05c7ff7  com.apple.Kerberos (3.0 - 1) <49DCBE1A-130C-3FBF-AAEA-AF9A518913AC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                                                      0x7fffa05c8000 -     0x7fffa05fefff  com.apple.LDAPFramework (2.4.28 - 194.5) <0F18D033-BBD8-3D88-A17C-EC7E796CA88F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                                                      0x7fffa0854000 -     0x7fffa085afff  com.apple.MediaAccessibility (1.0 - 97.1.1) <1025DB59-18DE-39EA-9C04-35CE8D6103E5> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
                                                      0x7fffa0870000 -     0x7fffa0dc4fff  com.apple.MediaToolbox (1.0 - 1907.15.15) <22150DE7-8CD3-30DD-8C0F-3D06F865C186> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                                                      0x7fffa0dc5000 -     0x7fffa0e1dfff  com.apple.Metal (86.18 - 86.18) <7DFE0437-25A8-3E87-8318-91573C895742> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
                                                      0x7fffa16f1000 -     0x7fffa16f9fff  com.apple.NetFS (6.0 - 4.0) <6614F9B8-0861-338B-8FF0-8E402F96141C> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                                                      0x7fffa18ce000 -     0x7fffa18d6ff7  libcldcpuengine.dylib (2.8.5) <341EBC48-CCF4-3292-9097-F61715AC573E> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
                                                      0x7fffa18d7000 -     0x7fffa19bdfff  unorm8_bgra.dylib (2.8.5) <1A39075B-6717-3FA5-A712-7F37583DB709> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra .dylib
                                                      0x7fffa19be000 -     0x7fffa1a9efe7  unorm8_rgba.dylib (2.8.5) <26AFDFC2-CF2F-3F73-986E-72F659216AB1> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba .dylib
                                                      0x7fffa1a9f000 -     0x7fffa1aedff3  com.apple.opencl (2.8.6 - 2.8.6) <553BFCCA-5ACB-3DB0-B958-4BF2DE91838F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                                                      0x7fffa1aee000 -     0x7fffa1b07ffb  com.apple.CFOpenDirectory (10.12 - 194) <88E97774-6767-3A01-808B-C923F9310E20> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                                                      0x7fffa1b08000 -     0x7fffa1b13ff7  com.apple.OpenDirectory (10.12 - 194) <0E4E32DD-6592-3860-9793-BAED6915AE0D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                                                      0x7fffa1b14000 -     0x7fffa1b16fff  libCVMSPluginSupport.dylib (13.0.10) <43D037C3-9254-3601-9F5B-CD637D517758> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                                                      0x7fffa1b17000 -     0x7fffa1b1aff7  libCoreFSCache.dylib (151.1) <1910EF80-DE30-3817-8FDF-63F3C8B4BA37> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
                                                      0x7fffa1b1b000 -     0x7fffa1b1efff  libCoreVMClient.dylib (151.1) <8C8E9295-1918-3763-A0B7-6397EB181EF4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                                                      0x7fffa1b1f000 -     0x7fffa1b27ffb  libGFXShared.dylib (13.0.10) <52E92D3C-25EA-31F9-9885-DC0D886D9143> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                                                      0x7fffa1b28000 -     0x7fffa1b33fff  libGL.dylib (13.0.10) <B40728B5-13D2-3423-9C39-885B1098698D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                                                      0x7fffa1b34000 -     0x7fffa1b70fe7  libGLImage.dylib (13.0.10) <3E856113-9217-3B13-98AD-4D0D356931B6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                                                      0x7fffa1b71000 -     0x7fffa1ce7ffb  libGLProgrammability.dylib (13.0.10) <4C3FD24A-1C43-343E-8EBA-BE1FDCE3F74C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                                                      0x7fffa1ce8000 -     0x7fffa1d28ff3  libGLU.dylib (13.0.10) <BBCAA457-BA34-3D13-8845-803C63960E08> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                                                      0x7fffa2690000 -     0x7fffa269efff  com.apple.opengl (13.0.10 - 13.0.10) <B11A2E1B-4B1D-3ECD-BADA-3508BE5775BF> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                                                      0x7fffa269f000 -     0x7fffa2845fff  GLEngine (13.0.10) <62CCEC13-1EB3-3A65-9224-3DCD2838E0C7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
                                                      0x7fffa2846000 -     0x7fffa2870ffb  GLRendererFloat (13.0.10) <E508ABC7-3E67-3845-989F-5B764D36FE12> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
                                                      0x7fffa2909000 -     0x7fffa2a50fff  com.apple.QTKit (7.7.3 - 2978.3) <665AF577-900D-349E-B1C5-D5BDD70DB481> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                                                      0x7fffa2a51000 -     0x7fffa2cbbff7  com.apple.imageKit (3.0 - 1021) <5D77D4A4-F844-376B-93AA-F9CB55C719AE> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
                                                      0x7fffa2cbc000 -     0x7fffa2d80fff  com.apple.PDFKit (1.0 - 1) <7375423F-5815-36C5-A345-546843827588> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
                                                      0x7fffa2d81000 -     0x7fffa32a7fff  com.apple.QuartzComposer (5.1 - 351.1) <A13FD5C2-36D1-3B92-88E6-AB4CAF733907> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
                                                      0x7fffa32a8000 -     0x7fffa32cbffb  com.apple.quartzfilters (1.10.0 - 1.10.0) <8A8ED06E-3A07-312A-A976-982C51159A45> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
                                                      0x7fffa32cc000 -     0x7fffa33b9fff  com.apple.QuickLookUIFramework (5.0 - 720.5) <85A0BF0F-94B1-33CD-A3DC-4048380A3258> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
