1 2 Previous Next 59 Replies Latest reply on Dec 4, 2018 5:10 AM by Johnnes Branched to a new discussion.
    After Effects CC 2017 RAM preview problem
    jokog75920106 Level 1
      Hey,
      i use After Effects two years. Now I had buy new hardware.
      System:
      i7 6700k
      GTX 1070
      16 RAM
      Win 10 Pro
      I thought it works good, but i can't use the ram preview correctly.
      If I would play a clip (30s long) without a effect, so the clip rendered to 1 second an played in a loop.
      The same clip with a effect for example twitch, it rendered the same time of 1 second and played also in a loop.
      AE can use 14GB of RAM and there is maybe 1 or 2 GB in use.
      I swichted the view render from CPU to GPU and reversed. I see no different.
      Where is the problem (?), my cache had I clean up. By the way premiere work very goog and without problems.
      Thank you!
        1 2 Previous Next
