My video isn't visible after I upload the file to Premiere Elements 11. It doesn't seem to be a codec problem as I checked G-Spot and it says correct audio and video codecs are installed. The avi files play fine on G-Spot and the Movies & TV applications. I recently got the new laptop and the problem may be related to something on it as my old Windows 7 laptop didn't have this problem.
Would you please help me?
System info:
Windows 10 Home OS
.avi file type
Premiere Elements v 11.0
It's an AVI using the H.264 codec -- which doesn't sit well with Premiere Elements.
Easiest solution is to run it through the free download Handbrake and convert it to a 1280x720 MP4.
What codec does G Spot report the file uses and what format is the file?
What model of camcorder did the video come from?
Also, do you have Quicktime 7 installed, per the program's system requirements? It provides important codec information for version 11 of the program.
Steve, thanks. I use a Kodak Zi8 hand-held camcorder. Quicktime v7.7.9 is installed on the laptop. Here is the G-Spot file analysis:
Thanks Steve! Converting to MP4 worked great. Now I have another problem-PreEle11 crashed when I tried to burn my disc, but I'll post something separately for that.
Thanks again
