2 Replies Latest reply on Jan 20, 2017 12:49 PM by laindustria
    get the column of a paragraph in multicolumn textframes
    laindustria
      Hi, I would like to know how to get the current column of a paragraph in a multicolumn textframe.
      Given a story myStory formed by several multicolumn textFrames along multiple pages, I can access to its textFrames, columns of the textFrames, and paragraphs and words and lines,... in that order with codes like
      var myParagraph = myStory.paragraphs[a];
      var myColumn = myStory.parentTextFrames[myframe].textColumns[myColumnIndex];
      But I dont know in which sub column is a known paragraph or line. I wonder if exists some method or property to get it as the parent, parentTextFrame or parentStory exist for other objects. In my work I want to know if a paragraph is shared between two or more sub columns.
      Thanks in advance.
        • 1. Re: get the column of a paragraph in multicolumn textframes
          Jump_Over Level 5
          In this case check givenParagraph.textColumns.length
          In this case you may need to calculate it. For example in this way:
          (to alert column's number of 1st paragraph of current selection)
          var
            arrayOfIndexes = app.selection[0].parentStory.textColumns.everyItem().index,
            searchObject = app.selection[0].paragraphs[0],
            cIndex, step,
            searchIndex = searchObject.textColumns[0].index;
          for (step = 0; step < arrayOfIndexes.length; step++) {
            cIndex = arrayOfIndexes[step];
            if (searchIndex == cIndex) {
                 alert ("searchObject found in a textColumn number: " + (step+1) );
                 break;
          Jarek
          • 2. Re: get the column of a paragraph in multicolumn textframes
            laindustria Level 1
            Thanks very much, Jarek. I´m working with your code.