                                                      0x7fffa33ba000 -     0x7fffa33bafff  com.apple.quartzframework (1.5 - 21) <DA6924FE-3D6C-3CCE-9CB6-188B6B1671DD> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                                                      0x7fffa33bb000 -     0x7fffa35b6ff7  com.apple.QuartzCore (1.11 - 449.41.15) <3CD775C0-683D-3B4E-8EC2-AB1DAC4C3AE9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                                                      0x7fffa35b7000 -     0x7fffa360cfff  com.apple.QuickLookFramework (5.0 - 720.5) <9E76504A-B17B-3302-82DF-9CE1CB31CAC3> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                                                      0x7fffa360d000 -     0x7fffa3620ff7  com.apple.SafariServices.framework (12602 - 12602.4.8) <D88756B5-91A1-3EE8-B69D-F9CE206DBB14> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
                                                      0x7fffa3b1c000 -     0x7fffa3e3bfff  com.apple.security (7.0 - 57740.31.2) <A47D7BAE-0591-3184-8E44-FB2EB08A19C2> /System/Library/Frameworks/Security.framework/Versions/A/Security
                                                      0x7fffa3e3c000 -     0x7fffa3eb2ff7  com.apple.securityfoundation (6.0 - 55132.20.1) <9407620B-B230-3320-B0B7-5AE59F1D135C> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                                                      0x7fffa3eb3000 -     0x7fffa3edbff7  com.apple.securityinterface (10.0 - 55079.30.2) <D5B9D6B0-E3D6-32A7-ABAB-3F005B3ED81D> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
                                                      0x7fffa3edc000 -     0x7fffa3edfff3  com.apple.xpc.ServiceManagement (1.0 - 1) <4E24C12E-6164-3A7A-8EB8-C2523492BAE8> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                                                      0x7fffa4266000 -     0x7fffa42d7ff7  com.apple.SystemConfiguration (1.14 - 1.14) <D9A57D90-E54F-3E1A-AA2F-F5A694BCE4BB> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                                                      0x7fffa42d8000 -     0x7fffa4685fff  com.apple.VideoToolbox (1.0 - 1907.15.15) <685B6CCD-3027-3D0F-8B31-2388A3CE1BDC> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                                                      0x7fffa4686000 -     0x7fffa58bfff3  com.apple.WebCore (12602 - 12602.4.8) <2128FC8F-DFC5-350C-8E0B-E3CA6849AC6C> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
                                                      0x7fffa58c0000 -     0x7fffa5a2aff3  com.apple.WebKitLegacy (12602 - 12602.4.8) <83C97613-16F4-3BEF-B5D9-B7F69B10BBB3> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/ Versions/A/WebKitLegacy
                                                      0x7fffa5a2b000 -     0x7fffa5d9dffb  com.apple.WebKit (12602 - 12602.4.8) <04045E4A-16B0-308A-B27B-9E4DAFB12D8B> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
                                                      0x7fffa61a1000 -     0x7fffa61a7ff7  com.apple.APFS (1.0 - 1) <7846BAA7-F9FD-3110-8DCB-C6DFAA86F7B0> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
                                                      0x7fffa6911000 -     0x7fffa692cff3  com.apple.AppContainer (4.0 - 307.30.3) <EF4C3C83-6F51-38F7-A3D2-2D46EE4560EB> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
                                                      0x7fffa692d000 -     0x7fffa693aff3  com.apple.AppSandbox (4.0 - 307.30.3) <D2C978EB-F4F1-3E79-9DB1-BEE2A92590CE> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
                                                      0x7fffa693b000 -     0x7fffa695dffb  com.apple.framework.Apple80211 (12.0 - 1200.41) <360012DB-DAE7-3EEF-85F0-E5BE1DE3425D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                                                      0x7fffa695e000 -     0x7fffa696dfdb  com.apple.AppleFSCompression (88 - 1.0) <B6E2148F-BFBF-3F1B-A7DF-0F39190B4C20> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
                                                      0x7fffa6a5a000 -     0x7fffa6ae597f  com.apple.AppleJPEG (1.0 - 1) <B4C3209B-58A5-359F-A898-F61B6C40E5E9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
                                                      0x7fffa6af9000 -     0x7fffa6b14fff  com.apple.aps.framework (4.0 - 4.0) <D7BF6782-5E35-3A0E-9412-99C2B22F17E9> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
                                                      0x7fffa6b15000 -     0x7fffa6b1dffb  com.apple.AppleSRP (5.0 - 1) <F105D2D2-8A12-3361-9C9D-E405668CAF75> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
                                                      0x7fffa6b1e000 -     0x7fffa6b21ff3  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <6FF50E26-5BDA-3421-BDAE-B57AE6E4F6AC> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
                                                      0x7fffa6b22000 -     0x7fffa6b74fff  com.apple.AppleVAFramework (5.0.34 - 5.0.34) <2AA15DE0-9A7E-3CC0-988A-3BB080A8F603> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                                                      0x7fffa6b7d000 -     0x7fffa6b84ffb  com.apple.AssetCacheServices (31.2 - 31.2) <5E08DBDE-1DF0-37AC-9ED0-035A2ED67573> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServi ces
                                                      0x7fffa6f0a000 -     0x7fffa6f88fff  com.apple.backup.framework (1.8.3 - 1.8.3) <B2E28A7A-1727-3052-AA73-CBC108286C07> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                                                      0x7fffa6fb1000 -     0x7fffa6feeff7  com.apple.bom (14.0 - 193.8) <FAA5CE82-0A87-34C5-A606-81A179009930> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
                                                      0x7fffa722c000 -     0x7fffa7258fff  com.apple.CacheDelete (1.0 - 1) <74C78009-7CC8-366B-8673-3D698AC1C307> /System/Library/PrivateFrameworks/CacheDelete.framework/Versions/A/CacheDelete
                                                      0x7fffa7622000 -     0x7fffa7649fff  com.apple.CalendarAgentLink (8.0 - 250) <884AE0DB-A1AF-3D0D-BFA6-19C6D47E0009> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLin k
                                                      0x7fffa7c0e000 -     0x7fffa7c35ffb  com.apple.ChunkingLibrary (172 - 172) <83E91936-305D-32A4-A256-5582B96B1852> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                                                      0x7fffa7c36000 -     0x7fffa7cc8ff7  com.apple.CloudDocs (1.0 - 485.12) <42A562A2-284D-3252-9341-855E52E45A02> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
