I want to paste an object into all visible or unlocked layers in a single command, Can u help me?
You want one object to be masked by many paths?
Or paste multiple objects to multiple layers at once?
Please be precise, post a screenshot.
I want to paste a single object or objects in all visible layers
You can paste onto all Artboards from the Edit menu, but no, there is no command in Illustrator to paste onto all Layers at once.
May I ask what you are trying to achieve? Why do you want the same object on all layers? How many layers?
I would Option + Drag the Selection indicator in the Layers panel to copy the object to another layer in place.
you are correct. I have 20 more layers I need the same object in all 20 more layers means alt + drag will take more time. I need to give a progressive pdf with die for all layers. If there is no option like paste on all layers please make it an coming update It will helpful for all
Hi eppp25788359​,
This is a user to user forum, and I don't work for Adobe. They do have a wish list / bug report form, and it is read by the illustrator team.
http://www.adobe.com/products/wishform.html
You might also ask a question on the Scripting forum. It's possible that a script can be written and they can help you with that.
