I'm trying to delete a 100,000 image folder and failing. The back story is a I have an external hard drive D: which at one time had a folder of 100,000 images. Outside of Lightroom and on another computer, I formatted the external drive D, deleting those images, and then loaded a different folder (about 60,000) images. A 2 Tb drive. Now when I plug that drive into my laptop, the LR version I have there shows both the old D: with 100,000 images all of course have ? missing, as well as the current collection of 60,000 which I did succeed in importing. How do I get rid of the ? images. I tried right clicking on the folder but after half an hour of processing it quits, "not enough memory". I can delete them 500 at a time by opening each subfolder, but that will take a long time.
What I was able to do is open a sub folder and select maybe eight or 9000 images then right click and delete. Then come back an hour later and repeat until they were all gone.
If you are getting "out of memory" errors trying to delete all at the same time, you will need to break it into smaller pieces. The catch is to figure out how big those smaller pieces can be.
Start with a leaf folder. That should work fine.
Then try deleting its parent and all its siblings in one go.
