6 Replies Latest reply on Jan 22, 2017 5:50 PM by nancyg43376568
    Error! Check Activation
      II have uninstalled, reinstalled, tried to activate and I still keep getting "Error! Check Activation!". When I try to activate it tells me there is a server issue. What can I try next?
      Preferably I don't want to use Adobe Digital Editions since it doesn't work properly and I have spent hours on it. There must be better applications on the market?
      Thankful for help.
        • 1. Re: Error! Check Activation
          Nanaky Level 5
              Close all applications.
              Choose Start > Run.
              In the Open text box, type regedit and then press Enter. The Registry Editor opens.
              In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
              Select the Adept key.
              Choose File > Export.
              In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
              Right-click the Adept key and choose Delete.
              In the Confirm Key Delete dialog, click OK.
              Close the Registry Editor.
              Open Adobe Digital Editions and reauthorize.
              quit Adobe Digital Editions.
              Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
              If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
          • 2. Re: Error! Check Activation
            somethingtoremember5 Level 1
            Sorry for my late reply to this and many thanks for helping me. Just a quick question: As I don't want to authorise at all since i do not use the program more that for downloading books (I don'tuse this as a library as there is nothing but trouble with it), is that an option?
            • 3. Re: Error! Check Activation
              Nanaky Level 5
              To open eBooks of the Library need a adobe ID. Without authoirze if was not right work. Better you authoirze it with your Adobe ID.
              • 4. Re: Error! Check Activation
                THANK YOU!! I have been up, down and all around the Internet the past few days trying to find a fix. I've been borrowing epub books for years and have never had so many problems. I followed your instructions for the Windows as posted, and I was immediately able to download the same book that has been giving me error messages. I hope Adobe pays you for the advice. I was about to write a strongly worded email to them about the error issues.
                • 5. Re: Error! Check Activation
                  All is fixed.  The combination of removing and restoring my activation but more importantly downloading the latest update for B&N that was released a day or two ago fixed all problems.
                  Sent from my iPad
                  • 6. Re: Error! Check Activation
                    I had the same problem on my windows 7 desktop when I was prompted to upgrade to 4.53.
                    I tried following the instructions but it didn't work.
                    I did system restore and went back to ADE 2.0.
                    I went to the website and downloaded ADE 3.0.
                    After doing that, I was able to download the book without getting the "Error! Check Activation"
                    In fact, the ePub book I downloaded shows up in all three places.
