3 Replies Latest reply on Jan 10, 2017 10:51 AM by D.A.R
    Batch printing psds
    bfcreativenyc1 Level 1
      Is it possible to batch print psds? If so, how? Thanks!
        • 1. Re: Batch printing psds
          If your photoshop print default setting are correct you may  able to record a  single step  action Pint one copy and batch that action
          • 2. Re: Batch printing psds
            D.A.R Adobe Community Professional
            Put the files in a specific folder.
            Create a Print Action - Simply record a new action and print a file. Be sure to include a "Close" in the action.
            Then from the File menu... Automate > Batch...
            Choose the folder of images. Click OK.
            Each image will open and be sent to the printer then close.
            • 3. Re: Batch printing psds
              In addition:
              If you are not using the same settings for each file you can set that uno in the following way. While the file is open invoke the print dialog, set all the parameters necessary and click Done. Close the file and save.
              Now when you run the action for the batch the settings applied to the file will be used regardless of what was printed prior. For example, some images can be printed with indicators or scaling or different profiles.