                                                      0x7fffa855e000 -     0x7fffa8567ffb  com.apple.CommonAuth (4.0 - 2.0) <830B940B-3523-38DE-996D-695739616D10> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                                                      0x7fffa862e000 -     0x7fffa867eff3  com.apple.AddressBook.ContactsFoundation (8.0 - 2250.2.2) <96696447-7484-34C8-A838-9BD28687D17F> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundat ion
                                                      0x7fffa867f000 -     0x7fffa86a1fff  com.apple.contacts.ContactsPersistence (1.0 - 2250.2.2) <12AB8AA1-7F0C-3BE3-B6C6-2A4822948E58> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersis tence
                                                      0x7fffa86eb000 -     0x7fffa8ac8fe7  com.apple.CoreAUC (224.0.0 - 224.0.0) <8DF6075A-0711-33A9-9031-6FDA22E85C4F> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                                                      0x7fffa8ac9000 -     0x7fffa8af9fff  com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <5E1B0512-E50B-3534-99EF-AD15E601877A> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
                                                      0x7fffa8b6f000 -     0x7fffa8b77ffb  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <212D3DB2-DC44-329F-B810-238DF156D1EE> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
                                                      0x7fffa8c87000 -     0x7fffa8c97fff  com.apple.CoreEmoji (1.0 - 39.1) <0A46D6BF-22F3-39AD-B3DC-DE1EE5C442CC> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
                                                      0x7fffa8d4c000 -     0x7fffa8d62ff3  com.apple.CoreMediaAuthoring (2.2 - 955) <3E1E33F1-B4FF-320E-B336-7E7F74D73642> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                                                      0x7fffa8d69000 -     0x7fffa8df9ffb  com.apple.CorePDF (4.0 - 4) <254118BE-2E30-3772-B425-6328D1487162> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
                                                      0x7fffa8f7a000 -     0x7fffa8faaff3  com.apple.CoreServicesInternal (276.2 - 276.2) <7D8DEF04-72F1-39F4-BBFB-09E65D7B8C10> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                                                      0x7fffa923a000 -     0x7fffa92c4fff  com.apple.CoreSymbolication (61050) <F4B7C798-F7B7-3977-AA08-59A03F00308E> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                                                      0x7fffa92c5000 -     0x7fffa9403fd7  com.apple.coreui (2.1 - 430.6) <99D08D71-3E9D-300C-9EB2-A73F1B5E228C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                                                      0x7fffa9404000 -     0x7fffa94b4ff3  com.apple.CoreUtils (5.0 - 500.9) <5567181B-721C-339E-A3DC-579E36D92341> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
                                                      0x7fffa9504000 -     0x7fffa9569ff3  com.apple.framework.CoreWiFi (12.0 - 1200.25.1) <BEFA276C-D284-3160-8641-7DD47E38C9D7> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                                                      0x7fffa956a000 -     0x7fffa9577ff7  com.apple.CrashReporterSupport (10.12 - 817) <CB5251B1-5BE5-308B-B30B-0050065E04CC> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                                                      0x7fffa9578000 -     0x7fffa95e8ff7  com.apple.DCERPC (2.0 - 63) <78FF4D39-6484-3405-ACAE-ED64C20ACECA> /System/Library/PrivateFrameworks/DCERPC.framework/Versions/A/DCERPC
                                                      0x7fffa95e9000 -     0x7fffa95f3ff7  com.apple.framework.DFRFoundation (1.0 - 104.14) <258B6CFE-FD64-31C5-9973-2FD80597ECDA> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
                                                      0x7fffa95f4000 -     0x7fffa9628ff3  com.apple.datadetectors (5.0 - 348.2.1) <B16D1182-DF2D-3C7A-BF1F-36717BD1955F> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
                                                      0x7fffa9629000 -     0x7fffa96a0ff7  com.apple.datadetectorscore (7.0 - 539.1) <E9892E38-3D5F-36CF-BDC5-E4E3C5516B55> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                                                      0x7fffa96dd000 -     0x7fffa971cfff  com.apple.DebugSymbols (137 - 137) <B229F3F7-250B-3151-8048-CEA7BF80FA52> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                                                      0x7fffa971d000 -     0x7fffa982efff  com.apple.desktopservices (1.11.3 - 1.11.3) <CCE689AA-85F3-3587-AE12-1231E8ED127E> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                                                      0x7fffa9833000 -     0x7fffa9909ff7  com.apple.DiskImagesFramework (444.41.1 - 444.41.1) <DEE2D0A1-D1E6-333F-AF76-DEEA48426760> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
                                                      0x7fffa996e000 -     0x7fffa9978ff7  com.apple.DisplayServicesFW (3.1 - 380) <A1B8B6C2-5782-3D5C-B54E-48E96BB807DA> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
                                                      0x7fffa99bd000 -     0x7fffa99bfffb  com.apple.EFILogin (2.0 - 2) <E03C6225-7650-3498-906B-C248A93F55B5> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
                                                      0x7fffa9b12000 -     0x7fffa9f43ff7  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <DEB42099-6927-332C-8D3E-D45096318D25> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
                                                      0x7fffa9f81000 -     0x7fffaa311fff  com.apple.FinderKit (1.5.3 - 1.5.3) <DAC122BE-B0CB-3BCB-830A-196A46D49696> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
                                                      0x7fffab298000 -     0x7fffab298fff  libmetal_timestamp.dylib (600.0.48.32) <31DF1B9E-0BBF-308B-B78D-11CCE72DAA68> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
                                                      0x7fffab2a5000 -     0x7fffab2b0ff3  libGPUSupportMercury.dylib (13.0.10) <7CC5CEF8-D132-3234-A078-6D080DFC599F> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
                                                      0x7fffab564000 -     0x7fffab580ff3  com.apple.GenerationalStorage (2.0 - 259.2) <00BF8427-967F-3693-A86F-DA0F29B49BF3> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                                                      0x7fffab599000 -     0x7fffabc38fff  com.apple.GeoServices (1.0 - 1228.22.8.29.13) <280AEA5E-2EF5-3A88-B1DE-D0811045F9CC> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
