4 Replies Latest reply on Jan 23, 2017 11:53 AM by huseinl9521971
    Error building .apk
    romanvenica
      Hey there.
      This problem started today at morning.
      When I try to build an apk file I get this error:
      "Oh geez. Your build failed. Click the "Log" button above to view the compile log. If you need help diagnosing the issue, you can post to the support forum with your App ID (please do a search first)."
      It seems like there have been some changes on this plugin:
      https://github.com/dpa99c/cordova-diagnostic-plugin
      I tried removing it from config.xml file and it solves the problem. But I need it.
      I will let you below the compile log.
      Please tell me if this is some phonegap error and it will be solved soon or it is something that I'm doing wrong.
      Best reggards.
      Build Date: 2017-01-15 14:34:35 +0000
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-splashscreen@4.0.1" via npm
      Installing "cordova-plugin-splashscreen" at "4.0.1" for android
      Fetching plugin "cordova-plugin-network-information@1.3.1" via npm
      Installing "cordova-plugin-network-information" at "1.3.1" for android
      Fetching plugin "cordova-plugin-dialogs@1.3.1" via npm
      Installing "cordova-plugin-dialogs" at "1.3.1" for android
      Fetching plugin "cordova-plugin-device@1.1.4" via npm
      Installing "cordova-plugin-device" at "1.1.4" for android
      Fetching plugin "cordova-plugin-geolocation@2.4.1" via npm
      Installing "cordova-plugin-geolocation" at "2.4.1" for android
      Fetching plugin "cordova-plugin-compat" via npm
      Installing "cordova-plugin-compat" at "1.1.0" for android
      Fetching plugin "cordova.plugins.diagnostic" via npm
      Installing "cordova.plugins.diagnostic" at "3.3.3" for android
      COMPILE OUTPUT
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      :preBuild UP-TO-DATE
      :preDebugBuild UP-TO-DATE
      :checkDebugManifest
      :preReleaseBuild UP-TO-DATE
      :CordovaLib:preBuild UP-TO-DATE
      :CordovaLib:preDebugBuild UP-TO-DATE
      :CordovaLib:compileDebugNdk UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint UP-TO-DATE
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:compileDebugAidl
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:mergeDebugShaders
      :CordovaLib:compileDebugShaders
      :CordovaLib:generateDebugAssets
      :CordovaLib:mergeDebugAssets
      :CordovaLib:processDebugManifest
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:incrementalDebugJavaCompilationSafeguard
      :CordovaLib:compileDebugJavaWithJavac
      :CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :CordovaLib:preReleaseBuild UP-TO-DATE
      :CordovaLib:compileReleaseNdk UP-TO-DATE
      :CordovaLib:copyReleaseLint UP-TO-DATE
      :CordovaLib:mergeReleaseProguardFiles
      :CordovaLib:packageReleaseRenderscript UP-TO-DATE
      :CordovaLib:checkReleaseManifest
      :CordovaLib:prepareReleaseDependencies
      :CordovaLib:compileReleaseRenderscript
      :CordovaLib:generateReleaseResValues
      :CordovaLib:generateReleaseResources
      :CordovaLib:packageReleaseResources
      :CordovaLib:compileReleaseAidl
      :CordovaLib:generateReleaseBuildConfig
      :CordovaLib:mergeReleaseShaders
      :CordovaLib:compileReleaseShaders
      :CordovaLib:generateReleaseAssets
      :CordovaLib:mergeReleaseAssets
      :CordovaLib:processReleaseManifest
      :CordovaLib:processReleaseResources
      :CordovaLib:generateReleaseSources
      :CordovaLib:incrementalReleaseJavaCompilationSafeguard
      :CordovaLib:compileReleaseJavaWithJavac
      :CordovaLib:compileReleaseJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      :CordovaLib:processReleaseJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForRelease
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease
      :CordovaLib:mergeReleaseJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForRelease
      :CordovaLib:transformNative_libsWithSyncJniLibsForRelease
      :CordovaLib:bundleRelease
      :prepareComAndroidSupportAnimatedVectorDrawable2510Library
      :prepareComAndroidSupportAppcompatV72510Library
      :prepareComAndroidSupportSupportCompat2510Library
      :prepareComAndroidSupportSupportCoreUi2510Library
      :prepareComAndroidSupportSupportCoreUtils2510Library
      :prepareComAndroidSupportSupportFragment2510Library
      :prepareComAndroidSupportSupportMediaCompat2510Library
      :prepareComAndroidSupportSupportV42510Library
      :prepareComAndroidSupportSupportVectorDrawable2510Library
      :prepareProjectCordovaLibUnspecifiedDebugLibrary
      :compileDebugAidl
      :mergeDebugShaders
      :mergeDebugAssets
      :mergeDebugResources
      :processDebugResources/project/build/intermediates/res/merged/debug/values-v24/values-v24. xml:3: AAPT: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.Button.Borderless.Colored'.
      /project/build/intermediates/res/merged/debug/values-v24/values-v24.xml:4: AAPT: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.Button.Colored'.
      FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':processDebugResources'.
