8 Replies Latest reply on Jan 12, 2017 5:38 AM by [Jongware]
    Changing nested styles
    jonase5228042
      Hi there,
      Can anyone explain how to change nested styles with script?
      I have a simple script that can change some parameters in the paragraph style, but I cant find out how to change the nested parameters.
      I'm not a scripter and Google is my friend, but this question I can't find the answer for.
      I use to bachprocess a lot of templates so it would be awesome if someone can tell me what to do.
      Here's my simple script:
      #target "InDesign-8.0"
      if (app.documents.length != 0){
      var myD = app.activeDocument;
      try {
      var my_pstyle  = myD.paragraphStyles.item("6 BILD platta");
      with (my_pstyle){
      appliedFont = "Guardian AgateSans2";
      fontStyle = "Regular";
      rightIndent = 3;
      catch (myError) {}
      Here's what I want to change in the pstyle:
        • 1. Re: Changing nested styles
          Do you want to change the nested items in an existing style, or do you want to add the nesting parameters as shown in the image to your new style?
          Anyway, you can look at ParagraphStyle.nestedStyle and the NestedStyle Object itself. You can most likely just use .add "as usual", i.e.,
          with (my_pstyle)
            nestedStyles.add({.appliedCharacterStyle:app.activeDocument.characterStyles.item("6 BILD platta fotograf"), delimiter:"^y", repetition:1, inclusive:true});
          You can fiddle with its parameters until you get the right settings, or inspect them in an existing style.
          • 2. Re: Changing nested styles
            jonase5228042 Level 1
            Thank's man. I will try that.
            I want to change the nested items in an existing style.
            • 3. Re: Changing nested styles
              That should be possible: check each of the nested style's until you find the one to change, and then you can change the property you want to alter. Just set that property to the new value.
              Here is a quickie to list the important properties (written on a CS4 machine but hey, not much changed so far):
              st = app.activeDocument.paragraphStyles.item("6 BILD platta");
              r = [];
              for (ns=0; ns<st.nestedStyles.length; ns++)
              r.push ("nested style #"+ns+":");
              for (i in st.nestedStyles[0])
                if (i != 'parent' && i != 'properties' && i != 'index' && i != 'isValid')
                if (i == 'appliedCharacterStyle')
                  r.push (i+'='+st.nestedStyles[0][i].name);
                else
                  r.push (i+'='+st.nestedStyles[0][i]);
              alert (r.join('\r'));
              • 4. Re: Changing nested styles
                I found a period in the code .appliedCharacterStyle:
                with (my_pstyle)
                If I remove that the code works great. Many thanks!
                try {
                with (my_pstyle){
                  nestedStyles.add({appliedCharacterStyle:app.activeDocument.characterStyles.item("6 BILD platta fotograf"), delimiter:"^y", repetition:2, inclusive:true});
                catch (myError) {}
                Maybe it's not the right way, but it works.
                • 5. Re: Changing nested styles
                  Obi-wan Kenobi Level 5
                  Hi [Jongware],
                  If I just want to modify an existing nested style inserted in a "xxx" specific para style, is that code correct?
                  Thanks in advance!
                  app.activeDocument.paragraphStyles.item("xxx").nestedStyles[0].properties = {appliedCharacterStyle:app.activeDocument.characterStyles.item("yyy"), inclusive: false, repetition: 5, delimiter: "^y"};
                  • 6. Re: Changing nested styles
                    My code is working Obi-Wan-Kenobi
                    This part Jongware wrote:
                    with (my_pstyle){
                    • 7. Re: Changing nested styles
                      Oops... (I didn't want to mess up the document I was working on so I did not test that part.)
                      Your correction looks okay!
                      • 8. Re: Changing nested styles
                        Sure – or at least, I think so. But you need to know in advance what index the nested style has (if the style has more than one). Yeah I know, "surely you can count them, from top to bottom", but I've been bitten by that before.