                                                      0x7fffabc7e000 -     0x7fffabcf4fff  com.apple.Heimdal (4.0 - 2.0) <00F00E7E-7EF4-3254-86D3-ADA4F67938CF> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                                                      0x7fffabcf5000 -     0x7fffabd06fff  com.apple.HelpData (2.1.11 - 100) <86213EE9-C049-3084-8824-2A17A8DE2D6B> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
                                                      0x7fffac317000 -     0x7fffac31effb  com.apple.IOAccelerator (289.32 - 289.32) <6395ACEE-5AD7-3536-AF12-FD6565415D94> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
                                                      0x7fffac320000 -     0x7fffac334ff3  com.apple.IOPresentment (1.0 - 25) <40934217-996A-3DDB-A8C4-484CA0F0222B> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
                                                      0x7fffac335000 -     0x7fffac357fff  com.apple.IconServices (74.3 - 74.3) <3F0BD358-D019-3083-82F2-69CCAD5E5D66> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
                                                      0x7fffac3f3000 -     0x7fffac403ff3  com.apple.IntlPreferences (2.0 - 216) <589A5D92-6809-3F3C-900E-DBC60A07A101> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
                                                      0x7fffac422000 -     0x7fffac42ffff  com.apple.KerberosHelper (4.0 - 1.0) <B4AADAF1-5E4F-3654-8377-045BF992C63C> /System/Library/PrivateFrameworks/KerberosHelper.framework/Versions/A/KerberosHelper
                                                      0x7fffac43a000 -     0x7fffac5f0fff  com.apple.LanguageModeling (1.0 - 123.2.4) <FEB98F96-A9BB-3E6C-85B4-B466825B8C92> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
                                                      0x7fffac620000 -     0x7fffac624ff7  com.apple.LoginUICore (4.0 - 4.0) <95D5E239-C9C9-394D-9848-D76198234F7F> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore. framework/Versions/A/LoginUICore
                                                      0x7fffac6d0000 -     0x7fffac7a1ffb  com.apple.MMCS (1.3 - 381.1) <5582D879-5F26-3552-8E88-58703456EB7A> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
                                                      0x7fffacc4a000 -     0x7fffacc4dfff  com.apple.Mangrove (1.0 - 1) <05039E9F-9C07-375B-A940-D90D455A2EC2> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
                                                      0x7fffacd25000 -     0x7fffacd59ff3  com.apple.MediaKit (16 - 840) <2035FF47-C7E6-3F73-A335-AC0BFBB1DB36> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
                                                      0x7fffaceb4000 -     0x7fffacf2dff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <6A759DBA-B7DF-363B-9827-AB1D1129BB34> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerfo rmanceShaders
                                                      0x7fffad093000 -     0x7fffad09eff3  com.apple.MobileKeyBag (2.0 - 1.0) <8A7EEA75-8334-3FB5-A83B-F0ECB87952B2> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
                                                      0x7fffad0af000 -     0x7fffad0d7fff  com.apple.MultitouchSupport.framework (368.7 - 368.7) <A29E6031-E9A6-353A-BDE5-D8DF20FD393C> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                                                      0x7fffad186000 -     0x7fffad190fff  com.apple.NetAuth (6.0 - 6.0) <1E7765FC-4580-3CE4-A0F1-CAA22006AE43> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                                                      0x7fffad588000 -     0x7fffad58afff  com.apple.OAuth (25 - 25) <1A29AF10-4AFE-32A2-9CA9-A98BACA2CE8D> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
                                                      0x7fffada0c000 -     0x7fffada4dff7  com.apple.PerformanceAnalysis (1.145 - 145) <12640C1F-433D-3CD9-B2A8-048D57B8B56D> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                                                      0x7fffada91000 -     0x7fffada98ff3  com.apple.phonenumbers (1.1.1 - 105) <14003B00-D2DA-3732-A1AC-A71763EC3556> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
                                                      0x7fffae05b000 -     0x7fffae07dff7  com.apple.pluginkit.framework (1.0 - 1) <E41C33BD-8C3F-32B2-A485-A2BFEE148E04> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
                                                      0x7fffae0c4000 -     0x7fffae0efffb  com.apple.ProtectedCloudStorage (1.0 - 1) <4B38E6F6-AD64-3345-B51D-38E9DD518666> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
                                                      0x7fffae0f0000 -     0x7fffae10afff  com.apple.ProtocolBuffer (1 - 249) <D8B7694B-B598-3728-8583-9C4CC0F05B64> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
                                                      0x7fffae10b000 -     0x7fffae11bffb  com.apple.QuickLookThumbnailing (1.0 - 1) <1A91596D-0A8D-3B7A-ACF5-783A78E9723E> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThu mbnailing
                                                      0x7fffae124000 -     0x7fffae147ff3  com.apple.RemoteViewServices (2.0 - 124) <4765DC2E-CF05-38CF-9564-1FBACB7E167C> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                                                      0x7fffae1f0000 -     0x7fffae209fff  com.apple.SMBClient (3.1 - 3.1) <60E0C8F6-EC9D-3049-893D-C8ACDDCA90A0> /System/Library/PrivateFrameworks/SMBClient.framework/Versions/A/SMBClient
                                                      0x7fffaedb3000 -     0x7fffaedb6fff  com.apple.SecCodeWrapper (4.0 - 307.30.3) <1B0B2122-C230-3E3F-8A81-EBD58818586B> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
                                                      0x7fffaee45000 -     0x7fffaeec2ff7  com.apple.Sharing (696.1.22 - 696.1.22) <D0A5C682-8996-3851-B332-AD05301E6FA3> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
                                                      0x7fffaeec3000 -     0x7fffaeee2ff7  com.apple.shortcut (2.16 - 98) <A7D38F28-73EB-3DF5-AE77-A95E4CB60DB9> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
