4 Replies Latest reply on Jan 15, 2017 6:38 AM by smithcgl9043167
    Help with User Interface "Dialog Box"
    smithcgl9043167 Level 2
      Hi friends! I've found this script for dialog box that works great and need to use on small panel I'm creating. I just wanted to give an improvement on your visual as it shows the Image below: I would like it to look like image 2.
      I am not able to modify the script: Could anyone help me by changing the script? Thank you!
          var w = new Window("dialog", "Formact");
          var radio_group = w.add('panel', undefined, "Função");
          radio_group.alignChildren = "left";
          radio_group.add("radiobutton", undefined, "Opção 01");
          radio_group.add("radiobutton", undefined, "Opção 02");
          radio_group.add("radiobutton", undefined, "Opção 03");
          var btnGroup = w.add("group");
          btnGroup.add('button', {
              x: 90,
              y: 125,
              width: 90,
              height: 25
          }, 'Ok', {
              x: 240,
              y: 125,
              width: 90,
              height: 25
          }, 'Cancel', {
          // set dialog defaults
          radio_group.children[0].value = true;
          function selected_rbutton(rbuttons) {
              for (var i = 0; i < rbuttons.children.length; i++) {
                  if (rbuttons.children[i].value == true) {
                      return rbuttons.children[i].text;
          // Linkar com os Scrips.jsx
          if (w.show() == 1) {
              var chosenRadioButton = selected_rbutton(radio_group);
              switch (chosenRadioButton) {
        • 1. Re: Help with User Interface "Dialog Box"
          Photoshop Chef Level 1
          here you go, see line 2. and 13.:
              w.orientation = "row";
              btnGroup.orientation = "column";
                  x: 90,
                  y: 125,
                  width: 90,
                  height: 25
              }, 'Ok', {
                  x: 240,
                  y: 125,
                  width: 90,
                  height: 25
              }, 'Cancel', {
          • 2. Re: Help with User Interface "Dialog Box"
            it helped a lot, thank you! But I realized that as I add more options, the buttons are centered vertically. It would be really cool if the buttons were positioned at the top. Could it be arranged? Thank you
            • 3. Re: Help with User Interface "Dialog Box"
              pixxxel schubser MVP & Adobe Community Professional
              Hi smithcgl9043167
              try this
              w.alignChildren = "top";  // insert this line
              Have fun
              • 4. Re: Help with User Interface "Dialog Box"
                Hi pixxxel schubert
                Now it's perfect, thank you very much for the tip!
