I downloaded Adobe Premiere Pro Tryout version but I can't run it. Every time I launch the application I get the error message 'Adobe Premiere Pro could not load any audio drivers. Please reinstall Adobe Premiere Pro and start again'.
The Adobe Premiere Pro version is 2 and my computer's OS is Windows 10 Home, 64-bit version.
I tried fixing the installation from the Control Panel but it didn't solve the problem.
I searched Adobe support and found a question about this issue, but it refers to version 1 and the recommended fix is to install version 1.5.
Can anyone help?
Did you tried to reinstall the Adobe Premiere ?
CS2 is so old that it is probably not going to run with Win10
An idea that MAY work to install and/or run old programs in Windows 10... works for some, not for others
-RIGHT click the program icon or EXE and select a compatibility mode in the pop up option window
-or Run as Administrator http://forums.adobe.com/thread/969395 to assign FULL Windows permissions may help... says Encore, but sometimes required for ALL Adobe programs (this is NOT the same as using an Administrator account)