                                                      0x7fffaeee3000 -     0x7fffaf151fff  com.apple.SkyLight (1.600.0 - 122.8) <C65A18FE-3021-38F2-9AA1-9527B0ADD4A2> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
                                                      0x7fffaf332000 -     0x7fffaf33eff7  com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <F9F0FCED-3A72-3639-91F2-B7EF248ED1B9> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
                                                      0x7fffaf6c5000 -     0x7fffaf726fff  com.apple.Suggestions (6.0 - 197) <A202005E-CF88-3F7B-B955-B25FD89EC790> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
                                                      0x7fffafa27000 -     0x7fffafa93ff3  com.apple.Symbolication (61080.2) <27A57DC2-FEB7-3D23-AEB5-E3E76C5AAE79> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                                                      0x7fffafc7d000 -     0x7fffafca9ffb  com.apple.framework.SystemAdministration (1.0 - 1.0) <81B27779-ABCD-35DE-931E-E8BCE07ACFB4> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdminis tration
                                                      0x7fffafe8d000 -     0x7fffafe93ff7  com.apple.TCC (1.0 - 1) <956F7C1A-D457-3FE0-9CFE-3F1719F0865C> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                                                      0x7fffaff22000 -     0x7fffb00eaff7  com.apple.TextureIO (1.41 - 1.41) <3A9D9FD9-8997-3BD1-8046-76D0BF709806> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
                                                      0x7fffb0133000 -     0x7fffb0148ff3  com.apple.ToneKit (1.0 - 1) <0558CDBA-8127-3C55-825E-6F6A464E2FB4> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
                                                      0x7fffb0149000 -     0x7fffb0157ffb  com.apple.ToneLibrary (1.0 - 1) <32AD3F5C-124F-351D-BC9B-63A7AEA20F31> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
                                                      0x7fffb015e000 -     0x7fffb015ffff  com.apple.TrustEvaluationAgent (2.0 - 28) <07C1F711-A1E0-3BAC-8F4D-977516D50925> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                                                      0x7fffb0160000 -     0x7fffb02f0ff3  com.apple.UIFoundation (1.0 - 490.7) <047781ED-9E79-361F-8E04-71FF90C650F3> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
                                                      0x7fffb0d4c000 -     0x7fffb0e0fff7  com.apple.ViewBridge (280 - 280) <6D4F6019-5ECC-377B-AF7D-9796E96841CB> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
                                                      0x7fffb1239000 -     0x7fffb123ffff  com.apple.XPCService (2.0 - 1) <BC3FCE26-6219-3316-949F-37F7005C9A0F> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
                                                      0x7fffb1310000 -     0x7fffb1312ffb  com.apple.loginsupport (1.0 - 1) <4449ACBA-27A8-3311-BD92-CB7E63583FC6> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
                                                      0x7fffb133e000 -     0x7fffb1365ffb  com.apple.contacts.vCard (1.0 - 2250.2.2) <278D1962-FFC8-399C-92FF-1D50383D291F> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
                                                      0x7fffb1367000 -     0x7fffb1382ff7  libCRFSuite.dylib (34) <BACC371B-6153-36B5-BC54-3BCF26FBB221> /usr/lib/libCRFSuite.dylib
                                                      0x7fffb1383000 -     0x7fffb138efff  libChineseTokenizer.dylib (21) <09E74E18-ADB2-30D2-A858-13691CB1186C> /usr/lib/libChineseTokenizer.dylib
                                                      0x7fffb138f000 -     0x7fffb141fff7  libCoreStorage.dylib (540.30.1) <127A0A91-4E62-39A7-B18F-A3E166304505> /usr/lib/libCoreStorage.dylib
                                                      0x7fffb1420000 -     0x7fffb1421ff3  libDiagnosticMessagesClient.dylib (102) <422911A4-E273-3E88-BFC4-DF6470E48242> /usr/lib/libDiagnosticMessagesClient.dylib
                                                      0x7fffb1422000 -     0x7fffb1635fff  libFosl_dynamic.dylib (16.38) <8232FA8A-F16A-3DC0-AE68-B61EFCD5F4A4> /usr/lib/libFosl_dynamic.dylib
                                                      0x7fffb1651000 -     0x7fffb1658fff  libMatch.1.dylib (27) <5D52A207-E2AF-3E05-8C51-91C1D82FCEE8> /usr/lib/libMatch.1.dylib
                                                      0x7fffb1659000 -     0x7fffb1659fff  libOpenScriptingUtil.dylib (172) <D025E180-BB3B-3FFA-98FC-B6835354D723> /usr/lib/libOpenScriptingUtil.dylib
                                                      0x7fffb165a000 -     0x7fffb165eff3  libScreenReader.dylib (477.20.6) <8158E263-B7DF-3B0C-BABE-4FE94A53DFE5> /usr/lib/libScreenReader.dylib
                                                      0x7fffb165f000 -     0x7fffb1660ff3  libSystem.B.dylib (1238) <9CB018AF-54E9-300F-82BE-81FE553C9154> /usr/lib/libSystem.B.dylib
                                                      0x7fffb16cc000 -     0x7fffb16f7ffb  libarchive.2.dylib (41.41.1) <D53F0A5C-7FAA-3FCF-8A27-B7DF032C4221> /usr/lib/libarchive.2.dylib
                                                      0x7fffb16f8000 -     0x7fffb17edfef  libate.dylib (1.12.13) <DD046A96-07D9-3066-8BD6-D0E27FE9E1D3> /usr/lib/libate.dylib
                                                      0x7fffb17f1000 -     0x7fffb17f1ff3  libauto.dylib (187) <5BBF6A00-CC76-389D-84E7-CA88EDADE683> /usr/lib/libauto.dylib
                                                      0x7fffb17f2000 -     0x7fffb1802ff3  libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
                                                      0x7fffb1803000 -     0x7fffb1811ff7  libbz2.1.0.dylib (38) <6FD3B63F-0F86-3A25-BD5B-E243F58792C9> /usr/lib/libbz2.1.0.dylib
                                                      0x7fffb1812000 -     0x7fffb1868ff7  libc+.1.dylib (307.4) <BEE86868-F831-384C-919E-2B286ACFE87C> /usr/lib/libc+.1.dylib
                                                      0x7fffb1869000 -     0x7fffb1893fff  libc+abi.dylib (307.2) <1CEF8ABB-7E6D-3C2F-8E0A-E7884478DD23> /usr/lib/libc+abi.dylib
                                                      0x7fffb1894000 -     0x7fffb18a4ffb  libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
                                                      0x7fffb18a5000 -     0x7fffb18baffb  libcompression.dylib (34) <AEF908E6-C0FE-3884-BD45-FB37A035545D> /usr/lib/libcompression.dylib
