Please see the summary. I use the Acrobat DC. When I use the feature "Replace Pages", I note that when the replacement has some annotations, for example, typewriters, notes. Only the Note in the replacement pages will be retained. Any other type of annotations will not be retained.
What is more, only the Note which has content, for example, input some text in it, this type of Note will be retained. If it doesn't hava any contents, it will not be retained in the result page.
Why? Is it intent to do so? Or it is a bug?
Hmmm... I've just tested this on Mac OSX version of Adobe Acrobat Pro DC and I can't get it to fail as per your description.
I then thought let's move the content of the original document around... I pushed headers down, removed lines that were marked up and replaced the page again.
Can you let us know WHAT version of Adobe Acrobat Pro DC you are using, and which platform (Windows, Mac, and the version, e.g. Windows 10).
Also check that you have the latest version of Acrobat Pro DC installed. See: Release Notes | Adobe Acrobat, Reader
Thank you for your quick reply!
Let me give you an example.
I have a Page named A and a page named B. When in the Page B, there are two Sticky Notes. One is B1 which has no content. The other one is B2 which has content in it. Then I open the page A, and use the feature of "Replace Page", then I choose Page B as the replacement. In the result page, I have seen that B2 has been retained while B1 is not.
I am sure you can understand me fully via this example. So is it intent to do so?
I use Acrobat Pro DC on Windows. The version number is 2015.006.30279.
Aaaah you are doing the exact reverse of what I tried to replicate earlier on.
My best guess is that what you are seeing is intended behaviour... However having said that I'd expect NONE of the comments to carry across when you use a page with comments to replace a page in another PDF.
So it's interesting to see that when you use a page that contains numerous comment types (e.g. strikethrough, notes etc.), one type does come through and that's the non-blank Note. I would not have expected that to come across either.
It'd be worth bringing this behaviour to the attention of Adobe. I'll see if I can reach-out and get some feedback.
Thanks a lot!
Waiting for your feedback!
Some feedback so far: The tech support consultant I reported this to has sent it to the product team and confirms he can also replicate the issue, so hopefully we'll get some advice on whether this is a feature soon. I'll keep you posted (and if I don't hear back from product team, I'll send a reminder in abt. two weeks time, as guessing these guys/girls are pretty busy so might not be able to look at it immediately).
I had this same issue. As a work around, I printed the marked-up PDF to a PDF and was able to replace pages with the comments. Unfortunately, the comments are now part of the PDF and cannot be edited as comments.
Export the comments to an FDF file, replace the pages, import the comments from the FDF file to the new page.
