Je ne retrouve pas cet outil sur Acrobat DC qui permettait de copier/coller d'un doc sur l'autre plusieurs lignes de texte de polices, couleur, tailles différentes.
Salutations.
Hi jbd32416826,
Could you please confirm if you are referring to Edit Object option under Tools>Content (Acrobat X Pro), below is the screenshot?
If yes, you can launch Acrobat DC>click Tools>type edit and select Edit PDF. You can also add this tool to the right hand pane toolbar by clicking Add.
Let me know if you have a different query.
Thank You,
Shivam
Bonjour,
Excusez moi je parle mal anglais, regardez le Pdf joint vous avez l’outil dans Acrobat DC Pro pour modifier une image.
Cet outil remplace celui de X Pro.
Salutations.
[Unnecessay information removed by moderator]
Hi jbd32416826,
There have been some changes in Acrobat design which allows to you access tools you need more quickly.
You may visit the following link which shows how to edit pdfs in Acrobat DC:
Use Adobe Acrobat DC to edit text and images in PDFs | Adobe Acrobat DC tutorials
Let me know if you have further questions.
-Shivam
