Hello Every-one.
I have an English version of Indesign, but my tutorial book is in french.
How can I change to Indesign English version to French?
Many Thanks
Best Regards
André
What exactly are you trying to accomplish? Do you want to change the spelling features of InDesign to recognise the correct spellings/grammar in French? Or are you trying to change the menu and UI of InDesign itself?
If you want to change the UI and you have a Creative Cloud Package then follow the steps recommended here:
Change the language setting of your Creative Cloud apps
Or if you have purchased an Adobe Application outright then this "hack" should work for you by following the instructions
...Copy link to clipboard
Open Creative Cloud program and choose your language in preferences. And you need than to install your french ID.
Change the language setting of your Creative Cloud apps - from help.
Unfortunately InDesign can't do this "on the fly" as can QuarkXPress. I write to Adobe many times feature request about it, but they not add this to features.
http://indesignsecrets.com/change-ui-language-indesign-cs6-cc.php - not oficial trick
Or if you have purchased an Adobe Application outright then this "hack" should work for you by following the instructions on this link:
If you only want to change the dictionary language to french for spelling check purposes etc then that can be done under Preferences> Dictionary as per the example below:
