3 Replies Latest reply on Jan 14, 2017 12:36 PM by k64
    LR CC(2015.8) slows down entire PC
    k64 Level 1
      Been using LR from v5 right up to v6.8 with no performance problems at all until I decided to go to CC(2015.8) last weekend.
      Surely this should perform exactly the same as v6.8?  I'm working on exactly the same Book as I was in v6.8 but after only 10 or 20 minutes it starts to slow down, it takes several seconds to select the next image, pop-up windows appear only as outlines etc.
      This affects any other running programs too, not just LR.  The best way to revert to normal running is a reboot of the system.
      Task Manager shows <5% CPU, <20% memory and <2% system disk usage (0% the other 3 drives).  LR's system info below:
      Lightroom version: 6.8 [ 1099473 ]
      License: Perpetual
      Operating system: Windows 10
      Version: 10.0
      Application architecture: x64
      System architecture: x64
      Logical processor count: 8
      Processor speed: 4.0 GHz
      Built-in memory: 32696.0 MB
      Real memory available to Lightroom: 32696.0 MB
      Real memory used by Lightroom: 794.3 MB (2.4%)
      Virtual memory used by Lightroom: 759.2 MB
      Memory cache size: 535.5 MB
      Maximum thread count used by Camera Raw: 8
      Camera Raw SIMD optimization: SSE2,AVX,AVX2
      System DPI setting: 96 DPI
      Desktop composition enabled: Yes
      Displays: 1) 1680x1050
      Input types: Multitouch: No, Integrated touch: No, Integrated pen: No, External touch: No, External pen: No, Keyboard: No
      Graphics Processor Info:
      GeForce GT 610/PCIe/SSE2
      Check OpenGL support: Passed
      Vendor: NVIDIA Corporation
      Version: 3.3.0 NVIDIA 355.82
      Renderer: GeForce GT 610/PCIe/SSE2
      LanguageVersion: 3.30 NVIDIA via Cg compiler
      Application folder: C:\Program Files\Adobe\Adobe Lightroom
      Library Path: D:\Users\{username}\Pictures\Lightroom\Keiths LR6 Catalog.lrcat
      Settings Folder: D:\Users\{username}\AppData\Roaming\Adobe\Lightroom
      Installed Plugins:
      1) Canon Tether Plugin
      2) Facebook
      3) Flickr
      4) HDR Efex Pro 2
      5) Leica Tether Plugin
      6) Nikon Tether Plugin
      7) Photo Upload
      Does anyone have any ideas?
        • 1. Re: LR CC(2015.8) slows down entire PC
          F. McLion Adobe Community Professional & MVP
          Your licensing model is still on perpetual (LR 6) and not on subscription (CC 2015).
          However, this does not have any influence on the performance, but you will miss out on the CC features.
          Please update the Nvidia graphic card driver to the latest version and see if this helps: http://www.nvidia.com/download/driverResults.aspx/113448/en-us
          NVIDIA DRIVERS GeForce Game Ready Driver WHQL
          • 2. Re: LR CC(2015.8) slows down entire PC
            k64 Level 1
            Yes, I noticed the licensing model too, but the splash screen and about... both show 2015.8
            I'll get back about the driver later.
            • 3. Re: LR CC(2015.8) slows down entire PC
              k64 Level 1
              After receiving your advice on updating the graphics card driver everything was working very sweetly so I didn't update it (if it ain't broke, don't fix it) until this evening when...
              • LR CC 2015.8 had been running for 3 or 4 hours
              • I moved 16 photos into the LR Watched Folder.
              • Just 2 were automatically imported to my Newly Imported folder, but not renamed as they should have been and neither are they in the catalog, then the Import button was greyed-out.
              • I uninstalled LR CC 2015.8 and installed 2015.0 then updated to 2015.7
              • LR, when started, correctly imported the remaining files (and the original 2 once I'd moved them back to the Watched Folder).
              • After several minutes work in the Library, Develop and Book modules it suddenly slowed down as per my original problem above.
              I have now rebooted in order to update this post and will then update the graphics card driver.
