3 Replies Latest reply on Oct 28, 2008 2:14 PM by HooMaster
    displaying panel infront of iFrame
    Benji2008 Level 1
      if anyone can help me out, it would be much appreciated :)
      the problem is, the application i'm working on has an iframe but there is also a pop up panel in which info is shown, the problem is that this panel shows up "behind" the iframe..
      does anyone know if there's a certain way to force the panel to the front of the application ?
      thanks for your time :)
      grtz
        • 1. Re: displaying panel infront of iFrame
          Level 7
          "Benji2008" <webforumsuser@macromedia.com> wrote in message
          news:gcv6mj$t5e$1@forums.macromedia.com...
          > also
          > shows up
          > of
          > the application ?
          The iFrame is actually drawn by the browser, not the Flash player. You can
          have the iFrame in front of your Flex swf or behind your Flex swf (as I
          understand it), but you can't sandwich it between pieces of your swf.
          HTH;
          Amy
          • 2. Re: displaying panel infront of iFrame
            adobeflamingo
            I am experiencing the same issue. Is there a way to fix this? Or is there a way to replace iframe to avoid this issue? Thank you for your help.
            • 3. Re: displaying panel infront of iFrame
              HooMaster
              Because of the way iframes are handled by the browser, there's not really a good way to make things appear in front of them. If you can, you might try using 2 iframes and using the z-index to control which is in front.
