12 Replies Latest reply on Jan 11, 2017 8:48 AM by luchababe
    Layer FX won't stay consistent in frames of animation
    luchababe Level 1
      I'm creating gifs that have text with a drop shadow. The text appears on each frame of the gif and has a drop shadow with a 120º angle. But the shadow FX is only correct in whatever frame is active as I work. Every other frame has a different angle. I have FX linked to be consistent through the entire animation but it's not doing it. I have to manually go to each frame and correct the angle to be the same throughout. It's very time consuming. I'm new to CC so maybe there's an option to select to help but I can't find it.
      I also try selecting all the frames and THEN pasting the FX setting but it doesn't work either.
