The template I had previously used, doesn't work. Any template I create which includes the date, no longer works
thank you
Pat
Hi elearndesigner,
Please refer the below knowledge base articles, related to the same.
How to specify import options in Lightroom
How and When to Rename Files in Lightroom « Julieanne Kost's Blog
Regards,
Mohit
Mohit,
This is a BUG in Lightroom 6.8 and will not be solved by the Knowledge Base articles. See here for more info. The second link title should be NOT WORKING. The template editor for both the import and library rename are both broken.
It should be noted that I think the actual rename is done correctly but the EXAMPLE in the rename dialog in incorrect.
Re: Metatags in Filename Template Editor only insert at the end instead of at cursor.
Hi Robert,
Thanks for correcting me here. Let me check some info on the same.
Thanks again.
Mohit
Your welcome Mohit And thanks for your interest on this problem. This bug has been reported by several people.
The File rename templates are STILL NOT working in 2015.9 and it seems to be worse than I originally thought. See my Post #7 in this thread. The thread title should be Not Working.
