0 Replies Latest reply on Jan 13, 2017 2:04 PM by scottf2585416
    Indexing issue. "Can not index as its modified version is open".
      I am trying to create an index with all PDF's that exist in a certain folder. The log after creating the index for all the PDF's displays the following error:  "Can not index this document as its modified version is open in Acrobat".
      After examining the PDF's, every PDF seems to think there are changes that need to be saved. This holds true since when closing any PDF document, it it asking to save. They are form type PDF's. If you save the PDF, then open it again, it does not ask to save again and the index will work.
      There are 71,000 PDF files that need to be indexed. Is there a batch way to make all these PDF files "save"?
