I'd like to remove the open space underneath the cap is the first attached image and make it look like one long continuous bottle.
I've tried making a selection of the bottom portion, copying and pasting it to a new layer, then dragging up to the top. Please see second attached image.
It works great accept that it leaves a strange little bump which I can't figure out why is there considering the bottom part is wider than the part its being dragged over.
Why is this happening? Is there a way to edit it so that I don't have to pull the bottom part wider than it already is to cover the bump? Thanks!
I
Good thinking.
Please use this thread to continue this discussion
Making a bottle cap look closed
This thread is now locked.
Hi
You should keep this discussion into your first post about this matter.
Right now you just confuse the matter & goal.
Maybe a moderator can merge these. ?
Pierre
Good thinking.