      > com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command '/android-sdk/build-tools/24.0.1/aapt'' finished with non-zero exit value 1
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 2.501 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      /project/build/intermediates/res/merged/debug/values-v24/values-v24.xml:3: AAPT: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.Button.Borderless.Colored'.
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
        • 1. Re: Error building .apk
          kerrishotts Adobe Employee
          PhoneGap has no control over third-party plugins. Looking at the plugin's repo, it appears this issue has already been reported, and the dev has a fix: https://github.com/dpa99c/cordova-diagnostic-plugin/issues/168#issuecomment-272847634, which is to ensure you're on phonegap-cli@6.4.0.
          • 2. Re: Error building .apk
            jimb8343086
            I found that forcing Build to use the latest version of the CLI fixed this problem for me.  Insert the following into your config.xml:
            <preference name="phonegap-version" value="cli-6.4.0" />
            • 3. Re: Error building .apk
              romanvenica Level 1
              Thanks to both of you for the answers!
              • 4. Re: Error building .apk
                huseinl9521971
                Hey, i followed your instructions but the error message still appears, but the log has changed:
                Build Date: 2017-01-23 19:32:04 +0000
                PLUGIN OUTPUT
                Fetching plugin "cordova-plugin-whitelist" via npm
                Installing "cordova-plugin-whitelist" at "1.3.1" for android
                Subproject Path: CordovaLib
                :clean
                :CordovaLib:clean
                BUILD SUCCESSFUL
                Total time: 1.396 secs
                  This plugin is only applicable for versions of cordova-android greater than 4.0. If you have a previous platform version, you do *not* need this plugin since the whitelist will be built in.
                Fetching plugin "phonegap-plugin-push@1.5.3" via npm
                Installing "phonegap-plugin-push" at "1.5.3" for android
                :clean
                :CordovaLib:clean
                BUILD SUCCESSFUL
                Total time: 1.463 secs
                Fetching plugin "com.paypal.cordova.mobilesdk" via npm
                Installing "com.paypal.cordova.mobilesdk" at "3.3.1" for android
                Fetching plugin "card.io.cordova.mobilesdk" via npm
                Installing "card.io.cordova.mobilesdk" at "2.1.0" for android
                :clean
                :CordovaLib:clean
                BUILD SUCCESSFUL
                Total time: 3.218 secs
                :clean
                :CordovaLib:clean
                BUILD SUCCESSFUL
                Total time: 1.364 secs
                Fetching plugin "cordova-plugin-device" via npm
                :clean
                :CordovaLib:clean
                BUILD SUCCESSFUL
                Total time: 1.713 secs
                Fetching plugin "cordova-plugin-inappbrowser" via npm
                Installing "cordova-plugin-inappbrowser" at "1.6.1" for android
                :clean
                :CordovaLib:clean
                BUILD SUCCESSFUL
                Fetching plugin "cordova-plugin-splashscreen" via npm
                :clean
                :CordovaLib:clean
                BUILD SUCCESSFUL
                Total time: 2.483 secs
                Fetching plugin "cordova-plugin-geolocation" via npm
                :clean
                :CordovaLib:clean
                BUILD SUCCESSFUL
                Total time: 1.76 secs
                :clean
                :CordovaLib:clean
                BUILD SUCCESSFUL
                Fetching plugin "cordova-plugin-network-information" via npm
                :clean
                :CordovaLib:clean
                BUILD SUCCESSFUL
                Total time: 2.117 secs
                Fetching plugin "cordova-plugin-request-location-accuracy" via npm
                Installing "cordova-plugin-request-location-accuracy" at "2.2.0" for android
                :clean
                :CordovaLib:clean
                BUILD SUCCESSFUL
                Total time: 1.335 secs
                Fetching plugin "cordova-plugin-x-toast" via npm
                Installing "cordova-plugin-x-toast" at "2.5.2" for android
                :clean
                :CordovaLib:clean
                BUILD SUCCESSFUL
                Total time: 2.113 secs
                Fetching plugin "cordova-plugin-fastrde-checkgps" via npm
                Installing "cordova-plugin-fastrde-checkgps" at "1.0.0" for android
                Dependent plugin "cordova-plugin-geolocation" already installed on android.
                :clean
                :CordovaLib:clean
                BUILD SUCCESSFUL
                Total time: 1.258 secs
                Fetching plugin "https://github.com/rodrigo-martinezd/cordova-dialog-gps.git" via git clone
                Using shallow clone
                Repository "https://github.com/rodrigo-martinezd/cordova-dialog-gps.git" checked out to git ref "master" at "f110314".