                                                      0x7fffb18bb000 -     0x7fffb18bbff7  libcoretls.dylib (121.31.1) <BCC32537-4831-3E9F-876E-8C9F4CF52FD3> /usr/lib/libcoretls.dylib
                                                      0x7fffb18bc000 -     0x7fffb18bdff3  libcoretls_cfhelpers.dylib (121.31.1) <6F37C5AD-7999-3D31-A52F-7AEED935F32D> /usr/lib/libcoretls_cfhelpers.dylib
                                                      0x7fffb1977000 -     0x7fffb1a5cff7  libcrypto.0.9.8.dylib (64.30.2) <D41E1901-06DD-3860-BB4F-B3ACE0284C01> /usr/lib/libcrypto.0.9.8.dylib
                                                      0x7fffb1bee000 -     0x7fffb1bf9fff  libcsfde.dylib (540.30.1) <8E7FAE94-37E0-3181-B2C4-9878FFF63851> /usr/lib/libcsfde.dylib
                                                      0x7fffb1bfa000 -     0x7fffb1c4dff7  libcups.2.dylib (450) <78243BA4-43AB-3364-8111-8D54D3382621> /usr/lib/libcups.2.dylib
                                                      0x7fffb1c4e000 -     0x7fffb1c9effb  libcurl.4.dylib (95.31.1) <F078ABAE-B13D-3436-A3B8-0B3DFFCF090F> /usr/lib/libcurl.4.dylib
                                                      0x7fffb1c9f000 -     0x7fffb1ca6ff3  libdscsym.dylib (145.1) <E121E3BC-D2B7-37C3-86A8-5DFC3ECF94D6> /usr/lib/libdscsym.dylib
                                                      0x7fffb1cc8000 -     0x7fffb1cc8fff  libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
                                                      0x7fffb1cd6000 -     0x7fffb1cd7fff  libffi.dylib (18.1) <49D03682-E111-351C-8266-4519B3B82BE9> /usr/lib/libffi.dylib
                                                      0x7fffb1cd8000 -     0x7fffb1cddff7  libheimdal-asn1.dylib (498.30.1) <4ED9F6E3-83BC-3302-B004-C25399DA0333> /usr/lib/libheimdal-asn1.dylib
                                                      0x7fffb1cde000 -     0x7fffb1dd0ff7  libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
                                                      0x7fffb1dd1000 -     0x7fffb1ff6ffb  libicucore.A.dylib (57149.0.1) <6B5FDA93-AA88-318F-9608-C2A33D602EC7> /usr/lib/libicucore.A.dylib
                                                      0x7fffb1ffc000 -     0x7fffb1ffdfff  liblangid.dylib (126) <3F4530C9-8BE1-3AA7-9A82-98694D240866> /usr/lib/liblangid.dylib
                                                      0x7fffb1ffe000 -     0x7fffb2017ffb  liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
                                                      0x7fffb2018000 -     0x7fffb202eff7  libmarisa.dylib (5) <2183D484-032D-3DE5-8984-3A14006E034E> /usr/lib/libmarisa.dylib
                                                      0x7fffb202f000 -     0x7fffb22d6ff7  libmecabra.dylib (744.5) <EF046855-CB9C-32D8-B2F1-C85B526E386F> /usr/lib/libmecabra.dylib
                                                      0x7fffb2309000 -     0x7fffb2382ff7  libnetwork.dylib (856.30.16) <66C6E4D6-B39C-3309-80C1-CBBE170DDD51> /usr/lib/libnetwork.dylib
                                                      0x7fffb2383000 -     0x7fffb2758127  libobjc.A.dylib (706) <47104A1B-13E8-369F-BC36-27FF465809FD> /usr/lib/libobjc.A.dylib
                                                      0x7fffb2759000 -     0x7fffb275aff7  libodfde.dylib (23) <4DFCC459-2C07-38C6-871F-94DA3677F1EA> /usr/lib/libodfde.dylib
                                                      0x7fffb275b000 -     0x7fffb275ffff  libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
                                                      0x7fffb2760000 -     0x7fffb2790ff7  libpcap.A.dylib (67) <450DB888-2C0C-3085-A5F1-69324DFE902C> /usr/lib/libpcap.A.dylib
                                                      0x7fffb27ae000 -     0x7fffb27caffb  libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
                                                      0x7fffb27cb000 -     0x7fffb2804fff  libsandbox.1.dylib (592.31.1) <0B3D5690-EF2C-39A6-B63C-CFB8CBAC0956> /usr/lib/libsandbox.1.dylib
                                                      0x7fffb2805000 -     0x7fffb2817ffb  libsasl2.2.dylib (209) <5A177BA8-362D-32DA-8D14-69AB191648B3> /usr/lib/libsasl2.2.dylib
                                                      0x7fffb2818000 -     0x7fffb2819ff3  libspindump.dylib (230.3) <59FAC445-F8FB-3881-A69A-FD0E98100E19> /usr/lib/libspindump.dylib
                                                      0x7fffb281a000 -     0x7fffb295bfff  libsqlite3.dylib (253) <AECBC92F-FF00-3369-8ECB-AE053B3578B8> /usr/lib/libsqlite3.dylib
                                                      0x7fffb29b7000 -     0x7fffb2a07fff  libstdc+.6.dylib (104.1) <91F66BFD-F927-301F-B8F3-578A5CEA78F4> /usr/lib/libstdc+.6.dylib
                                                      0x7fffb2a4c000 -     0x7fffb2a4fff7  libutil.dylib (47.30.1) <C29FFC2C-C7F0-39EA-9215-F5A2DCAF570A> /usr/lib/libutil.dylib
                                                      0x7fffb2a50000 -     0x7fffb2a5dfff  libxar.1.dylib (357) <58BFB84B-66FE-3299-AA3D-BBA178ADEE39> /usr/lib/libxar.1.dylib
                                                      0x7fffb2a61000 -     0x7fffb2b50ffb  libxml2.2.dylib (30.11) <E12AF929-0FA5-3214-840F-C81E6AC9F36E> /usr/lib/libxml2.2.dylib
                                                      0x7fffb2b51000 -     0x7fffb2b7afff  libxslt.1.dylib (15.8) <FFF5DD45-F544-34B2-BE3C-DB877DC60081> /usr/lib/libxslt.1.dylib
                                                      0x7fffb2b7b000 -     0x7fffb2b8cff3  libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
                                                      0x7fffb2b9b000 -     0x7fffb2b9fff7  libcache.dylib (79) <0C8092D3-600F-3ADD-A036-F225B6CDCA43> /usr/lib/system/libcache.dylib
                                                      0x7fffb2ba0000 -     0x7fffb2babff7  libcommonCrypto.dylib (60092.30.2) <B16E29B6-EC8D-3A8F-9A89-DD9CF35F7C4B> /usr/lib/system/libcommonCrypto.dylib
                                                      0x7fffb2bac000 -     0x7fffb2bb3fff  libcompiler_rt.dylib (62) <E992E8D9-037C-3454-A366-A25E4D31D6BB> /usr/lib/system/libcompiler_rt.dylib
                                                      0x7fffb2bb4000 -     0x7fffb2bbcfff  libcopyfile.dylib (138) <64E285D9-5485-333B-AEE7-8B0C8FB9275F> /usr/lib/system/libcopyfile.dylib
                                                      0x7fffb2bbd000 -     0x7fffb2c40fdf  libcorecrypto.dylib (442.30.20) <2074B932-FD79-30A9-8E90-AF25C49F2AF1> /usr/lib/system/libcorecrypto.dylib
