1. Re: Shadows not casting in Classic 3D but do in Raytraced 3D
Mylenium Jan 11, 2017 8:45 AM (in response to jessicao98749098)Show us screenshots of your various switches in teh timeline in teh comp window. Also check your settings for Draft 3D, the comp viewer settings, guide layers and all the usual. Presumably you mixed up something there.
Mylenium
2. Re: Shadows not casting in Classic 3D but do in Raytraced 3D
jessicao98749098 Jan 11, 2017 9:11 AM (in response to Mylenium)Draft 3D isn't on, there are no guide layers. Also surely Draft3D wouldn't affect what it actually rendered out into an image sequence?
All the lights have basically the same settings, and nothing has been changed since it worked 6 months ago.
Here's the main comp settings,
This is the "shadow map" I'm getting from Raytraced 3D, but I can't get the DOF on it and it's just not the same look when reapplied on top.
It's so frustrating because I know I've done it all as one render before......
3. Re: Shadows not casting in Classic 3D but do in Raytraced 3D
Szalam Jan 11, 2017 9:49 AM (in response to jessicao98749098)Do you get the right shadows using the C4D renderer? (It might be faster than the ray-traced renderer.)
Also, check inside your precomp containing all of your 3d layers; are there any 2d layers hiding in there? Is that comp set to draft 3d?
4. Re: Shadows not casting in Classic 3D but do in Raytraced 3D
jessicao98749098 Jan 12, 2017 1:55 AM (in response to Szalam)No, unfortunately C4D renderer produces a largely black image.
Also, checked the precomps, there aren't any 2d layers and not set to draft 3d.
Is there something in Classic 3D that will stop shadows being rendered? Literally changing nothing else, but switching between Classic and raytraced, shadows appear...
5. Re: Shadows not casting in Classic 3D but do in Raytraced 3D
Szalam Jan 17, 2017 9:41 AM (in response to jessicao98749098) -
6. Re: Shadows not casting in Classic 3D but do in Raytraced 3D
Kevin-MonahanFeb 14, 2017 3:47 PM (in response to jessicao98749098)
Hi Jessica,
Interesting looking image. Did you ever get your depth of field looking right? Please let us know how you solved the issue or if you still need assistance.
Thanks!
Kevin -
7. Re: Shadows not casting in Classic 3D but do in Raytraced 3D
jessicao98749098 Feb 15, 2017 1:21 AM (in response to Kevin-Monahan)Hi Kevin,
No I didn't find a solution to the problem, I made a workaround instead to get the result I needed.
I rendered a shadow pass separately without the DOF and fudged it in the comp. Not the ideal answer, but I had a deadline to meet so needs must.
8. Re: Shadows not casting in Classic 3D but do in Raytraced 3D
Kevin-MonahanMar 13, 2017 5:55 PM (in response to jessicao98749098)
Thanks for letting us know, Jessica O.
Kevin