                Installing "cl.rmd.cordova.dialoggps" at "0.0.2" for android
                UNEXPECTED TOP-LEVEL EXCEPTION:
                java.io.FileNotFoundException: /tmp/gimlet/25568680/1918762/project/build/intermediates/exploded-aar/com.google.android. gms/play-services-maps/8.4.0/jars/classes.jar (No such file or directory)
                at java.util.zip.ZipFile.open(Native Method)
                at java.util.zip.ZipFile.<init>(ZipFile.java:219)
                at java.util.zip.ZipFile.<init>(ZipFile.java:149)
                at java.util.zip.ZipFile.<init>(ZipFile.java:163)
                at com.android.dx.cf.direct.ClassPathOpener.processArchive(ClassPathOpener.java:244)
                at com.android.dx.cf.direct.ClassPathOpener.processOne(ClassPathOpener.java:166)
                at com.android.dx.cf.direct.ClassPathOpener.process(ClassPathOpener.java:144)
                at com.android.dx.command.dexer.Main.processOne(Main.java:677)
                at com.android.dx.command.dexer.Main.processAllFiles(Main.java:574)
                at com.android.dx.command.dexer.Main.runMonoDex(Main.java:311)
                at com.android.dx.command.dexer.Main.run(Main.java:277)
                at com.android.dx.command.dexer.Main.main(Main.java:245)
                at com.android.dx.command.Main.main(Main.java:106)
                1 error; aborting
                trouble writing output: /tmp/gimlet/25568680/1918762/project/build/intermediates/pre-dexed/debug/com.google.andro id.gms-play-services-base-8.4.0_3f9367004278fddd15903240cc38bc0ff75a4f67.jar (No such file or directory)
                :clean
                :CordovaLib:clean
                BUILD SUCCESSFUL
                Total time: 8.827 secs
                Fetching plugin "https://github.com/razorpay/razorpay-cordova.git" via git clone
                Using shallow clone
                Repository "https://github.com/razorpay/razorpay-cordova.git" checked out to git ref "master" at "4d01a71".
                Installing "com.razorpay.cordova" at "0.13.1" for android
                :clean
                :CordovaLib:clean
                BUILD SUCCESSFUL
                Total time: 1.865 secs
                Fetching plugin "cordova-plugin-media" via npm
                Installing "cordova-plugin-media" at "2.4.1" for android
                Fetching plugin "cordova-plugin-file" via npm
                Installing "cordova-plugin-file" at "4.3.1" for android
                Dependent plugin "cordova-plugin-compat" already installed on android.
                :clean
                :CordovaLib:clean
                BUILD SUCCESSFUL
                Total time: 1.459 secs
                The Android Persistent storage location now defaults to "Internal". Please check this plugin's README to see if your application needs any changes in its config.xml.
                If this is a new application no changes are required.
                If this is an update to an existing application that did not specify an "AndroidPersistentFileLocation" you may need to add:
                  "<preference name="AndroidPersistentFileLocation" value="Compatibility" />"
                to config.xml in order for the application to find previously stored files.
                :clean
                :CordovaLib:clean
                BUILD SUCCESSFUL
                Total time: 1.261 secs
                :clean
                :CordovaLib:clean
                BUILD SUCCESSFUL
                Total time: 1.464 secs
                Fetching plugin "cordova-plugin-googlemaps" via npm
                Installing "cordova-plugin-googlemaps" at "1.4.0" for android
                :clean
                :CordovaLib:clean
                BUILD SUCCESSFUL
                Total time: 1.518 secs
                  In order to run this plugin, you need to obtain Google Maps API key for Android.
                  Visit https://github.com/mapsplugin/cordova-plugin-googlemaps/wiki/Installation
                  Check our release notes.
                  https://github.com/wf9a5m75/phonegap-googlemaps-plugin/wiki/Release-Notes
                COMPILE OUTPUT
                :checkDebugManifest
                :prepareComAndroidSupportSupportV132340Library
                :prepareComGoogleAndroidGmsPlayServicesBase1001Library
                :prepareComGoogleAndroidGmsPlayServicesBasement1001Library
                :prepareComGoogleAndroidGmsPlayServicesGcm1001Library
                :prepareComGoogleAndroidGmsPlayServicesIid1001Library
                :prepareComGoogleAndroidGmsPlayServicesLocation1001Library
                :prepareComGoogleAndroidGmsPlayServicesMaps980Library
                :prepareComGoogleAndroidGmsPlayServicesTasks1001Library
                :prepareComPaypalSdkPaypalAndroidSdk2146Library
                :prepareComRazorpayCheckout120Library
                :prepareIoCardAndroidSdk540Library
                :compileDebugAidl
                :processDebugResourcesWarning: AndroidManifest.xml already defines debuggable (in http://schemas.android.com/apk/res/android); using existing value in manifest.
                /project/src/plugin/google/maps/PluginCircle.java:28: error: cannot access AbstractSafeParcelable
                  circleOptions.center(new LatLng(center.getDouble("lat"), center.getDouble("lng")));
                  class file for com.google.android.gms.common.internal.safeparcel.AbstractSafeParcelable not found
                Note: Some input files use unchecked or unsafe operations.
                Note: Recompile with -Xlint:unchecked for details.
                1 error
                :compileDebugJavaWithJavac FAILED
                * What went wrong:
                Execution failed for task ':compileDebugJavaWithJavac'.
                > Compilation failed; see the compiler error output for details.
                * Try:
                BUILD FAILED
                Total time: 7.303 secs
                1 error
                * What went wrong:
                * Try:
