9 Replies Latest reply on Jan 16, 2017 1:14 PM by scottshermandesign
    Error Code 1151
    scottshermandesign
      I built my website with Flash in 2010 (Action Script 2.0) and am trying to add material, now using Animate CC 2017 (which requires it to convert to AS 3.0).
      When I open the old .fla file and then run thru Control/Test Movie it comes up with the following error code message:
      "1151 A conflict exists with the definition MyHoriTween in namespace internal".
      In the Actions pane, the offending code reads:
      ____________________________________________
      import mx.transitions.Tween;
      import mx.transitions.easing.*;
      var myHoriTween:Tween = new Tween (Logo_ON_mc,"_x",Strong.easeOut,-450,-74,2,true)
      ___________________________________________________________
      And there are 3 other 1151 type errors all relating to Tweens.
      Can anyone help?
        • 1. Re: Error Code 1151
          you shouldn't re-declare the same variable:
          should only appear once on any one timeline/class.  it can be reused but that's not necessarily wise. using different names is more prudent:
          var tween1:Tween = whatever;
          var tween2:Tween = whatever else;
          etc.
          • 2. Re: Error Code 1151
            scottshermandesign Level 1
            Thanks kglad.
            I think I fixed that (at least the errors went away--though it still cycles through without stopping) but now I am getting an error code regarding the Sound layer:
            1046 Type was not found or was not a compile-time constant: Void
            And this was the code line it was referencing
            var game_sound:Sound = new Sound();
            game_sound.onLoad = function(success:Boolean):Void {
                if (success) {
                    trace("Sound Loaded");
                    game_sound.start();
            game_sound.loadSound("pagechangeSFX2.mp3", false);
            Any thoughts?
            Scott
            • 3. Re: Error Code 1151
              that should be void.  actionscript 3 is case-sensitive.
              • 4. Re: Error Code 1151
                More error codes:
                1120 Access of undefined property percent
                Here is the code block it is referencing:
                percent = Math.floor(getBytesLoaded()/getBytesTotal()*100);
                loadingPercent.text = percent + " %";
                Also,
                1180 Call to an undefined method getbytestloaded
                Code:
                Also,
                1120 Access of undefined property progressBar_mc
                Code:
                //create clips to hold your content
                this.createEmptyMovieClip("progressBar_mc", 0);
                progressBar_mc.createEmptyMovieClip("bar_mc", 1);
                progressBar_mc.createEmptyMovieClip("stroke_mc", 2);
                //use drawing methods to create a progress bar
                with (progressBar_mc.stroke_mc) {
                   lineStyle(0, 0x000000);
                   moveTo(0, 0);
                   lineTo(100, 0);
                   lineTo(100, 10);
                   lineTo(0, 10);
                   lineTo(0, 0);
                with (progressBar_mc.bar_mc) {
                   beginFill(0xFF0000, 100);
                   moveTo(0, 0);
                   lineTo(100, 0);
                   lineTo(100, 10);
                   lineTo(0, 10);
                   lineTo(0, 0);
                   endFill();
                   _xscale = 0;
                progressBar_mc._x = 2;
                progressBar_mc._y = 1143;
                // load progress
                var mclListener:Object = new Object();
                mclListener.onLoadStart = function(target_mc:MovieClip) {
                   progressBar_mc.bar_mc._xscale = 0;
                mclListener.onLoadProgress = function(target_mc:MovieClip, bytesLoaded:Number, bytesTotal:Number) {
                   progressBar_mc.bar_mc._xscale = Math.round(bytesLoaded/bytesTotal*100);
                mclListener.onLoadComplete = function(target_mc:MovieClip) {
                   progressBar_mc.removeMovieClip();
                mclListener.onLoadInit = function(target_mc:MovieClip) {
                   target_mc._height = 500;
                   target_mc._width = 700;
                • 5. Re: Error Code 1151
                  to solve that percent error, use:
                  var percent:Number = Math.floor(this.loaderInfo.bytesLoaded/this.loaderInfo.bytesTotal*100);
                  for your progressBar_mc error, you need to define progressBar_mc either on stage or in code.
                  • 6. Re: Error Code 1151
                    Next errors:
                    Error Message:
                    1172: Definition mx.transitions:Tween could not be found
                    1172: Definition mx.transitions.easing could not be found
                    Code:
                    var myHoriTween:Tween = new Tween (Logo_OFF_mc,"_x",Strong.easeOut,-450,-83,2,true);
                    • 7. Re: Error Code 1151
                      that should be:
                      import fl.transitions.Tween;
                      import fl.transitions.easing.*;
                      (p.s when using the adobe forums, please mark helpful/correct responses, if there are any.)
                      • 8. Re: Error Code 1151
                        Thanks, kglad!
                        Here is the next issue:
                        Error Message:
                        1067: Implicit coercion of a value of type int to an unrelated type string
                        Code:
                        if (percent ==100){
                        gotoAndPlay("animation",1);
                        }else{
                        gotoAndPlay(1);
                        Also, kglad I would be interested in paying you to clean up all the code on this website if you are interested.
                        • 9. Re: Error Code 1151
                          Thanks, kglad!
                          Here is my next issue:
                          Error Message:
                          Code:
                          if (percent ==100){
                          }else{
                          gotoAndPlay(1);
