I have a jpg. of an old german text an need to convert it to any modern font to make it readable for others. Adobe Acrobat pro "edit text & images" it recognises some of the text right but most not.
Is this possible? or do i have to type it manually?
This might be an issue with jpg file. If it is of low resolution or colored background, there might be a case where it won't recognize all text. Can you please share following detail to help us understand the issue.
- Sample file(you can use https://cloud.acrobat.com/send to share the file)
- Acrobat version
- OS Detail
Thanks.
version is:
acrobat dc
Architecture: x86_64
Build: 15.20.20042.205528
AGM: 4.30.66
CoolType: 5.14.5
JP2K: 1.2.2.37137
os detail:
MacOs Sierra 10.12.2
markus schulte
[PII removed by moderator]
Ideally, it should work fine. But this type of problem occurs if image quality is not good. I request you to please share the document file.
Thanks.
markus schulte
Acrobat doesn't support this font very well.
