7 Replies Latest reply on Jan 15, 2017 7:09 AM by kglad
    Animator CC 2017 - Scrollable Text Box Error 1120
    garyb5854400
      Hello. I'm working on a scrolling textbox that I can import into another project as a SWF file. However, upon exporting the file I get a series of Error 1120 messages. The code that I'm using, I found on another forum post for a scrolling text box here (credit to kglad). I then, edited a few things out for my purposes. The actionscript code works perfectly when I use the Test function, but after that it all becomes a hodge podge mess. My two varieties of error messages and my code are pasted below:
      Scene 1, Layer 'Layer 3' Line 1, Column 1 | 1120: Access of undefined property tl.
      Scene 1, Layer 'Layer 3' Line 3, Column 1 | 1120: Access of undefined property createjs.
      tl = this;
      createjs.Touch.enable(tl);
      paramF(0, 48, 146 - 20, 48 + 146 - tl.tf.getBounds().height);
      tl.sb.thumb.addEventListener('mousedown', startdragF);
      function startdragF(e) {
          stage.addEventListener('stagemousemove', dragF);
          stage.addEventListener('stagemouseup', stopdragF);
      function stopdragF(e) {
          stage.removeEventListener('stagemousemove', dragF);
      function dragF(e) {
          if (e.stageY >= 48 && e.stageY <= 48 + 146 - 20) {
              tl.sb.thumb.y = Math.floor(e.stageY - tl.sb.y);
              tl.tf.y = Math.floor(tl.m * tl.sb.thumb.y + tl.b);
      function paramF(x1, y1, x2, y2) {
          tl.m = (y1 - y2) / (x1 - x2);
          tl.b = y1 - tl.m * x1;
      Any help or suggestions as to fix this code would be greatly appreciated. I'm not super skilled with code, but will do my best.
      Thanks!
        • 1. Re: Animator CC 2017 - Scrollable Text Box Error 1120
          are you creating an html5/canvas project?
          • 2. Re: Animator CC 2017 - Scrollable Text Box Error 1120
            garyb5854400 Level 1
            It's an html/canvas project that I want to export to a SWF format.
            • 3. Re: Animator CC 2017 - Scrollable Text Box Error 1120
              to me that means you're creating an as3 project, not html5/canvas and that would explain the errors.
              as3 != javascript/easeljs.  the as3 and javascript are similar, but they're not the same.
              for as3:
              paramF(0, 48, 146 - 20, 48 + 146 - tf.height);
              sb.thumb.addEventListener(MouseEvent.MOUSE_DOWN, startdragF);
              function startdragF(e:MouseEvent):void {
                  stage.addEventListener(MouseEvent.MOUSE_MOVE, dragF);
                  stage.addEventListener(MouseEvent.MOUSE_UP, stopdragF);
              function stopdragF(e:MouseEvent):void {
                  stage.removeEventListener(MouseEvent.MOUSE_MOVE, dragF);
              function dragF(e:MouseEvent):void {
                      sb.thumb.y = Math.floor(e.stageY - sb.y);
                      tf.y = Math.floor(m * sb.thumb.y + b);
                  b = y1 - m * x1;
              • 4. Re: Animator CC 2017 - Scrollable Text Box Error 1120
                for as3:
                b = y1 - m * x1;
                Thanks for the responses! I created a new file, set to as3 and added the layers that I had previously, using the new action code on the same frame. I was met with the following errors:
                Scene 1, Layer 'Layer 3', Frame 1, Line 29, Column 27    1120: Access of undefined property m.
                Scene 1, Layer 'Layer 3', Frame 1, Line 29, Column 44    1120: Access of undefined property b.
                Scene 1, Layer 'Layer 3', Frame 1, Line 37, Column 5    1120: Access of undefined property m.
                Scene 1, Layer 'Layer 3', Frame 1, Line 39, Column 5    1120: Access of undefined property b.
                Scene 1, Layer 'Layer 3', Frame 1, Line 39, Column 14    1120: Access of undefined property m.
                Thank you again for your assistance!
                • 5. Re: Animator CC 2017 - Scrollable Text Box Error 1120
                  have to declare those variables:
                  var m:Number;
                  var b:Number;
                  b = y1 - m * x1;
                  • 6. Re: Animator CC 2017 - Scrollable Text Box Error 1120
                    var m:Number;
                    var b:Number;
                    b = y1 - m * x1;
                    This works and exports with no error!. One last quick question. Is there a way to add this to an interactive InDesign project? I will still be exporting it as a SWF but when the project is viewed as a swf, can the scrollbar work?
                    Thanks!
                    • 7. Re: Animator CC 2017 - Scrollable Text Box Error 1120
                      i've never used id, so i don't know the answer to your question. post in the id forum.
                      the original code is from a fla that published a swf.  the code you've been testing in this thread wouldn't be used to publish a swf.
                      (p.s when using the adobe forums, please mark helpful/correct responses, if there are any.)