                                                      0x7fffb2c41000 -     0x7fffb2c73fff  libdispatch.dylib (703.30.5) <EA0CC14E-D559-3802-B4B2-0E8C7579AAC4> /usr/lib/system/libdispatch.dylib
                                                      0x7fffb2c74000 -     0x7fffb2c79ff3  libdyld.dylib (421.2) <6F506653-FFF6-3DB8-84F1-109AE3C52F32> /usr/lib/system/libdyld.dylib
                                                      0x7fffb2c7a000 -     0x7fffb2c7affb  libkeymgr.dylib (28) <1A318923-1200-3B06-B432-5007D82F195D> /usr/lib/system/libkeymgr.dylib
                                                      0x7fffb2c7b000 -     0x7fffb2c87ffb  libkxld.dylib (3789.41.3) <87550136-9353-348B-9CD9-C342B48C5AAF> /usr/lib/system/libkxld.dylib
                                                      0x7fffb2c88000 -     0x7fffb2c88fff  liblaunch.dylib (972.30.7) <15FACC21-079A-3BDF-9AFB-4253EFDEB587> /usr/lib/system/liblaunch.dylib
                                                      0x7fffb2c89000 -     0x7fffb2c8efff  libmacho.dylib (894) <A2F38EC1-C37C-3B93-B0E4-36B07C177F8C> /usr/lib/system/libmacho.dylib
                                                      0x7fffb2c8f000 -     0x7fffb2c91ff3  libquarantine.dylib (85) <C1D7749F-5F5F-3BB9-BEFC-1F0B9DA941FD> /usr/lib/system/libquarantine.dylib
                                                      0x7fffb2c92000 -     0x7fffb2c93ffb  libremovefile.dylib (45) <CD42974E-BE0B-39FC-9BFC-8A7540A04DC6> /usr/lib/system/libremovefile.dylib
                                                      0x7fffb2c94000 -     0x7fffb2cacff7  libsystem_asl.dylib (349.30.2) <EFAC72D7-CB13-3DF7-ADF3-EC6635C6F1EA> /usr/lib/system/libsystem_asl.dylib
                                                      0x7fffb2cad000 -     0x7fffb2cadff7  libsystem_blocks.dylib (67) <B8C3701D-5A91-3D35-999D-2DC8D5393525> /usr/lib/system/libsystem_blocks.dylib
                                                      0x7fffb2cae000 -     0x7fffb2d3bfef  libsystem_c.dylib (1158.30.7) <2F881962-03CB-3B9D-A782-D98C1BBA4E3D> /usr/lib/system/libsystem_c.dylib
                                                      0x7fffb2d3c000 -     0x7fffb2d3fffb  libsystem_configuration.dylib (888.30.2) <4FE3983C-E4ED-3939-A578-03AD29C99788> /usr/lib/system/libsystem_configuration.dylib
                                                      0x7fffb2d40000 -     0x7fffb2d43fff  libsystem_coreservices.dylib (41.4) <1A572B9E-0C47-320F-8C64-7990D0A5FB5A> /usr/lib/system/libsystem_coreservices.dylib
                                                      0x7fffb2d44000 -     0x7fffb2d5cff3  libsystem_coretls.dylib (121.31.1) <4676F06D-274D-31BE-B61C-4D7A4AEF4858> /usr/lib/system/libsystem_coretls.dylib
                                                      0x7fffb2d5d000 -     0x7fffb2d63fff  libsystem_dnssd.dylib (765.30.11) <DC708D84-ED7D-3936-B996-A67C66B8DDAA> /usr/lib/system/libsystem_dnssd.dylib
                                                      0x7fffb2d64000 -     0x7fffb2d8dff7  libsystem_info.dylib (503.30.1) <9ED9121C-F111-3FAD-BC2F-C95DEE1C9362> /usr/lib/system/libsystem_info.dylib
                                                      0x7fffb2d8e000 -     0x7fffb2db0ff7  libsystem_kernel.dylib (3789.41.3) <B75B128C-7D7A-3318-91CD-82B5A69C5329> /usr/lib/system/libsystem_kernel.dylib
                                                      0x7fffb2db1000 -     0x7fffb2df8fe7  libsystem_m.dylib (3121.4) <266DB92B-A86F-3691-80FB-1B26AD73CFF3> /usr/lib/system/libsystem_m.dylib
                                                      0x7fffb2df9000 -     0x7fffb2e17ff7  libsystem_malloc.dylib (116.30.3) <F40DEE3B-386A-3529-A3F7-98117ED55BF4> /usr/lib/system/libsystem_malloc.dylib
                                                      0x7fffb2e18000 -     0x7fffb2e6fffb  libsystem_network.dylib (856.30.16) <4AE368E9-605D-379D-B04C-2AC7455B8250> /usr/lib/system/libsystem_network.dylib
                                                      0x7fffb2e70000 -     0x7fffb2e79ff3  libsystem_networkextension.dylib (563.30.15) <EB020B0C-7DF0-3EEF-8E3C-15DA3C01D687> /usr/lib/system/libsystem_networkextension.dylib
                                                      0x7fffb2e7a000 -     0x7fffb2e83ff3  libsystem_notify.dylib (165.20.1) <E7FD3A7C-DD07-36E2-9FA4-7561F9F114DA> /usr/lib/system/libsystem_notify.dylib
                                                      0x7fffb2e84000 -     0x7fffb2e8cfe7  libsystem_platform.dylib (126.1.2) <3CA06D4E-C00A-36DE-AA65-3A390097D1F6> /usr/lib/system/libsystem_platform.dylib
                                                      0x7fffb2e8d000 -     0x7fffb2e97ff7  libsystem_pthread.dylib (218.30.1) <C869ED7C-BE29-3532-8E69-3A8DA1447EDC> /usr/lib/system/libsystem_pthread.dylib
                                                      0x7fffb2e98000 -     0x7fffb2e9bff7  libsystem_sandbox.dylib (592.31.1) <7BBFDF96-293F-3DD9-B3A4-7C168280B441> /usr/lib/system/libsystem_sandbox.dylib
                                                      0x7fffb2e9c000 -     0x7fffb2e9dfff  libsystem_secinit.dylib (24) <5C1F1E47-0F7D-3E25-8DEB-D9DB1F902281> /usr/lib/system/libsystem_secinit.dylib
                                                      0x7fffb2e9e000 -     0x7fffb2ea5fff  libsystem_symptoms.dylib (532.30.6) <5D990CF5-B58F-39F7-B375-99B4EC62CFBD> /usr/lib/system/libsystem_symptoms.dylib
                                                      0x7fffb2ea6000 -     0x7fffb2ec6ff7  libsystem_trace.dylib (518.30.7) <6D34D1EA-2A3C-3D2D-803E-A666E6AEEE52> /usr/lib/system/libsystem_trace.dylib
                                                      0x7fffb2ec7000 -     0x7fffb2eccffb  libunwind.dylib (35.3) <9F7C2AD8-A9A7-3DE4-828D-B0F0F166AAA0> /usr/lib/system/libunwind.dylib
                                                      0x7fffb2ecd000 -     0x7fffb2ef6ff7  libxpc.dylib (972.30.7) <65E41BB6-EBD5-3D93-B0BE-B190CEE4DD93> /usr/lib/system/libxpc.dylib
                                                  External Modification Summary:
                                                    Calls made by other processes targeting this process:
                                                      task_for_pid: 14
                                                      thread_create: 0
                                                      thread_set_state: 0
                                                    Calls made by this process:
                                                      task_for_pid: 0
