I have installed the Adobe InDesign CC 2017 application from my Creative Cloud Desktop on my Mac Sierra. It works fine. I now want to install the debug version of Adobe InDesign CC 2017 so I copy the content of the blob from the developers prerelease site into the /Applications/Adobe InDesign CC 2017 Debug folder. When I try to launch the application it just shows a Configuration error (Error 11) and quits ??????
[moved from Creative Cloud Download & Install to InDesign SDK]
HI,
Please copy the AMT folder from the installed Adobe InDesign CC2017 to same location in Adobe InDesign CC2017 Debug/
Let me know if it works
Regards
Sanyam Talwar
I faced the same issue using the ESD supplied installer on a German 10.11 (El Capitan) OS.
The reason for the error that you probably did either of two things:
@Sanyam: Copying the AMT folder did not work for me.
The AMT folders are identical with one exception, namely the file "application.xml". I think this file needs to be different because it seems to point to licensing data, which should of course be different for debug and release builds.
Regards,
Wolfgang
The issue faced by you is different as the installation of InDesign Debug ESD would provide the AMT folder and there is no need to copy.
Regards
Sanyam Talwar
you are right wtextor​, I installed InDesign Debug on spanish os X. Copying presets from release version solved my problem.
