• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Issues with Importing from Canon M5
New Here ,
Jan 11, 2017 Jan 11, 2017
I just updated my Lightroom to 6.8 so I could import from my new Canon M5. I shot some test RAW photos and they look fine sitting on my hard drive before import. The first view on import looks fine and then they all change to odd psychodelic colors with vertical or horizontal banding, depending on whether i was in landscape or portrait orientation.
Anyone else experience this or have a solution?
Here's an example:
Views
343
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jan 11, 2017 Jan 11, 2017
This looks like corrupted files, caused by failing hardware - could be camera card, usb cable, card reader, hard drive or RAM.
The images look ok in the OS, LR import dialog and initially in the LR Library because you are then seeing the raw file's embedded jpg.
Corruption typically affects only the raw files and not the embedded jpgs.
Votes
Translate
Translate
Community Expert ,
Try disabling the Graphics Processor in your Lightroom Preferences > Performance
Adobe Lightroom GPU Troubleshooting and FAQ
Votes
Translate
Translate
Report
Report
New Here ,
Thanks John. Did that. Shutdown LR and then restarted to assure the setting was read. Deleted previous photos and imported them again. Same issue.
Votes
Translate
Translate
Report
Report
New Here ,
Also, new computer built in July 2016 to Adobe specs. Don't think it's that cause.
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
New Here ,
Jan 12, 2017 Jan 12, 2017
LATEST
Thank you, Per. I appreciate your insight.
I think you are correct. Tried this SD card in a different camera (after formatting) and it worked fine. Then tried another faster card in the M5 (after formatting). Both sets of test images imported to Lightroom fine. I think that eliminates any parts of the computer or card reader as issues as all that is the same throughout all these tests.
Will keep experimenting, with fingers crossed that it doesn't happen again.
Votes
Translate
Translate
Report
Report