                                                      thread_create: 0
                                                      thread_set_state: 0
                                                    Calls made by all processes on this machine:
                                                      task_for_pid: 46414
                                                      thread_create: 0
                                                      thread_set_state: 0
                                                  VM Region Summary:
                                                  ReadOnly portion of Libraries: Total=650.8M resident=0K(0%) swapped_out_or_unallocated=650.8M(100%)
                                                  Writable regions: Total=1.3G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.3G(100%)
        VIRTUAL   REGION
                                                  REGION TYPE                        SIZE    COUNT (non-coalesced)
                                                  ATS (font support)                33.0M       10
                                                  ATS (font support) (reserved)        8K        3         reserved VM address space (unallocated)
                                                  Accelerate framework               896K        8
                                                  Activity Tracing                   256K        2
                                                  CG backing stores                 24.7M       23
                                                  CG image                          1128K      106
                                                  CoreAnimation                     2148K       67
                                                  CoreUI image data                 2252K       28
                                                  CoreUI image file                  188K        6
                                                  Foundation                        16.0M        6
                                                  Image IO                          4580K      148
                                                  Kernel Alloc Once                    8K        2
                                                  MALLOC                             1.0G     1351
                                                  MALLOC guard page                   48K       10
                                                  MALLOC_LARGE (reserved)           6664K        2         reserved VM address space (unallocated)
                                                  Memory Tag 242                      12K        2
                                                  Memory Tag 249                     156K        4
                                                  Memory Tag 251                      28K        3
                                                  OpenCL                              32K        5
                                                  OpenGL GLSL                        256K        4
                                                  STACK GUARD                       56.2M       42
                                                  Stack                             28.3M       45
                                                  VM_ALLOCATE                      195.7M       61
                                                  __DATA                            57.8M      895
                                                  __GLSLBUILTINS                    2588K        2
                                                  __IMAGE                            528K        2
                                                  __LINKEDIT                       152.4M      354
                                                  __TEXT                           498.5M      655
                                                  __UNICODE                          556K        2
                                                  mapped file                      187.5M       85
                                                  shared memory                     16.4M       20
                                                  TOTAL                              2.2G     3922
                                                  TOTAL, minus reserved VM space     2.2G     3922
                                                  Model: iMac12,2, BootROM IM121.0047.B25, 4 processors, Intel Core i5, 2.7 GHz, 16 GB, SMC 1.72f2
                                                  Graphics: AMD Radeon HD 6770M, AMD Radeon HD 6770M, PCIe, 512 MB
                                                  Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x0000, -
                                                  Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x0000, -
                                                  Memory Module: BANK 0/DIMM1, 4 GB, DDR3, 1333 MHz, 0x0000, -
                                                  Memory Module: BANK 1/DIMM1, 4 GB, DDR3, 1333 MHz, 0x0000, -
                                                  AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x9A), Atheros 9380: 4.0.74.0-P2P
                                                  Bluetooth: Version 5.0.3f1, 3 services, 27 devices, 1 incoming serial ports
                                                  Network Service: Ethernet, Ethernet, en0
                                                  Serial ATA Device: WDC WD1001FALS-403AA0, 1 TB
                                                  Serial ATA Device: HL-DT-STDVDRW  GA32N
                                                  USB Device: USB 2.0 Bus
                                                  USB Device: FaceTime HD Camera (Built-in)
                                                  USB Device: Hub
                                                  USB Device: Backup+ Desk Mac
                                                  USB Device: BRCM2046 Hub
                                                  USB Device: Bluetooth USB Host Controller
                                                  USB Device: Hub
                                                  USB Device: Keyboard Hub
                                                  USB Device: Apple Keyboard
                                                  USB Device: IR Receiver
                                                  USB Device: Card Reader
                                                  Thunderbolt Bus: iMac, Apple Inc., 22.1
